On Jan 10, 7:32�pm, robert bristow-johnson <r...@audioimagination.com> wrote:> On Jan 10, 6:39�pm, Greg Heath <he...@alumni.brown.edu> wrote: > > > > >http://12000.org/my_notes/transforms/transforms.png > > > Hope this helps. > > nice chart. > > one old issue that gets me into fights here is that i disagree with > the mathematical factuality of this statement: "Finite x[n] length N, > zero elsewhere". > > it's oft repeated, you see it in print, and it's wrong. >another problem with it is that it is sloppy with the notation regarding X_a(omega) vs. X_a(f). even though they are notated as the same function, unless X_a() is a constant function, X_a(f) cannot be the same as X_a(omega) with "f" substituted as the argument. i know it's hard to be consistent, but i really dislike the "omega" notation. with the unitary "f" notation of the CFT, it's much easier to remember theorems and relationships (like duality, convolution, Parseval) and not have to worry about where you toss in 1/(2*pi) and where you don't. r b-j
Appendix A: Types of Fourier Transforms
Started by ●January 10, 2011
Reply by ●January 10, 20112011-01-10
On Jan 10, 9:00�pm, Tim Wescott <t...@seemywebsite.com> wrote:> Just to inscribe this on the wall in cyberspace:> �From this you get the four possible combinations: > > continuous-time infinite --> continuous-frequency infinite. > continuous-time cyclic --> discrete-frequency infinite. > discrete-time infinite --> continuous-frequency cyclic. > discrete-time cyclic --> discrete-frequency, cyclic.Almost correct, but crucially wrong: There is no suct thing as a 'cyclic' signal. Those signals are of infinite duration. You confuse the 'cyclic' signal with the 'finite duration' *function*. Your variants 2 and 4 are the FTs that work on finite-duration domains. For continuous time, that's the Fourier series; for discrete time that's the DFT.> I'm pulling this from memory, but you can find it in books with titles > like "Signals and Systems"; the one on my shelf is by Oppenheim, Willsky > & Young.The blunders and flaws you present above might, yes. But if one wants to understand the properties of the various variants of the FT one is better off consulting the maths literature, e.g. on differential equations.> There. �I'll put down my can of spray paint now.Pick up a new one and spray base color over the blunders, and try again. Rune
Reply by ●January 11, 20112011-01-11
On Jan 10, 10:30�pm, Rune Allnor <all...@tele.ntnu.no> wrote:> On Jan 10, 9:00�pm, Tim Wescott <t...@seemywebsite.com> wrote: > > > Just to inscribe this on the wall in cyberspace: > > �From this you get the four possible combinations: > > > continuous-time infinite --> continuous-frequency infinite. > > continuous-time cyclic --> discrete-frequency infinite. > > discrete-time infinite --> continuous-frequency cyclic. > > discrete-time cyclic --> discrete-frequency, cyclic. > > Almost correct, but crucially wrong: There is no suct thing as > a 'cyclic' signal. Those signals are of infinite duration. > You confuse the 'cyclic' signal with the 'finite duration' > *function*.sorry, Rune. but it's you (and many others) that are crucially wrong. and i'm willing to take you on about it. i've been doing this multiple times since my very beginning here at comp.dsp in 1995 or 96.> Your variants 2 and 4 are the FTs that work > on finite-duration domains. For continuous time, that's > the Fourier series; for discrete time that's the DFT.fundamentally, the DFT is nothing other than the DFS. the DFT maps a discrete and periodic function in one domain (we'll call it the "time domain") to another discrete and periodic function in the reciprocal domain (we'll call it the "frequency domain"). that's what the DFT does. periodic on one domain implies discrete (with dirac impulses) in the other domain and vise-versa. the converse is also true: non-periodic on one domain implies continuous in the other domain. just because a function can be fully described by a finite-length segment of that function, does not mean that the function is itself finite in duration. r b-j
