On Wed, 20 May 2015 15:57:33 -0500, a.s. wrote:> The primary advantage of digital transmission over analog transmission > is Noise Immunity. A digital signal (in comparison to an analog signal) > is inherently more immune to noise. Why the word "inherent"? > > Please make it more clear to me.Sorta-kinda because as they're generally used, a digital signal has an excess of signal to noise for the information that's actually carried. The excess information is thrown away at detection along with much of the effect of noise. That's not a good description, but it's the best I can come up with at the moment. -- www.wescottdesign.com
How/Why a digital signal is inherently more immune to noise?
Started by ●May 20, 2015
Reply by ●May 21, 20152015-05-21
On Wednesday, May 20, 2015 at 4:57:36 PM UTC-4, a.s. wrote:> The primary advantage of digital transmission over analog transmission is > Noise Immunity. A digital signal (in comparison to an analog signal) is > inherently more immune to noise. Why the word "inherent"? > > Please make it more clear to me. > > > > --------------------------------------- > Posted through http://www.DSPRelated.comUnder a rather broad set of conditions, using digital communication to convey information allows you to play around with signaling, bandwidth, ECC, processing, etc. such that **for sufficiently high SNR** you can reproduce the input to that system at very high fidelity. Things get murkier when you start to go deeper into what fidelity means, introduce constraints in complexity, and most importantly on end-to-end delay. It's been known for a long time, due to Toby Berger, that for a Gaussian source and Gaussian channel under MMSE fidelity constraint, the best you can do is uncoded transmission. Google this up. Further work by Michael Gastpar expanded the set of sources, channels, fidelity constraints, such that this holds true. His PhD thesis was, "To Code or Not to Code." Back to earth and practical stuff, a lot of PHY today operate at very high rate, so the channel coding part isn't a big deal. But the source coding part is still tricky, in particular when you do two-way interactive communication. What's really valuable in using digital transmission (channel coding) is that you can design the signal to best fit the channel you are allowed to use. Noise immunity is often compromised for the sake of having good signal conditioning. The problem of noise immunity is often solved elsewhere, using rate adaptive source coding, ARQ, iterative processing, etc. So that statement is vague, in rare cases misleading, and not so insightful.
Tim Wescott <tim@seemywebsite.com> wrote:> On Wed, 20 May 2015 15:57:33 -0500, a.s. wrote:>> The primary advantage of digital transmission over analog transmission >> is Noise Immunity. A digital signal (in comparison to an analog signal) >> is inherently more immune to noise. Why the word "inherent"?> Sorta-kinda because as they're generally used, a digital signal has an > excess of signal to noise for the information that's actually carried. > The excess information is thrown away at detection along with much of the > effect of noise.OK, but that is because we have some convenient channels with appropriate excess bandwidth and noise characteristics.> That's not a good description, but it's the best I can come up with at > the moment.But the other reason is that the cost of digital electronics, per transistor, is so much less than for analog. If built using discrete transistors in little metal cans, none of what we do today would make sense. I was explainging Software (sic) Defined Radio to my (non engineer) brother, and he couldn't see why anyone would want to do that. Why make something so simple (analog radio) so complicated. I think most people don't realize how complicated things like CD players actually are, compared to analog audio. Even with integrated circuitry, analog electronics is nowhere near where digital electronics is. A 128GB USB drive, smaller than your thumb, has trillions of transistors. As far as I know, all the analog electronics ever made so far hasn't used a trillion transistors. Well, maybe close. -- glen
