Ubuntu 64bit on an AMD C50 dual core The c program was initially compiled using dynamic linking and tested fine. I statically linked it with gcc a.c b.c -o myprogramEXE -static -lm and also by putting the full path the 3rd time. I also tested with ldd. When executing it dumps core on the same input conditions as with dynamic linking and on the same environment! Why - what is the fix?
Static library with -lm dumps core on run time
Started by ●March 31, 2015
Reply by ●March 31, 20152015-03-31
On Tuesday, March 31, 2015 at 2:03:22 PM UTC-7, wrote:> Ubuntu 64bit on an AMD C50 dual core > > The c program was initially compiled using dynamic linking and tested fine. > > I statically linked it with > gcc a.c b.c -o myprogramEXE -static -lm and also by putting the full path the 3rd time. > > I also tested with ldd. > > When executing it dumps core on the same input conditions as with dynamic linking and on the same environment! > > Why - what is the fix?Tried with the trace command: execve("./mypro", ["./mypro"], [/* 61 vars */]) = 0 uname({sys="Linux", node="Acer", ...}) = 0 brk(0) = 0x2668000 brk(0x26691c0) = 0x26691c0 arch_prctl(ARCH_SET_FS, 0x2668880) = 0 readlink("/proc/self/exe", "/home/owner/wfiles/V555", 4096) = 23 brk(0x268a1c0) = 0x268a1c0 brk(0x268b000) = 0x268b000 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) write(2, "Expecting two argume"..., 35Expecting two argument ) = 35 exit_group(1) = ? +++ exited with 1 +++
On Tuesday, March 31, 2015 at 2:03:22 PM UTC-7, speec...@gmail.com wrote:> Ubuntu 64bit on an AMD C50 dual core > > The c program was initially compiled using dynamic linking and tested fine. > > I statically linked it with > gcc a.c b.c -o myprogramEXE -static -lm and also by putting the full path the 3rd time. > > I also tested with ldd. > > When executing it dumps core on the same input conditions as with dynamic linking and on the same environment! > > Why - what is the fix?When tried with the trace command: execve("./mypro", ["./mypro"], [/* 61 vars */]) = 0 uname({sys="Linux", node="Acer", ...}) = 0 brk(0) = 0x2668000 brk(0x26691c0) = 0x26691c0 arch_prctl(ARCH_SET_FS, 0x2668880) = 0 readlink("/proc/self/exe", "/home/owner/wfiles/mypro", 4096) = 23 brk(0x268a1c0) = 0x268a1c0 brk(0x268b000) = 0x268b000 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) write(2, "Expecting two argume"..., 35Expecting two argument ) = 35 exit_group(1) = ? +++ exited with 1 +++
Reply by ●April 1, 20152015-04-01
I ran gdb and bactrace - the issue is possibly something to do with Linux and malloc. Part of the code was taken from Numerical Recipie in C (NRC) which used void *malloc(int); It was incompatible to Linux and in lieu of it, I added another include file. The segmentation fault occurs on this function from NRC: float *vector (nl,nh) int nl, nh; { float *v; v=(float *)malloc((unsigned) (nh-nl+1)*sizeof(float)); if (!v) nrerror("allocation failure in vector()"); return v-nl; } How can I fix the issue - why it happens when there is a static link on the same build environment?
I ran gdb and bactrace - the issue is possibly something to do with Linux and malloc. Part of the code was taken from Numerical Recipie in C (NRC) which used: void *malloc(int); It was incompatible to Linux and in lieu of it, I added another include file. The segmentation fault occurs on this function below from NRC, where it says free(): void free_vector(v,nl,nh) float *v; int nl, nh; /* Frees a float vector allocated by vector(). */ { free((char*) (v+nl)); } How can I fix the issue - why it happens when there is a static link on the same build environment?
On Wednesday, April 1, 2015 at 5:09:08 PM UTC-7, speec...@gmail.com wrote:> I ran gdb and bactrace - the issue is possibly something to do with Linux and malloc. Part of the code was taken from Numerical Recipie in C (NRC) which used: > > void *malloc(int); > > It was incompatible to Linux and in lieu of it, I added another include file. The segmentation fault occurs on this function below from NRC, where it says free(): > > void free_vector(v,nl,nh) > float *v; > int nl, nh; > /* Frees a float vector allocated by vector(). */ > { > free((char*) (v+nl)); > } > > How can I fix the issue - why it happens when there is a static link on the same build environment?The following function was used by NRC to create the vector: float *vector (nl,nh) int nl, nh; { float *v; v=(float *)malloc((unsigned) (nh-nl+1)*sizeof(float)); if (!v) nrerror("allocation failure in vector()"); return v-nl; }
Reply by ●April 2, 20152015-04-02
speech2020@gmail.com writes:> On Wednesday, April 1, 2015 at 5:09:08 PM UTC-7, speec...@gmail.com wrote: >> I ran gdb and bactrace - the issue is possibly something to do with Linux and malloc. Part of the code was taken from Numerical Recipie in C (NRC) which used: >> >> void *malloc(int); >> >> It was incompatible to Linux and in lieu of it, I added another include file. The segmentation fault occurs on this function below from NRC, where it says free(): >> >> void free_vector(v,nl,nh) >> float *v; >> int nl, nh; >> /* Frees a float vector allocated by vector(). */ >> { >> free((char*) (v+nl)); >> } >> >> How can I fix the issue - why it happens when there is a static link on the same build environment? > > The following function was used by NRC to create the vector: > > float *vector (nl,nh) > int nl, nh; > { > float *v; > > v=(float *)malloc((unsigned) (nh-nl+1)*sizeof(float)); > if (!v) nrerror("allocation failure in vector()"); > return v-nl; > }Have you considered social work? Perhaps sports? Seriously, a competent programmer would have had this solved in about 30 minutes (and that's with 4 Facebook posts while working on it). You've been at it for, what, weeks? -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