On Jan 11, 6:23�am, robert bristow-johnson <r...@audioimagination.com> wrote:> On Jan 10, 10:30�pm, Rune Allnor <all...@tele.ntnu.no> wrote: > > > On Jan 10, 9:00�pm, Tim Wescott <t...@seemywebsite.com> wrote: > > > > Just to inscribe this on the wall in cyberspace: > > > �From this you get the four possible combinations: > > > > continuous-time infinite --> continuous-frequency infinite. > > > continuous-time cyclic --> discrete-frequency infinite. > > > discrete-time infinite --> continuous-frequency cyclic. > > > discrete-time cyclic --> discrete-frequency, cyclic. > > > Almost correct, but crucially wrong: There is no suct thing as > > a 'cyclic' signal. Those signals are of infinite duration. > > You confuse the 'cyclic' signal with the 'finite duration' > > *function*. > > sorry, Rune. �but it's you (and many others) that are crucially > wrong. �and i'm willing to take you on about it. �i've been doing this > multiple times since my very beginning here at comp.dsp in 1995 or 96.So what? Do claim that your persistence of making an incorrect point turns the blunder correct? That your seniority here matters? We have had many slugfests over this issue in the past, your position is as well known as it is flawed, so I will not engage in yet another fight. It's sad to see how you pull others down with you, though. Rune
On Jan 11, 1:03�am, Rune Allnor <all...@tele.ntnu.no> wrote:> > So what? Do claim that your persistence of making an incorrect point > turns the blunder correct?is the premise of your question supported? of course persistence of an incorrect point does not make it correct. (except for the current Republican Americans and the 1940 Nazis who are convinced that if they repeat a falsehood often enough, somehow it evolves from outright lie to plausible notion and eventually to gospel truth.)> That your seniority here matters?no, it's the math that matters. i'm just saying i'm kinda well-practiced in this argument. and it was only since '95 or '96 that i had to make it. before then, i had no idea that it was controversial. i guess i hadn't looked closely at texts other than O&S about it, so i was sorta ignorant of the other views.> We have had many slugfests over this issue in the past, your position > is as well known as it is flawed,... yet showing the flaw is so elusive ... BTW, i might agree with you a teeny-weeny bit in one sense; Tim shouldn't have "infinte" vs. "cyclic". it should be "non-cyclic" vs. "cyclic", or i might say "non-periodic" vs. "periodic". you're saying it should be "infinite" vs. "finite" and i am saying that they all have infinite support.> so I will not engage in yet another fight. > > It's sad to see how you pull others down with you, though.oh, Rune. you're no fun anymore. (can you watch Monty Python up there in the Arctic?) r b-j
>On Jan 10, 9:00=A0pm, Tim Wescott <t...@seemywebsite.com> wrote: >> Just to inscribe this on the wall in cyberspace: > >> =A0From this you get the four possible combinations: >> >> continuous-time infinite --> continuous-frequency infinite. >> continuous-time cyclic --> discrete-frequency infinite. >> discrete-time infinite --> continuous-frequency cyclic. >> discrete-time cyclic --> discrete-frequency, cyclic. > >Almost correct, but crucially wrong: There is no suct thing as >a 'cyclic' signal. Those signals are of infinite duration. >You confuse the 'cyclic' signal with the 'finite duration' >*function*. Your variants 2 and 4 are the FTs that work >on finite-duration domains. For continuous time, that's >the Fourier series; for discrete time that's the DFT.It seems to be you confusing things. Of course cyclic signals exist. A pure sine wave is a trivial example. They are, by implication, infinite in length. If they were not, they wouldn't be truly cyclic. They would be the product of a cyclic signal with a pulse of appropriate length. Steve
On Jan 11, 8:03�am, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote:> >On Jan 10, 9:00=A0pm, Tim Wescott <t...@seemywebsite.com> wrote: > >> Just to inscribe this on the wall in cyberspace: > > >> =A0From this you get the four possible combinations: > > >> continuous-time infinite --> continuous-frequency infinite. > >> continuous-time cyclic --> discrete-frequency infinite. > >> discrete-time infinite --> continuous-frequency cyclic. > >> discrete-time cyclic --> discrete-frequency, cyclic. > > >Almost correct, but crucially wrong: There is no suct thing as > >a 'cyclic' signal. Those signals are of infinite duration. > >You confuse the 'cyclic' signal with the 'finite duration' > >*function*. Your variants 2 and 4 are the FTs that work > >on finite-duration domains. For continuous time, that's > >the Fourier series; for discrete time that's the DFT. > > It seems to be you confusing things. Of