On Thu, 21 May 2015 15:08:03 +0000, glen herrmannsfeldt wrote:> Tim Wescott <tim@seemywebsite.com> wrote: >> On Wed, 20 May 2015 15:57:33 -0500, a.s. wrote: > >>> The primary advantage of digital transmission over analog transmission >>> is Noise Immunity. A digital signal (in comparison to an analog >>> signal) >>> is inherently more immune to noise. Why the word "inherent"? > >> Sorta-kinda because as they're generally used, a digital signal has an >> excess of signal to noise for the information that's actually carried. >> The excess information is thrown away at detection along with much of >> the effect of noise. > > OK, but that is because we have some convenient channels with > appropriate excess bandwidth and noise characteristics.True. Just as an observation, that applies to wideband FM radio, too, which is the only analog signal transmission scheme that I know of that has an input SNR to output SNR characteristic that resembles digital communications. Which makes one wonder if it's the only way, or if major Armstrong was just an absolutely unique freakin' genius.>> That's not a good description, but it's the best I can come up with at >> the moment. > > But the other reason is that the cost of digital electronics, per > transistor, is so much less than for analog. If built using discrete > transistors in little metal cans, none of what we do today would make > sense.Very little, at least. People were starting to use digital communications, because of the possibility for error correction and whatnot, even when computers were built using discrete transistors in little metal cans. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <seemywebsite@myfooter.really> wrote: (snip on digital vs. analog, and S/N)>> OK, but that is because we have some convenient channels with >> appropriate excess bandwidth and noise characteristics.> True. Just as an observation, that applies to wideband FM radio, too, > which is the only analog signal transmission scheme that I know of that > has an input SNR to output SNR characteristic that resembles digital > communications.Yes. I didn't mean to leave that out.> Which makes one wonder if it's the only way, or if major Armstrong was > just an absolutely unique freakin' genius.As well as I know the story, he must have been pretty close. I don't remember well by now, but I think he used one tube for both the oscillator and mixer. Seems detector, too: https://en.wikipedia.org/wiki/Regenerative_circuit>>> That's not a good description, but it's the best I can come up with at >>> the moment.>> But the other reason is that the cost of digital electronics, per >> transistor, is so much less than for analog. If built using discrete >> transistors in little metal cans, none of what we do today would make >> sense.> Very little, at least. People were starting to use digital > communications, because of the possibility for error correction and > whatnot, even when computers were built using discrete transistors in > little metal cans.Yes, but only for things like military, where they could afford it. It always seems to me that if you look back, things were always done earlier than they should have been. The Wright brothers got a working airplane knowing very little about aerodynamics. Philips developed the CD before semiconductor lasers had developed to the point that ordinary people could afford them. (I believe the early ones used HeNe lasers.) CDs store the track number in BCD (1 to 99) to save on the logic for the binary to BCD converter. -- glen
On 5/21/2015 11:08 AM, glen herrmannsfeldt wrote:> Tim Wescott <tim@seemywebsite.com> wrote: >> On Wed, 20 May 2015 15:57:33 -0500, a.s. wrote: > >>> The primary advantage of digital transmission over analog transmission >>> is Noise Immunity. A digital signal (in comparison to an analog signal) >>> is inherently more immune to noise. Why the word "inherent"? > >> Sorta-kinda because as they're generally used, a digital signal has an >> excess of signal to noise for the information that's actually carried. >> The excess information is thrown away at detection along with much of the >> effect of noise. > > OK, but that is because we have some convenient channels with > appropriate excess bandwidth and noise characteristics.The "excess" capacity often comes from the reduced requirements of digital signal transmission compared to analog. A TV signal, for example, uses less bandwidth once the image is compressed digitally or a much higher resolution digital image can be conveyed over the same channel.>> That's not a good description, but it's the best I can come up with at >> the moment. > > But the other reason is that the cost of digital electronics, per > transistor, is so much less than for analog. If built using discrete > transistors in little metal cans, none of what we do today would > make sense. > > I was explainging Software (sic) Defined Radio to my (non engineer) > brother, and he couldn't see why anyone would want to do that. > Why make something so simple (analog radio) so complicated. > > I think most people don't realize how complicated things like CD > players actually are, compared to analog audio.But that complexity is relatively easy to manage compared to the problems analog circuits present.> Even with integrated circuitry, analog electronics is nowhere near > where digital electronics is. > > A 128GB USB drive, smaller than your thumb, has trillions of > transistors. As far as I know, all the analog electronics ever made > so far hasn't used a trillion transistors. Well, maybe close.And that difference is exactly why the huge complexity of digital devices can be practical and even preferable. -- Rick
