Convex sets have become important in numerical optimization, so I'm trying to edjicate myself. Given some subset of points in a vector space, one must first determine its convex hull. For a set of points on a plane, this is easy to visualize However, I don't see how to write the code to accomplish this. Now suppose you have a set of vectors in a 6-D space. The convex hull would be a 5-D surface. What is the algorithm to determine this surface, for such a set? What is its complexity? Or, given a proposed surface, as the union of linear surfaces in n dimensions, how to determine if it constitutes the convex hull for some n+1 dimensional space? Then, given a point in that (n+1)-D space, how to determine if it lies within the volume enclosed by that convex hull? -- Rich
questions on convex hull
Started by ●March 24, 2015
Reply by ●March 24, 20152015-03-24
On Tue, 24 Mar 2015 14:07:54 -0700, RichD wrote:> Now suppose you have a set of vectors in a 6-D space. The > convex hull would be a 5-D surface. What is the algorithm > to determine this surface, for such a set? What is its complexity?Quickhull can be extended to any number of dimensions. It's O(n.log(n)) average-case, O(n^2) worst-case, where n is the number of points. Briefly: for an N-dimensional space, find the points with the minimum and maximum values in each dimension, i.e. those lying on the axis-aligned bounding hypercuboid. These points must be vertices of the convex hull. From these, choose N points to define a hyperplane. On each side, find the point farthest from the plane. Along with the original N points, this forms an N-dimensional simplex (triangle, tetrahedron, etc) having N+1 vertices. Any points inside the simplex cannot be vertices of the convex hull and are eliminated from future searches. For each face of the simplex (other than that formed by the initial plane), repeat the process until no points lie outside. The wikipedia page for Quickhull has an animation for the 2D case.> Or, given a proposed surface, as the union of linear surfaces > in n dimensions, how to determine if it constitutes the convex > hull for some n+1 dimensional space? Then, given a point in > that (n+1)-D space, how to determine if it lies within the volume > enclosed by that convex hull?Any convex polytope is the intersection of a set of linear half-spaces, each defined by a linear inequality c1.x1+c2.x2+... <= k. The surface is defined by convex polygons embedded in the corresponding hyperplanes c1.x1+c2.x2+... = k. The distance of the point <x1,x2,...> to the plane is (c1.x1+c2.x2+...-k)/sqrt(c1^2+c2^2+...). A point is inside the polytope if and only if it is inside all of the half-spaces, i.e. all of the inequalities hold.
