On Sun, 31 May 2015 14:08:24 -0400, rickman <gnuarm@gmail.com> wrote:>On 5/31/2015 2:02 PM, Cedron wrote: >> [...snip...] >> >>> >>> BTW, why would you use the abbreviation ARMA, even in this group, >>> without explanation? I bet I'm not the only one who had to look it up. >>> >>> >>>> Just my dos centavos. >>> >>> Thanks, now I can have that operation I've been needing... >>> >>> -- >>> >>> Rick >> >> I had to look it up, too. I wouldn't have had to if you had copy and >> pasted the answer when you did. >> >> ARMA = Autoregressive-moving-average > >I'm glad that was enough for you. The name didn't mean anything to me >until I read a bit about it. A fairly complex topic really. Nothing >like a simple moving average. Not sure why Eric even brought it up.ARMA filters are a DSP topic that was hot-ish maybe a couple of decades ago. It is a fairly straightforward and contextually relevant example of the use of the term Moving Average to mean something other than a boxcar, which was a sort-of-joking response to Randy stating that boxcar and moving average are the same thing. It is just another example of how people can sometimes get hung up on semantic issues due to terms that are overloaded. Can make for fun discussions. Not sure why that was complicated. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Filters for frequency inputs
Started by ●May 29, 2015
Reply by ●May 31, 20152015-05-31
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:> Plus there's the whole ARMA thing, so it's been used in > the lit for a long time to mean something other than a boxcar.Does anybody but Mathworks call a lattice filter an "ARMA"? Steve
rickman <gnuarm@gmail.com> wrote:>On 5/31/2015 2:02 PM, Cedron wrote:>> ARMA = Autoregressive-moving-average>I'm glad that was enough for you. The name didn't mean anything to me >until I read a bit about it. A fairly complex topic really. Nothing >like a simple moving average. Not sure why Eric even brought it up.I think, to point out that moving averages are not necessarily rectangular, in at least some peoples' terminlogy. True, but IMO it's a misnomer in cases such as "ARMA". (e.g. why not call direct-forms I and II moving averages also? They are all topologies of the same filter.) Steve
Cedron <103185@DSPRelated> wrote:>>> ARMA = Autoregressive-moving-average>It was enough to answer what the acronym stood for. I glanced at the >article, it did look fairly complicated. I won't speculate on Eric's >motivation, he would have to answer that.We actually had a discussion here once about the so-called ARMA filter and whether it is or is not complicated. I have used this filter topology many times, beginning when I was a grad student and working on speech analysis/synthesis, where it is (or was) popularly used. Some filter designers have never had ocassion to use it. I believe it to have good precision properties but there was no consensus formed in the discussion. i.e. situation normal. Steve
Reply by ●June 1, 20152015-06-01
Les Cargill <lcargill99@comcast.com> writes:> Randy Yates wrote: >> Les Cargill <lcargill99@comcast.com> writes: >> >>> Randy Yates wrote: >>>> Les Cargill <lcargill99@comcast.com> writes: >>>>> [...] >>>>> Tim Wescott wrote: >>>>>> Note that what I gave you was a 2-tap boxcar with a pole at z = 0; >>>>> >>>>> Yeah, it compares quite closely with a classic moving average. >>>> >>>> Boxcar, moving average - same damn thing. >>>> >>> >>> >>> Very similar - but not exactly the same. >> >> Les, >> >> What difference do you think exists? >> > > Huh. Are they mathematically equivalent?Hi Les, I would say a discrete-time N-sample moving average filter has z-transform H_ma(z) = (1 / N) * sum_{n = 0}^{N-1} z^{-n}, while an N-sample boxcar filter has z-transform H_bc(z) = A * sum_{n = 0}^{N-1} z^{-n} So yes, except for possibly the scaling factor A. I don't know why you brought Butterworth into it - those are IIR, while these are FIR. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
