Convolution property of DFT
Started by third_person June 29, 2010
Hi, I'm trying fast convolution property but there seems to be some mistake
(with the answer).
Here is the Matlab code for it,
clear all; clc;
% Test Vector Convolution
a = [1 2 3 4 5];
b = [10 20 30 40 50];
c= conv(a,b)
A = [1 2 3 4 5 zeros(1,5)];
B = [10 20 30 40 50 zeros(1,5)];
d= ifft(fft(A) .* fft(B))
c - d(1:9)
The results are:
c =
    10    40   100   200   350   440   460   400   250
d =
   10.0000   40.0000  100.0000  200.0000  350.0000  440.0000  460.0000
400.0000  250.0000    0.0000
ans =  (for the difference b/w the two)
  1.0e-012 *
   -0.0906   -0.0497   -0.0284   -0.0284  0  0.1137  0  0  0
Shouldn't the result be smaller than eps (2.2204e-016)?
On 6/29/10 12:26 PM, third_person wrote:
> Hi, I'm trying fast convolution property but there seems to be some mistake > (with the answer). > > Here is the Matlab code for it, > > clear all; clc; > > % Test Vector Convolution > > a = [1 2 3 4 5]; > b = [10 20 30 40 50]; > c= conv(a,b) > A = [1 2 3 4 5 zeros(1,5)]; > B = [10 20 30 40 50 zeros(1,5)]; > d= ifft(fft(A) .* fft(B)) > c - d(1:9) > > The results are: > > c = > > 10 40 100 200 350 440 460 400 250 > > d = > > 10.0000 40.0000 100.0000 200.0000 350.0000 440.0000 460.0000 > 400.0000 250.0000 0.0000 > > ans = (for the difference b/w the two) > > 1.0e-012 * > > -0.0906 -0.0497 -0.0284 -0.0284 0 0.1137 0 0 0 > > > Shouldn't the result be smaller than eps (2.2204e-016)? >
Why do you think it should smaller than eps? Do you think fft and ifft have no roundoff? I don't know what the actual roundoff should be but a difference of 1e-13 seems fairly reasonable. Ray
On Jun 29, 12:26�pm, "third_person"
<third_person@n_o_s_p_a_m.ymail.com> wrote:
> Hi, I'm trying fast convolution property but > there seems to be some mistake > (with the answer). > > Here is the Matlab code for it, > > clear all; clc; > > % Test Vector Convolution > > a = [1 2 3 4 5]; > b = [10 20 30 40 50]; > c= conv(a,b) > A = [1 2 3 4 5 zeros(1,5)]; > B = [10 20 30 40 50 zeros(1,5)]; > d= ifft(fft(A) .* fft(B)) > c - d(1:9) > > The results are: > > c = > > &#4294967295; &#4294967295; 10 &#4294967295; &#4294967295;40 &#4294967295; 100 &#4294967295; 200 &#4294967295; 350 &#4294967295; 440 &#4294967295; 460 &#4294967295; 400 &#4294967295; 250 > > d = > > &#4294967295; &#4294967295;10.0000 &#4294967295; 40.0000 &#4294967295;100.0000 &#4294967295;200.0000 &#4294967295;350.0000 &#4294967295;440.0000 &#4294967295;460.0000 > 400.0000 &#4294967295;250.0000 &#4294967295; &#4294967295;0.0000 > > ans = &#4294967295;(for the difference b/w the two) > > &#4294967295; 1.0e-012 * > > &#4294967295; &#4294967295;-0.0906 &#4294967295; -0.0497 &#4294967295; -0.0284 &#4294967295; -0.0284 &#4294967295;0 &#4294967295;0.1137 &#4294967295;0 &#4294967295;0 &#4294967295;0 > > Shouldn't the result be smaller than eps (2.2204e-016)?