course cyclic signals exist. A pure > sine wave is a trivial example. They are, by implication, infinite in > length.And that's where the problem occurs: The condition for the FT of a function x(t) to exist (CT infinite domain) is that integral |x(t)|^2 dt < infinite With x(t) = sin(t) that breaks down. Note that this has nothing to do with the sine being periodic, it has to do with it having infinite energy. (Try the same excercise with y(t) = sin(t)+sin(pi*t) to see why.) To get out of that embarrasment, engineers (*not* mathematicians) came up with the ad hoc solution to express the periodic sine as a sequence of periods, repeated ad infinitum, and compute the Fourier series of one period. It has no mathematical meaning, as the rather essential property of linearity of the FT breaks down (again, use the y(t) above to see why). Again, this is totally trivial. Rune
On Jan 11, 7:23�am, robert bristow-johnson <r...@audioimagination.com> wrote:> On Jan 11, 1:03�am, Rune Allnor <all...@tele.ntnu.no> wrote:> > We have had many slugfests over this issue in the past, your position > > is as well known as it is flawed, > > ... yet showing the flaw is so elusive ... > > BTW, i might agree with you a teeny-weeny bit in one sense; Tim > shouldn't have "infinte" vs. "cyclic". �it should be "non-cyclic" vs. > "cyclic", or i might say "non-periodic" vs. "periodic". �you're saying > it should be "infinite" vs. "finite" and i am saying that they all > have infinite support.Ant *that* is where the elusive flaw is hidden! Why have two different types of analyses, mutually exclusive, of the same mathemathical entity? Both the periodic x(t)=sin(t) and aperiodic y(t)=sin(t)+sin(pi*t) have similar mathematical properties, *except* for x(t) being periodic whereas y(t) is not. Why not subject the two to the same mathematical tools? Which are supposed to be linear? What sense is there in a *linear* tool that works on f(t) = x(t) but not on g(t) = x(t) + y(t)? Rune
On Jan 10, 4:32�pm, robert bristow-johnson <r...@audioimagination.com> wrote:> ...> one old issue that gets me into fights here is that i disagree with > the mathematical factuality of this statement: "Finite x[n] length N, > zero elsewhere". > > it's oft repeated, you see it in print, and it's wrong. > > r b-jThis appears so often because it is the only information that the DFT is given. There are many assumptions that can be made about the region outside the "length N", but the consequences of those assumptions are properties of the assumptions and not properties of the DFT. The output of the DFT is not a function of the values outside that "length N" The set of all functions I can calculate the DFT on N samples of is not limited to periodic functions. It would certainly be convenient and elegant if all signals of which I might come across a set of N samples had the characteristic that contiguous blocks of the signal had identical samples. Some people seem to have been so seduced by the convenience and elegance of a universe limited to such signals that they decide that they should live only in a world where that is true and they try to convince those around them to live there. But there have been many stochastic or non- stationary or even discrete frequency signals for which periodicity does not hold despite the fact that I have sampled and performed the DFT on N of those samples. Dale B. Dalrymple
On Jan 11, 2:44�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On Jan 11, 7:23�am, robert bristow-johnson <r...@audioimagination.com> > wrote: > > > On Jan 11, 1:03�am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > We have had many slugfests over this issue in the past, your position > > > is as well known as it is flawed, > > > ... yet showing the flaw is so elusive ... > > > BTW, i might agree with you a teeny-weeny bit in one sense; Tim > > shouldn't have "infinte" vs. "cyclic". �it should be "non-cyclic" vs. > > "cyclic", or i might say "non-periodic" vs. "periodic". �you're saying > > it should be "infinite" vs. "finite" and i am saying that they all > > have infinite support. > > And *that* is where the elusive flaw is hidden! Why have two > different types of analyses, mutually exclusive, of the same > mathematical entity? >well, there *is* a qualitative difference between discrete and continuous mathematics. with either axis. could be the mathematics of integers where both the argument and returned values of