[[forgot to add a point i had intended.]] On 12/10/11 11:13 AM, Fred Marshall wrote:> On 12/9/2011 9:31 AM, dbd wrote: >>> On 12/7/2011 7:59 PM, glen herrmannsfeldt wrote: >>> >>>> You can consider the DFT as the FT of delta functions at the data >>>> points, and periodic boundary conditions. >> >> The statement is very succinct, anyway. How many readers of comp.dsp >> do you think correctly convert "periodic boundary conditions" to the >> required assumption that the delta functions can only consist of >> samples of signals that are sums of components at the frequencies of >> the basis functions of the DFT?i certainly don't make that assumption. how have you determined that it is "required"?>> Aperiodic components and components >> periodic at other frequencies than the DFT's basis functions don't >> meet the "periodic boundary conditions".no kidding. that's why the DTFT and the DFT ain't the same thing (whereas the DFS and DFT *are* the same thing).> > Let us say that some signal with aperiodic components (relative to our > intended DFT) is sampled for a long time. > > Now let us select some N or temporal window and do a DFT on those > samples. The result is a length N discrete transform (complex usually). > > Now we have a transform pair. At this stage there are no aperiodic > components .. even though the original aperiodic components may have > affected the original samples. In effect what we have is a *new* > periodic sequence which deviates from the original *underlying* periodic > components.we need to be specific about what "we have" and what is deviating from the original. as i can observe it, *nothing* is deviating from the original if your entire universe is only those N samples. but if the entire universe is only those N samples, then it doesn't make any sense to talk of those "other" components, be they aperiodic or having a period other than N. in a universe of only N samples, there is no (and have never been) any meaning to any other components. but, if you think of these N samples as a sorta "pocket universe" (sorry to borrow from cosmology, Glen and Clay will probably wince) surrounded by an infinite sea of zeros, then (if you FT) you have the DTFT. [[and, at this point there likely *is* some deviation of what "we have" and the original underlying periodic (of some different period than N) or aperiodic components.]] the spectrum is continuous, but repeats every 2*pi. the spectrum is not zero outside of the [-pi +pi) interval, but if you make it so (in the mind of your brain or some other mathematician's brain), then those N samples are no longer attached to N dirac deltas, but are attached to N sinc() functions that go on forever and there is no periodicity in that domain. not yet. NOW (picking up on Fred's "when"), whether you zeroed the spectrum outside of [-pi +pi) or not (i don't care if you do or not), if you uniformly sample that spectrum with N samples from -pi to just under +pi (or from 0 to just under 2*pi, i don't really care), you have the DFT. and the act of sampling that spectrum *does* *necessarily* cause the periodic extension of the original data, the N samples. this is how you go from the one valid concept that "the DTFT is what you get when you attach N delta functions to the N original data points (uniformly spaced) and the DFT is what you get when you sample the DTFT result" to the other equally valid (but i say is *more* fundamental) that "the DFT invertibly maps one discrete and periodic sequence of numbers to another discrete and periodic sequence of numbers of the same period." ...> So, anyway, that's how I deal with the question of aperiodic components > .. which are only evident before N is selected. And, N, conceptually at > least, becomes a period of something that was originally not periodic > when we consider that we allow a discrete version of the FT of those > samples. > > Obviously we can compute the FT of the N samples and get a continuous > transform. Then the temporal periodicity wouldn't come up.not yet...> But that's not what we do.... that's right. what we do is *sample* the DTFT and the undeniable effect of that is the periodic extension of the> So, I call "what we do" a context. Then there are more > rigorous mathematical treatments to say the same thing but I rather > think that this somewhat philosophical treatment is worthwhile.it's also mathematically correct. and something that the periodicity deniers just don't seem to get. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Question about DFT
Started by ●December 7, 2011
Reply by ●December 10, 20112011-12-10
On Dec 10, 8:13 am, Fred Marshall <fmarshallxremove_th...@acm.org> wrote:> On 12/9/2011 9:31 AM, dbd wrote: > ... > > On Dec 8, 8:47 am, Fred Marshall<fmarshallxremove_th...@acm.org> > > wrote: > >> On 12/7/2011 7:59 PM, glen herrmannsfeldt wrote: > > >>> You can consider the DFT as the FT of delta functions at the data > >>> points, and periodic boundary conditions. > > >>> -- glen > > >> Glen, > > >> What an elegant way to put it! I don't think in all the discussions > >> that I've seen it expressed this way....