Tim Wescott wrote:> On Thu, 21 May 2015 15:08:03 +0000, glen herrmannsfeldt wrote: > >> Tim Wescott <tim@seemywebsite.com> wrote: >>> On Wed, 20 May 2015 15:57:33 -0500, a.s. wrote: >> >>>> The primary advantage of digital transmission over analog transmission >>>> is Noise Immunity. A digital signal (in comparison to an analog >>>> signal) >>>> is inherently more immune to noise. Why the word "inherent"? >> >>> Sorta-kinda because as they're generally used, a digital signal has an >>> excess of signal to noise for the information that's actually carried. >>> The excess information is thrown away at detection along with much of >>> the effect of noise. >> >> OK, but that is because we have some convenient channels with >> appropriate excess bandwidth and noise characteristics. > > True. Just as an observation, that applies to wideband FM radio, too, > which is the only analog signal transmission scheme that I know of that > has an input SNR to output SNR characteristic that resembles digital > communications. > > Which makes one wonder if it's the only way, or if major Armstrong was > just an absolutely unique freakin' genius. > >>> That's not a good description, but it's the best I can come up with at >>> the moment. >> >> But the other reason is that the cost of digital electronics, per >> transistor, is so much less than for analog. If built using discrete >> transistors in little metal cans, none of what we do today would make >> sense. > > Very little, at least. People were starting to use digital > communications, because of the possibility for error correction and > whatnot, even when computers were built using discrete transistors in > little metal cans. >Telegraphy seems a lot digital. -- Les Cargill
Reply by ●May 22, 20152015-05-22
a.s. wrote:> The primary advantage of digital transmission over analog transmission is > Noise Immunity. A digital signal (in comparison to an analog signal) is > inherently more immune to noise. Why the word "inherent"? > > Please make it more clear to me. >I see an unwarranted assumption that "Noise Immunity"/"SNR"/whatever has perfect correlation with "channel quality". CAVEAT LECTOR - note liberal use of quotation marks. In my living room I have a daily demonstration that digital does not always outperform analog. It's my TV reception. In the bad old analog days I could always get a useful signal on all the local channels. Now I get acceptable reception for _all_ channels only under certain atmospheric conditions. Yepp, there's some peculiar degenerate local conditions including rabbit ears at or near average terrain on path to transmitters (I'm on down slope of general terrain and there is a 20+ foot high ridge 2 blocks away). In analog days I could see very prominent ghosts. All the discussion in this thread assumes the noise is random. The "noise" I deal with is inherently coherent.
On 5/21/2015 11:14 PM, Richard Owlett wrote:> a.s. wrote: >> The primary advantage of digital transmission over analog transmission is >> Noise Immunity. A digital signal (in comparison to an analog signal) is >> inherently more immune to noise. Why the word "inherent"? >> >> Please make it more clear to me. >> > > I see an unwarranted assumption that "Noise Immunity"/"SNR"/whatever has > perfect correlation with "channel quality". CAVEAT LECTOR - note liberal > use of quotation marks. > > In my living room I have a daily demonstration that digital does not > always outperform analog. It's my TV reception. > > In the bad old analog days I could always get a useful signal on all the > local channels. > Now I get acceptable reception for _all_ channels only under certain > atmospheric conditions. > > Yepp, there's some peculiar degenerate local conditions including rabbit > ears at or near average terrain on path to transmitters (I'm on down > slope of general terrain and there is a 20+ foot high ridge 2 blocks > away). In analog days I could see very prominent ghosts. > > All the discussion in this thread assumes the noise is random. The > "noise" I deal with is inherently coherent.You aren't comparing apples and oranges. The digital transmission is capable of providing either a much higher resolution image than the analog signal did or providing multiple channels. If the extra channel capacity were used for increased error recovery I expect the digital signal would be adequate under a much wider range of conditions. -- Rick
