I'm just wondering about the reason for choosing an FIR filter over an IIR for ECG signals. If an IIR filter was used for a signal (in this case, an ECG)which contained many signal frequencies of interest, could distortion of the signal be a problem due to the non-linear phase? I only ask because I've seen papers which use IIR filters for ECG noise removal, and I'm wondering if some special technique is required to minimise distortion due to the non-linear phase characteristic, or if in fact the distortion is so minimal that it's negligible. Regards, Mike
ECG Filter IIR vs. FIR
Started by ●March 18, 2009
Reply by ●March 18, 20092009-03-18
On 18 Mar, 19:55, "mike2108" <michealho...@hotmail.com> wrote:> I'm just wondering about the reason for choosing an FIR filter over an IIR > for ECG signals. > > If an IIR filter was used for a signal (in this case, an ECG)which > contained many signal frequencies of interest, could distortion of the > signal be a problem due to the non-linear phase?There will be 'distorsion' of the signal regardless of whether the phase is linear or not.> I only ask because I've seen papers which use IIR filters for ECG noise > removal, and I'm wondering if some special technique is required to > minimise distortion due to the non-linear phase characteristic, or if in > fact the distortion is so minimal that it's negligible.Ask the cardiologists. Many years ago I saw a presentation on DSP of ECG signals, where the discussion addressed distorsions of the signal. One participant mentioned that cardiologists might interpret the data wrong if they showed certain types of distorsions. If they can see something that was introduced by the filter, and interpret it as a medical condition, the distorsion is too bad, regardless of the filter being IIR or FIR. Rune
>On 18 Mar, 19:55, "mike2108" <michealho...@hotmail.com> wrote: >> I'm just wondering about the reason for choosing an FIR filter over anIIR>> for ECG signals. >> >> If an IIR filter was used for a signal (in this case, an ECG)which >> contained many signal frequencies of interest, could distortion of the >> signal be a problem due to the non-linear phase? > >There will be 'distorsion' of the signal regardless of >whether the phase is linear or not. > >> I only ask because I've seen papers which use IIR filters for ECGnoise>> removal, and I'm wondering if some special technique is required to >> minimise distortion due to the non-linear phase characteristic, or ifin>> fact the distortion is so minimal that it's negligible. > >Ask the cardiologists. Many years ago I saw a presentation on >DSP of ECG signals, where the discussion addressed distorsions >of the signal. One participant mentioned that cardiologists >might interpret the data wrong if they showed certain types >of distorsions. If they can see something that was introduced >by the filter, and interpret it as a medical condition, the >distorsion is too bad, regardless of the filter being IIR or >FIR. > >Rune >Many thanks Rune, I guess it must just be a relative thing. Mike