> > Fred > > > The statement is very succinct, > > ... > > Dale B. Dalrymple> > Dale, > > Yes, I understand and agree to a point. Except for "when?". > > Let us say that some signal with aperiodic components (relative to our > intended DFT) is sampled for a long time. > > Now let us select some N or temporal window and do a DFT on those > samples. The result is a length N discrete transform (complex usually). > > Now we have a transform pair. At this stage there are no aperiodic > components .. even though the original aperiodic components may have > affected the original samples. In effect what we have is a *new* > periodic sequence which deviates from the original *underlying* periodic > components. Actually this occurred when we selected N. When we select > the sample rate and N, we are one way or another asserting its > periodicity. Well, I should add I guess "if we are going to compute a > DFT". I suppose there are other applications of those N samples that > wouldn't suggest such a thing.Yes, there are other applications of not just the N samples but the very same DFT coefficients. The algorithms know as 'frequency reassignment' calculate the amplitude, center frequency and phase of linear FM components from the same DFT coefficients. The N-periodic components are a subset of those linear FMs. So are periodic, but not N-periodic components. So, while you, as the analyst may chose to interpret via an N-periodic assumption, the use of DFT coefficients and selection of N and Fs and the signals to apply them to, do not need to depend on any prefered periodic assumption.> > Perhaps another way to put it is: > - once you've sampled there's no going back .. perfect reconstruction > being the only counter example that I can think of. > - once you've windowed i.e. selected N samples .. except for perhaps > things like concatenation of sequences with their neighboring samples .. > there's no going back. > - once you've DFT'd, you've put things in a context where everything is > periodic and there's no going back.Choosing to analyze and reason from only a single block of N samples is sometimes a necessity and sometimes just the analyst's choice, but it is a position of ignorance with respect to the properties of the original sequence whether voluntary or not. Analysts are free to chose assumptions to deal with that ignorance. You have your favorite assumption and I have often used it as well. It has the advantage of requiring the least additional processing after the DFT and is often good enough for applications.> > I'm not trolling for arguments or counter examples. Maybe these > assertions are just a "mind set". Without "proof" I think it's a useful > framework.We often try to pick N and Fs so that the assumption of periodicity is valid. Some instruments generate Fs to be synchronous with the periodicities of the signal. There is literature on resampling to make the Fs synchronous. It is often useful to make the assumption of periodiciy whether it is valid or not. My point is that the assumption is one possible interpretation (among others) by the analyst to cope with the consequences of examining only the analysis of one block of N samples. At the cost of further analysis of the N DFT coefficients, the assumption may not be necessary, useful, or appropriate.> > So, anyway, that's how I deal with the question of aperiodic components > .. which are only evident before N is selected. And, N, conceptually at > least, becomes a period of something that was originally not periodic > when we consider that we allow a discrete version of the FT of those > samples.In addition to the algorithms already suggested for application to the N DFT coefficients, the aperiodic components are also accesible to the analyst after N is selected by analyzing adjacent blocks of N samples and comparing magnitude and phase. Components that differ between the blocks are not N-periodic. (If the magnitudes are the same, the component may be periodic with period other than N.) If the components are identical, the components are candidates for periodicity. In theory, it would be necesary to analyze all blocks to prove periodicity. In practice it is often adequate to make the distinction between aperiodic or close-enough to periodic by comparing two or few blocks. In fact, until you do this there is no basis other than assumption, as stated by Glen's formulation or construction of the original time sequence by periodic extension by the analyst, as O&S do in their examples, for the periodic assumption. Well, in the construction case, the original sequence is defined by periodic extension, so the DFT and assumptions have nothing to do with it. But the assumption is convenient and often useful so it is often made without any basis.> Obviously we can compute the FT of the N samples and get a continuous > transform. Then the temporal periodicity wouldn't come up. But that's > not what we do. So, I call "what we do" a context. Then there are more > rigorous mathematical treatments to say the same thing but I rather > think that this somewhat philosophical treatment is worthwhile. >It a choice available to the analyst. It is both a choice of context and a choice of interpretation within that context.> And, of course, we all know that we can select "good" values of the > sample interval T and number of samples N and "bad" values of the same > such that some strong periodic component is grabbed with an integer plus > 1/2 of a period is in the window. That's pretty "aperiodic" and the > underlying (i.e. original) boundary conditions are ugly and the > resulting DFT is ugly too. But calling the DFT "ugly" is a perspective > while saying "it is what it is", I think, is more to the point.Ugly is your word, not mine. The DFT coefficients can still be used to calculate the frequency, ampltude and phase of the 'plus a 1/2' frequency component, which demonstrates that the assumption of N- periodicity is not a characteristic of the DFT and the coefficients it calculates, but one of many interpretations available to the analyst and one that can be usefully ignored when chosing how to analyze DFT coefficients. Is that what you mean by ugly?> ...Dale B. Dalrymple