Typically, 1. A and B are zeropadded to length(A)+length(B)-1 2. If A an B are real, d = real(ifft(fft(A) .* fft(B)) is used because ifft is notorious for creating spurious imaginary roundoff error However, the results I obtained below surprised me (Note the change in notation) clear all, clc a = [1 2 3 4 5]'; b = [10 20 30 40 50]'; c= conv(a,b) ; A = [1 2 3 4 5 zeros(1,4)]'; B = [10 20 30 40 50 zeros(1,4)]'; C = ifft(fft(A) .* fft(B)); D = [c C(1:9)] % D = % % 10 10 % 40 40 +1.2632e-014i % 100 100 -6.3159e-015i % 200 200 % 350 350 -6.3159e-015i % 440 440 -7.7816e-015i % 460 460 % 400 400 -6.3159e-015i % 250 250 +1.4097e-014i A = [1 2 3 4 5 zeros(1,5)]'; B = [10 20 30 40 50 zeros(1,5)]'; C = ifft(fft(A) .* fft(B)); D = [c C(1:9)] % D = % % 10 10 % 40 40 % 100 100 % 200 200 % 350 350 % 440 440 % 460 460 % 400 400 % 250 250 I can't explain it. Can someone else? Greg
On Jun 30, 9:53&#4294967295;am, Greg Heath <he...@alumni.brown.edu> wrote:
> On Jun 29, 12:26&#4294967295;pm, "third_person" > > > > <third_person@n_o_s_p_a_m.ymail.com> wrote: > > Hi, I'm trying fast convolution property but > > there seems to be some mistake > > (with the answer). > > > Here is the Matlab code for it, > > > clear all; clc; > > > % Test Vector Convolution > > > a = [1 2 3 4 5]; > > b = [10 20 30 40 50]; > > c= conv(a,b) > > A = [1 2 3 4 5 zeros(1,5)]; > > B = [10 20 30 40 50 zeros(1,5)]; > > d= ifft(fft(A) .* fft(B)) > > c - d(1:9) > > > The results are: > > > c = > > > &#4294967295; &#4294967295; 10 &#4294967295; &#4294967295;40 &#4294967295; 100 &#4294967295; 200 &#4294967295; 350 &#4294967295; 440 &#4294967295; 460 &#4294967295; 400 &#4294967295; 250 > > > d = > > > &#4294967295; &#4294967295;10.0000 &#4294967295; 40.0000 &#4294967295;100.0000 &#4294967295;200.0000 &#4294967295;350.0000 &#4294967295;440.0000 &#4294967295;460.0000 > > 400.0000 &#4294967295;250.0000 &#4294967295; &#4294967295;0.0000 > > > ans = &#4294967295;(for the difference b/w the two) > > > &#4294967295; 1.0e-012 * > > > &#4294967295; &#4294967295;-0.0906 &#4294967295; -0.0497 &#4294967295; -0.0284 &#4294967295; -0.0284 &#4294967295;0 &#4294967295;0.1137 &#4294967295;0 &#4294967295;0 &#4294967295;0 > > > Shouldn't the result be smaller than eps (2.2204e-016)? > > Typically, > 1. A and B are zeropadded to length(A)+length(B)-1 > 2. If A an B are real, d = real(ifft(fft(A) .* fft(B)) > is used because ifft is notorious for creating > spurious imaginary roundoff error > > However, the results I obtained below surprised me > (Note the change in notation) > > clear all, clc > > a = [1 2 3 4 5]'; > b = [10 20 30 40 50]'; > c= conv(a,b) ; > A = [1 2 3 4 5 zeros(1,4)]'; > B = [10 20 30 40 50 zeros(1,4)]'; > C = ifft(fft(A) .* fft(B)); > D = [c C(1:9)] > > % D = > % > % &#4294967295; 10 &#4294967295; &#4294967295; &#4294967295; &#4294967295; 10 > % &#4294967295; 40 &#4294967295; &#4294967295; &#4294967295; &#4294967295; 40 +1.2632e-014i > % &#4294967295;100 &#4294967295; &#4294967295; &#4294967295; &#4294967295;100 -6.3159e-015i > % &#4294967295;200 &#4294967295; &#4294967295; &#4294967295; &#4294967295;200 > % &#4294967295;350 &#4294967295; &#4294967295; &#4294967295; &#4294967295;350 -6.3159e-015i > % &#4294967295;440 &#4294967295; &#4294967295; &#4294967295; &#4294967295;440 -7.7816e-015i > % &#4294967295;460 &#4294967295; &#4294967295; &#4294967295; &#4294967295;460 > % &#4294967295;400 &#4294967295; &#4294967295; &#4294967295; &#4294967295;400 -6.3159e-015i > % &#4294967295;250 &#4294967295; &#4294967295; &#4294967295; &#4294967295;250 +1.4097e-014i > > A = [1 2 3 4 5 zeros(1,5)]'; > B = [10 20 30 40 50 zeros(1,5)]'; > C = ifft(fft(A) .* fft(B)); > D = [c C(1:9)] > > % D = > % > % &#4294967295; &#4294967295;10 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; 10 > % &#4294967295; &#4294967295;40 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; 40 > % &#4294967295; 100 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;100 > % &#4294967295; 200 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;200 > % &#4294967295; 350 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;350 > % &#4294967295; 440 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;440 > % &#4294967295; 460 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;460 > % &#4294967295; 400 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;400 > % &#4294967295; 250 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;250 > > I can't explain it. Can someone else?
