On Tue, 19 May 2015 15:16:21 -0500, "sia4uin" <105263@DSPRelated> wrote:>So in the case of mobile device, where the y-axis is pointing ahead, >x-axis is pointing sideways and z-axis is pointing up, will this formula >work ...The axis orientation is appropriate, but trying to use your formula in the real world is extremely naive. It assumes that everything is perfect and free of disturbances. That only happens in homework problems.
Verification of the following formula
Started by ●May 19, 2015
Reply by ●May 20, 20152015-05-20
>On Tue, 19 May 2015 15:16:21 -0500, "sia4uin" <105263@DSPRelated> >wrote: > >>So in the case of mobile device, where the y-axis is pointing ahead, >>x-axis is pointing sideways and z-axis is pointing up, will this >formula >>work ... > >The axis orientation is appropriate, but trying to use your formula in >the real world is extremely naive. It assumes that everything is >perfect >and free of disturbances. That only happens in homework problems.Thanks Greg :) What would be the quickest way to determine pitch, is there any quick method which people use? Best Regards Sia --------------------------------------- Posted through http://www.DSPRelated.com