On Dec 10, 10:23�am, robert bristow-johnson <r...@audioimagination.com> wrote:>... > > it's also mathematically correct. �and something that the periodicity > deniers just don't seem to get. > > r b-j r...@audioimagination.com > > "Imagination is more important than knowledge."There are no "periodicity deniers". There are only those deniers who know only a single small view of the world and from lack of imagination would deny others the use of many other valid useful world views. Dale B. Dalrymple
On 12/10/2011 12:42 PM, dbd wrote:>> And, of course, we all know that we can select "good" values of the >> > sample interval T and number of samples N and "bad" values of the same >> > such that some strong periodic component is grabbed with an integer plus >> > 1/2 of a period is in the window. That's pretty "aperiodic" and the >> > underlying (i.e. original) boundary conditions are ugly and the >> > resulting DFT is ugly too. But calling the DFT "ugly" is a perspective >> > while saying "it is what it is", I think, is more to the point. > Ugly is your word, not mine. The DFT coefficients can still be used to > calculate the frequency, ampltude and phase of the 'plus a 1/2' > frequency component, which demonstrates that the assumption of N- > periodicity is not a characteristic of the DFT and the coefficients it > calculates, but one of many interpretations available to the analyst > and one that can be usefully ignored when chosing how to analyze DFT > coefficients. Is that what you mean by ugly? >> > ... > Dale B. DalrympleDale, Well, let's see .. Yes, I introduced "ugly" to suggest the nature of the continous FT of what's in the temporal window .. the spectral spreading that's evident in that case. I didn't really say that but it's what I was imagining. So, we start with a rectangular window of, let's say for illumination, M + 1/2 periods of a sinusoid. I guess it doesn't matter if we sample it before or after windowing although if we sample it after windowing then the sample rate would be considered to be "too low" because of the sharp edges at the ends which suggests an issue with the boundary conditions. But, we accept the aliasing it causes by calling it something else: "spectral spreading" or "leakage". Is it true that spectral spreading, being continuous is somehow "more OK" than aliasing of a spectral line from one frequency to another? Seems like it, eh? And, how "ugly" is *that*? Depends on the eye of the beholder I guess. But, without the 1/2 period, the boundary conditions are smooth and there is no aliasing / spectral spreading. Fred
Reply by ●December 11, 20112011-12-11
On Dec 10, 1:50�pm, Fred Marshall <fmarshallxremove_th...@acm.org> wrote:> ... > So, we start with a rectangular window of, let's say for illumination, M > + 1/2 periods of a sinusoid. �I guess it doesn't matter if we sample it > before or after windowing although if we sample it after windowing then > the sample rate would be considered to be "too low" because of the sharp > edges at the ends which suggests an issue with the boundary conditions. > � But, we accept the aliasing it causes by calling it something else: > "spectral spreading" or "leakage". �Is it true that spectral spreading, > being continuous is somehow "more OK" than aliasing of a spectral line > from one frequency to another? �Seems like it, eh? �And, how "ugly" is > *that*? �Depends on the eye of the beholder I guess. > > But, without the 1/2 period, the boundary conditions are smooth and > there is no aliasing / spectral spreading. > > FredThere is spreading from windowing, but you can avoid looking at it. Any time you window you generate spectral spreading, even with a rectangular window and n-periodic boundary conditions. The convenience (or "beauty") of this case is that the projection of the N-periodic signals spread by the rectangular window is zero at the frequency samples calculated by the N point DFT except at the component frequency. The spectral spreading is non-zero elsewhere. The time domain windowing process convolves the FT of the window with the FT of the signal in the frequency domain. If you take N samples (that is the rectangular window) of a single N-periodic frequency component, the DFT calculates samples the delta function, the FT of the single component, convolved with the sync function that is the FT of the rectangular window. At the frequencies the N point DFT calculated samples, the windowed response is non-zero at only one sample. The zeros are due to the zeros of the sync function. If you sample the response at any other frequency, the projection is non-zero. An example of this can be calculated by zero extending the N time domain samples by N zeros and calculating the 2N point DFT. Alternate samples of the 2N point DFT output will be the samples calculated by the N point DFT of the original N samples and the rest of the points will be non-zero samples of the windowing-spread single frequency component at the frequencies half way between the frequency of samples calculated by the N point DFT. Dale B. Dalrymple
On 12/10/11 3:53 PM, dbd wrote:> On Dec 10, 10:23 am, robert bristow-johnson <rbj@audioimagination.com> wrote:...>> the DFT invertibly maps one discrete and periodic sequence of numbers to another discrete and periodic sequence of numbers of the same period. >> >> ... something that the periodicity deniers just don't seem to get. >> > > There are no "periodicity deniers". There are only those deniers who > know only a single small view of the world and from lack of > imagination would deny others the use of many other valid useful > world views.it's math, not something subjective nor political nor theological nor philosophical like "world views". equality signs are pretty much focused in their meaning and unforgiving. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