a function are integers or it can be signals that are discrete-time sequences vs. continuous-time functions. regarding the latter, we have a tool for relating the two domains and it is the Shannon/Nyquist Sampling (and Reconstruction) Theorem. now, _if_ you're willing to allow naked (that is, not always clothed with an integral) dirac impulses to exist**, you connect the discrete and continuous time (or frequency) domains by attaching dirac impulses to the members (a.k.a. elements) of the discrete sequence and use the continuous Fourier transform. Ultimately it's all the C.F.T., but there is no reason that one cannot use discrete tools (like the Z Transform or the DFT) within a problem where only discrete data exists. that's what we do as DSP engineers. **(so i'm not willing to divert this to the "the Dirac delta is not a function but something else" discussion.) but, if you want to establish a table of rules like:> continuous-time non-periodic <--> continuous-frequency non-periodic > continuous-time periodic <--> discrete-frequency non-periodic > discrete-time non-periodic <--> continuous-frequency periodic > discrete-time periodic <--> discrete-frequency periodic... which are attached to (respectively) CFT, Fourier Series, DTFT, and the DFT (or equivalently "DFS")... then you convert your discrete-whatever to continuous-whatever by attaching dirac impulses to the elements of the discrete sequences and use the continuous Fourier transform. but whenever you get an integral in the CFT (or inverse CFT), it may become a summation because the inside is a sum of uniformly-spaced dirac impulses. so the "different types of analyses" are NOT "mutually exclusive". they are related. just as the Z transform is related to the Laplace transform (operating on an dirac impulse train).> Both the periodic x(t)=sin(t) and aperiodic y(t)=sin(t)+sin(pi*t) > have similar mathematical properties, *except* for x(t) being > periodic whereas y(t) is not.so you deal with it with the CFT in both cases. big deel.> Why not subject the two to the same mathematical tools?> Which are supposed to be linear? What sense is there in > a *linear* tool that works on f(t) = x(t) but not on > g(t) = x(t) + y(t)?well, since both terms are pretty well bandlimited, there are two of those tools that works on g(t) or g[n] (CFT or DTFT) where information is not lost in the transform. it turns out that in both cases, the representation in at least one domain can be completely described with a set of numbers that are countably infinite. Rune, it depends on how anal-retentive (or OCD) the engineer is. It's not so much an issue of linearity but an issue of a sorta measure of information. In the continuous time/frequency case, you can go far enough out so that the functions are clearly different, no matter how many digits you give to pi. but we use tools like the DFT to deal with the finite sets of information that we are handed in real life. so we never, in practical reality, ever have to deal with the situation you bring up where, say, a million digits for pi ain't enough. so then, in reality, we limit the amount of information we have to deal (to finite sets that a computer might be expected to be able to deal with) with by truncating (a.k.a. "windowing") and sampling. both operations have a theory behind it. so far we might not be disagreeing. but, i think, the point to which we *do* disagree is that i am saying that when this finite set of numbers is passed to the DFT, it is as if the DFT (anthropomorphically) "assumes" that it is one period of a periodic sequence. the DFT inherently periodically extends (to infinity) the data that is passed to it. this is because the DFT and Discrete Fourier Series are one-and-the-same. if you were to pass the original data (sampled and windowed in whatever order) to the DTFT, no assumption of periodicity is made. in fact, you need to define those other samples (maybe their zero), for the DTFT to know what you're talking about. but the DFT and DTFT (with numbers attached to dirac impulses) agree with each other about what this periodically extended set of data is. and you can think of it as the continuous (but periodic) frequency-domain data of the DTFT (of the zero-extended finite x[n]) being sampled at N uniformly-spaced points between -pi and +pi. and, if you're really anal, you can push the whole thing up to the CFT and get equivalent maths. it's all the same. r b-j
