Good answer but almost 3 years too late M
SNR for ECG signal
Started by ●August 8, 2011
Reply by ●May 3, 20142014-05-03
Reply by ●March 27, 20152015-03-27
On Monday, August 8, 2011 at 2:39:26 PM UTC-4, Vladimir Vassilevsky wrote:> Tim Wescott wrote: > > > > Because an ECG signal is either non-stationary or non-Gaussian, or > > perhaps both, it's hard to express "SNR". Is this the measure that > > clinicians use to rate the quality of their ECG signals? If not, what > > is? If there is an alternative that's accepted, why not use it? > > There is aproximately a zillion of ECG analysers of all sorts around. A > megatonn of paperwork is written about it. Another ECG processor is just > what the world needs. > > Medics are interested in the so-called "QRS complex" parameters > calculated from the ECG data. The quality of ECG is the accuracy of the > QRS measurement. > > How do I know about this? Because I wrote a math part for a [zillion-1] > ECG processor :-) > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.comHi Vladimir, Is Kurtosis of the whole recorded ECG segment a good measure of accuracy of QRS measurement..? Thanks, Naveen
On Saturday, May 3, 2014 at 5:59:52 PM UTC-4, wdave...@googlemail.com wrote:> On Thursday, 11 August 2011 16:40:35 UTC+1, Jerry Avins wrote: > > On Aug 11, 3:40�am, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote: > > > >On Aug 8, 11:45=A0am, "Jebarajpeter" > > > ><jebarajselvapeter.p@n_o_s_p_a_m.jasmin-infotech.com> wrote: > > > >> Hi all, > > > >> I am working on baseline wander noise removal from ECG signal. I have > > > to > > > >> compare the performance of different algorithms. for comparison I have > > > to > > > >> use SNR. My question is how to calculate noise and signal power of an > > > ECG > > > >> signal available in the data set. I do not know what kind of noise is > > > the= > > > >re > > > >> in the ECG signal. > > > > > > >> I have tried like this: > > > > > > >> 1. Filter the ECG signal with a basic filter to remove the baseline > > > wande= > > > >r > > > >> signal. Then this signal is considered as Ideal signal (pure signal). > > > =A0 > > > >> 2. Then I have applied the devised algorithm to the original ECG > > > signal. > > > >> So the output from the algorithm has, > > > >> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0output =3D signal + noise; > > > >> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0noise =3D ideal - output > > > (usin= > > > >g the algorithm) > > > >> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0signal =3D output - noise; > > > >> using this i have calculated the SNR. Is it acceptable...? Please > > > help!! > > > > > > >> Best, > > > >> Jebaraj S.Peter > > > > > > >Before you dig into this, find out why the baseline wanders. Ideally, > > > >you will remove the cause instead of remedying the effect. In any > > > >event, you will know what you are contending with, always a good > > > >approach to a problem. > > > > > > >Jerry > > > > > > You want him to paralyse the patient? :-) ECG traces wander due to muscle > > > noise - i.e. the muscles other than the heart's. > > > > > > Steve > > > > See? It's always good to know what one is contending with. :-) > > > > Jerry > > -- > > Engineering is the art of making what you want from things you can get. > > Measure your noise in the in ST segmentof the ECG. This is stationary for approx 50mS. So take a window of 30mS in the middle of the S-T and add up all the data samples and find the standard deviation. > > Measure the signal across the QRS postion of the ECG...approx 120mS. Do the same with the data points. > > Divide the signal Std by the Noise Std. > > Job done.What about the samples in the PQ section? and also samples that are not in the PQRST segment? That is not considered as noise?