i don't understand what's troubling you, Greg. is it the extremely tiny imaginary values that result (presumably from roundoff) when N=9 that don't when N=10? r b-j
On Jun 30, 12:03&#4294967295;pm, robert bristow-johnson
<r...@audioimagination.com> wrote:
> On Jun 30, 9:53&#4294967295;am, Greg Heath <he...@alumni.brown.edu> wrote: > > > > > > > On Jun 29, 12:26&#4294967295;pm, "third_person" > > > <third_person@n_o_s_p_a_m.ymail.com> wrote: > > > Hi, I'm trying fast convolution property but > > > there seems to be some mistake > > > (with the answer). > > > > Here is the Matlab code for it, > > > > clear all; clc; > > > > % Test Vector Convolution > > > > a = [1 2 3 4 5]; > > > b = [10 20 30 40 50]; > > > c= conv(a,b) > > > A = [1 2 3 4 5 zeros(1,5)]; > > > B = [10 20 30 40 50 zeros(1,5)]; > > > d= ifft(fft(A) .* fft(B)) > > > c - d(1:9) > > > > The results are: > > > > c = > > > > &#4294967295; &#4294967295; 10 &#4294967295; &#4294967295;40 &#4294967295; 100 &#4294967295; 200 &#4294967295; 350 &#4294967295; 440 &#4294967295; 460 &#4294967295; 400 &#4294967295; 250 > > > > d = > > > > &#4294967295; &#4294967295;10.0000 &#4294967295; 40.0000 &#4294967295;100.0000 &#4294967295;200.0000 &#4294967295;350.0000 &#4294967295;440.0000 &#4294967295;460.0000 > > > 400.0000 &#4294967295;250.0000 &#4294967295; &#4294967295;0.0000 > > > > ans = &#4294967295;(for the difference b/w the two) > > > > &#4294967295; 1.0e-012 * > > > > &#4294967295; &#4294967295;-0.0906 &#4294967295; -0.0497 &#4294967295; -0.0284 &#4294967295; -0.0284 &#4294967295;0 &#4294967295;0.1137 &#4294967295;0 &#4294967295;0 &#4294967295;0 > > > > Shouldn't the result be smaller than eps (2.2204e-016)? > > > Typically, > > 1. A and B are zeropadded to length(A)+length(B)-1 > > 2. If A an B are real, d = real(ifft(fft(A) .* fft(B)) > > is used because ifft is notorious for creating > > spurious imaginary roundoff error > > > However, the results I obtained below surprised me > > (Note the change in notation) > > > clear all, clc > > > a = [1 2 3 4 5]'; > > b = [10 20 30 40 50]'; > > c= conv(a,b) ; > > A = [1 2 3 4 5 zeros(1,4)]'; > > B = [10 20 30 40 50 zeros(1,4)]'; > > C = ifft(fft(A) .* fft(B)); > > D = [c C(1:9)] > > > % D = > > % > > % &#4294967295; 10 &#4294967295; &#4294967295; &#4294967295; &#4294967295; 10 > > % &#4294967295; 40 &#4294967295; &#4294967295; &#4294967295; &#4294967295; 40 +1.2632e-014i > > % &#4294967295;100 &#4294967295; &#4294967295; &#4294967295; &#4294967295;100 -6.3159e-015i > > % &#4294967295;200 &#4294967295; &#4294967295; &#4294967295; &#4294967295;200 > > % &#4294967295;350 &#4294967295; &#4294967295; &#4294967295; &#4294967295;350 -6.3159e-015i > > % &#4294967295;440 &#4294967295; &#4294967295; &#4294967295; &#4294967295;440 -7.7816e-015i > > % &#4294967295;460 &#4294967295; &#4294967295; &#4294967295; &#4294967295;460 > > % &#4294967295;400 &#4294967295; &#4294967295; &#4294967295; &#4294967295;400 -6.3159e-015i > > % &#4294967295;250 &#4294967295; &#4294967295; &#4294967295; &#4294967295;250 +1.4097e-014i > > > A = [1 2 3 4 5 zeros(1,5)]'; > > B = [10 20 30 40 50 zeros(1,5)]'; > > C = ifft(fft(A) .* fft(B)); > > D = [c C(1:9)] > > > % D = > > % > > % &#4294967295; &#4294967295;10 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; 10 > > % &#4294967295; &#4294967295;40 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; 40 > > % &#4294967295; 100 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;100 > > % &#4294967295; 200 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;200 > > % &#4294967295; 350 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;350 > > % &#4294967295; 440 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;440 > > % &#4294967295; 460 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;460 > > % &#4294967295; 400 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;400 > > % &#4294967295; 250 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;250 > > > I can't explain it. Can someone else? > > i don't understand what's troubling you, Greg. &#4294967295;is it the extremely > tiny imaginary values that result (presumably from roundoff) when > N=9 that don't when N=10?
I usually get imaginary valued roundoff when I use ifft and the result should be real. I was intrigued that, in contrast, the OP got purely real roundoff. Then I noticed that he used one more zero than necessary in the zeropadding. So, I removed the extra zero and got purely imaginary roundoff. Satisfied that my understanding was validated, I put the extra zero back in to see if that was the cause of the real valued roundoff... Much to my surprise, my calculation resulted in no roundoff error. I find this puzzling, even intriguing, but certainly not troublesome. Greg
