On 30.7.15 17:30, Steve Pope wrote:> Bob Masta <NoSpam@daqarta.com> wrote: > >> Dunno if anyone uses PDNs any more; they were parallel >> chains of all-pass stages, with staggered TCs such that the >> *difference* between the outputs of the two chains >> approximated 90 degrees over the frequency range of >> interest. Lots of fun sorting and measuring Rs and Cs to >> get the target tuning... ahh, the "good old days"! > > I believe there's a National datasheet on designing them ... > if you use 1% resistors and 2% capacitors you're probably okay. > > Steve >It is standard material in ham radio books about SSB. There are several different ways to skin this cat. -- -TV
Automatic (no user-parameters) envelope/peak follower
Started by ●July 27, 2015
Reply by ●July 30, 20152015-07-30
Tauno Voipio <tauno.voipio@notused.fi.invalid> wrote:>On 30.7.15 17:30, Steve Pope wrote:>> Bob Masta <NoSpam@daqarta.com> wrote:>>> Dunno if anyone uses PDNs any more; they were parallel >>> chains of all-pass stages, with staggered TCs such that the >>> *difference* between the outputs of the two chains >>> approximated 90 degrees over the frequency range of >>> interest. Lots of fun sorting and measuring Rs and Cs to >>> get the target tuning... ahh, the "good old days"!>> I believe there's a National datasheet on designing them ... >> if you use 1% resistors and 2% capacitors you're probably okay.>It is standard material in ham radio books about SSB. There are >several different ways to skin this cat.Yes, the phase method for SSB used the same transfer functions ... but those tended to be LC filters, and not active (op-amp) RC filters. Lots of ways to do it. Steve
On 30.7.15 20:40, Steve Pope wrote:> Tauno Voipio <tauno.voipio@notused.fi.invalid> wrote: > >> On 30.7.15 17:30, Steve Pope wrote: > >>> Bob Masta <NoSpam@daqarta.com> wrote: > >>>> Dunno if anyone uses PDNs any more; they were parallel >>>> chains of all-pass stages, with staggered TCs such that the >>>> *difference* between the outputs of the two chains >>>> approximated 90 degrees over the frequency range of >>>> interest. Lots of fun sorting and measuring Rs and Cs to >>>> get the target tuning... ahh, the "good old days"! > >>> I believe there's a National datasheet on designing them ... >>> if you use 1% resistors and 2% capacitors you're probably okay. > >> It is standard material in ham radio books about SSB. There are >> several different ways to skin this cat. > > Yes, the phase method for SSB used the same transfer functions ... > but those tended to be LC filters, and not active (op-amp) > RC filters. > > Lots of ways to do it. > > SteveNot quite - the networks have been RC, at least for my entire ham career (since 1960). An example of the old times' devices was the Barker & Williamson 2Q4, packed inside an octal based tube format. -- Tauno Voipio (OH2UG)
