DSP Experts, I am analyzing a physiologic signal that has a varying fundamental frequency. To create a more accurate reconstruction from the FFT, I wish to include the bins immediately and symmetrically on either side of the fundamental bins. I refer to this as the "distribution method." I am confident I have been able to do a reconstruction using the fundamental bins (a standard reconstruction). I also performed a reconstruction for the distribution method. The mean squared error (comparing both reconstructions to data in the time domain) for the distribution method is lower than for the standard indicating the distribution method is potentially more accurate. However, the distribution reconstruction features an increase in difference between the maximums and minimums of each subsequent cycle. I have vigorously checked my Matlab code for potential errors in selecting components and performing operations; however, I have not been able to identify any. Hence, I am writing to request assistance in determining if this widening effect is an undesirable characteristic of the distribution method or whether there truly is an error in my code. I recognize that an FFT reconstruction should feature the exact same waveform for every cycle. I do not have a strong background in digital processing or signal analysis; however, I am eagerly learning on the fly. Thanks for any help you might be able to provide. -BMEngineer P.S. Plots and segments of my Matlab code are available to email as necessary. _____________________________ Posted through www.DSPRelated.com
Matlab FFT Reconstruction from Physiologic Frequency-Varying Signal
Started by ●March 30, 2015
Reply by ●March 31, 20152015-03-31
On Mon, 30 Mar 2015 16:53:34 -0500, "BMEngineer" <104668@dsprelated> wrote:>DSP Experts, > >I am analyzing a physiologic signal that has a varying fundamental >frequency. To create a more accurate reconstruction from the FFT, I wish to >include the bins immediately and symmetrically on either side of the >fundamental bins. I refer to this as the "distribution method." > >I am confident I have been able to do a reconstruction using the >fundamental bins (a standard reconstruction). I also performed a >reconstruction for the distribution method. The mean squared error >(comparing both reconstructions to data in the time domain) for the >distribution method is lower than for the standard indicating the >distribution method is potentially more accurate. However, the distribution >reconstruction features an increase in difference between the maximums and >minimums of each subsequent cycle. > >I have vigorously checked my Matlab code for potential errors in selecting >components and performing operations; however, I have not been able to >identify any. Hence, I am writing to request assistance in determining if >this widening effect is an undesirable characteristic of the distribution >method or whether there truly is an error in my code. I recognize that an >FFT reconstruction should feature the exact same waveform for every cycle. > > >I do not have a strong background in digital processing or signal analysis; >however, I am eagerly learning on the fly. > >Thanks for any help you might be able to provide. > >-BMEngineer > >P.S. Plots and segments of my Matlab code are available to email as >necessary.Any FFT bins other than those that you are using for the reconstruction that have non-zero magnitude would otherwise influence the reconstructed signal. Harmonics, especially, even with relatively low magnitudes, can have a significant influence on the amplitude of an output sine wave. When the fundamental is not centered on a bin it's DFT magnitude will naturally be lower than it would be if centered. The same is true for harmonics, so even if harmonic energy is not readily apparent in the DFT output there could easily be energy there that will affect the amplitude of your resconstructed signal. The bottom line is that you're using only a small part of the DFT information to reconstruct your output signal, so the loss of the rest of the information is reasonably expected to have an affect on your signal. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com
>On Mon, 30 Mar 2015 16:53:34 -0500, "BMEngineer" <104668@dsprelated> >wrote: > >>DSP Experts, >> >>I am analyzing a physiologic signal that has a varying fundamental >>frequency. To create a more accurate reconstruction from the FFT, I wishto>>include the bins immediately and symmetrically on either side of the >>fundamental bins. I refer to this as the "distribution method." >> >>I am confident I have been able to do a reconstruction using the >>fundamental bins (a standard reconstruction). I also performed a >>reconstruction for the distribution method. The mean squared error >>(comparing both reconstructions to data in the time domain) for the >>distribution method is lower than for the standard indicating the >>distribution method is potentially more accurate. However, thedistribution>>reconstruction features an increase in difference between the maximumsand>>minimums of each subsequent cycle. >> >>I have vigorously checked my Matlab code for potential errors inselecting>>components and performing operations; however, I have not been able to >>identify any. Hence, I am writing to request assistance in determiningif>>this widening effect is an undesirable characteristic of thedistribution>>method or whether there truly is an error in my code. I recognize thatan>>FFT reconstruction should feature the exact same waveform for everycycle.>> >> >>I do not have a strong background in digital processing or signalanalysis;>>however, I am eagerly learning on the fly. >> >>Thanks for any help you might be able to provide. >> >>-BMEngineer >> >>P.S. Plots and segments of my Matlab code are available to email as >>necessary. > >Any FFT bins other than those that you are using for the >reconstruction that have non-zero magnitude would otherwise influence >the reconstructed signal. Harmonics, especially, even with >relatively low magnitudes, can have a significant influence on the >amplitude of an output sine wave. > >When the fundamental is not centered on a bin it's DFT magnitude will >naturally be lower than it would be if centered. The same is true >for harmonics, so even if harmonic energy is not readily apparent in >the DFT output there could easily be energy there that will affect the >amplitude of your resconstructed signal. > >The bottom line is that you're using only a small part of the DFT >information to reconstruct your output signal, so the loss of the rest >of the information is reasonably expected to have an affect on your >signal. > >Eric Jacobsen >Anchor Hill Communications >http://www.anchorhill.com > >--- >This email has been checked for viruses by Avast antivirus software. >http://www.avast.comI understand the technicalities of your comments. They get at what I am trying to accomplish with the distribution method of reconstruction, which is to recover the spectral energy immediately adjacent to the harmonics, which is due to variability in the fundamental frequency. (The sampling frequency is sufficiently high such that aliasing is not an issue.) --------------------------------------- Posted through http://www.DSPRelated.com
>Any FFT bins other than those that you are using for the >reconstruction that have non-zero magnitude would otherwise influence >the reconstructed signal. Harmonics, especially, even with >relatively low magnitudes, can have a significant influence on the >amplitude of an output sine wave. > >When the fundamental is not centered on a bin it's DFT magnitude will >naturally be lower than it would be if centered. The same is true >for harmonics, so even if harmonic energy is not readily apparent in >the DFT output there could easily be energy there that will affect the >amplitude of your resconstructed signal. > >The bottom line is that you're using only a small part of the DFT >information to reconstruct your output signal, so the loss of the rest >of the information is reasonably expected to have an affect on your >signal. > >Eric Jacobsen >Anchor Hill Communications >http://www.anchorhill.com > >--- >This email has been checked for viruses by Avast antivirus software. >http://www.avast.comA further analysis of my distribution method reconstruction reveals that the generated waveform has lower frequency sine waves contributing to the undesirable distortions. --------------------------------------- Posted through http://www.DSPRelated.com
Reply by ●April 1, 20152015-04-01
The issue has been resolved. --------------------------------------- Posted through http://www.DSPRelated.com
