> Not exactly. Randy's code converts MSB to a 16 bit quantity first, then > shifts. Mauritiz's code shifts then type casts as a 16 bit quantity. > If MSB is an 8 bit quantity shifting before converting type will lose > all the data giving a zero value. > > -- > > RickYou are right Rick. What I meant to do is this: double x = (((((int16_t)MSB) << 8) | LSB) >> 2) / 4096.0;
Datasheet Question
Started by ●August 26, 2015
Reply by ●August 28, 20152015-08-28
rickman <gnuarm@gmail.com> writes:> On 8/27/2015 11:59 PM, Randy Yates wrote: >> Mauritz Jameson <mjames2393@gmail.com> writes: >> >>>> This is not right either - the MSB won't be sign-extended. But I think >>>> this would work: >>>> >>>> double x = ((((int16_t)MSB << 8) | LSB) >> 2) / 4096.0; >>>> >>> >>> >>> Exactly! You have to shift 8 up to ensure sign extension when you >>> later shift down by 2. So I guess you agree with me Randy :-) >> >> Yes, I do. > > Not exactly. Randy's code converts MSB to a 16 bit quantity first, > then shifts. Mauritiz's code shifts then type casts as a 16 bit > quantity. If MSB is an 8 bit quantity shifting before converting type > will lose all the data giving a zero value.Rick, Yeah, I forgot I did that, and I hadn't thought through the consequences of MSB being an 8-bit quantity. Good points. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Reply by ●August 29, 20152015-08-29
I do have one follow-up question. Since the acquired data is a vector (x,y,z) I don't understand why it has to be Q2.12. Why not just provide a normalized unit vector (length always 1) where each co-ordinate is in Q1.13 format for the direction? Example: Provide (-1,0,0) instead of (-2,0,0)
Mauritz Jameson <mjames2393@gmail.com> wrote:>I do have one follow-up question. > >Since the acquired data is a vector (x,y,z) I don't understand why it >has to be Q2.12.It doesn't. Only use Q notation if your boss has ordered you to do so, if anyone else starts quacking about Q notation tell them to go frub a duck. (There, got that off my chest.) S.
> It doesn't. Only use Q notation if your boss has ordered you to > do so, if anyone else starts quacking about Q notation tell > them to go frub a duck. > > > (There, got that off my chest.)Ok :-) So why is the Freescale PDF quacking that the data should be interpreted as a Q2.12 number? Since we're talking about directional vectors there's no additional information in - for example - (-2,0,0) versus (-1,0,0) I'm sure I'm missing something here...so I'm hoping that somebody in this group can offer some insight to this?
Reply by ●August 30, 20152015-08-30
Mauritz Jameson <mjames2393@gmail.com> wrote:>> It doesn't. Only use Q notation if your boss has ordered you to >> do so, if anyone else starts quacking about Q notation tell >> them to go frub a duck.>> (There, got that off my chest.)>Ok :-)>So why is the Freescale PDF quacking that the data should be interpreted >as a Q2.12 number?>Since we're talking about directional vectors there's no additional >information in - for example - (-2,0,0) versus (-1,0,0)It seems this datasheet is saying that the accelerometer is measuring in units of G's, and that there are modes which set the end-to-end range of the measurement (2G's, 4G's, or 8G's) and so in fact the binary point is physical and not purely conceptual. So in the 4G range case there really are two bits to the left of the binary poiint. And they also seem to consider rounding to a decimal number to be of value (it looks like, so one can report in milli-G's. Steve
On 8/30/2015 12:15 AM, Steve Pope wrote:> Mauritz Jameson <mjames2393@gmail.com> wrote: > >>> It doesn't. Only use Q notation if your boss has ordered you to >>> do so, if anyone else starts quacking about Q notation tell >>> them to go frub a duck. > >>> (There, got that off my chest.) > >> Ok :-) > >> So why is the Freescale PDF quacking that the data should be interpreted >> as a Q2.12 number? > >> Since we're talking about directional vectors there's no additional >> information in - for example - (-2,0,0) versus (-1,0,0) > > It seems this datasheet is saying that the accelerometer is measuring > in units of G's, and that there are modes which set the end-to-end range > of the measurement (2G's, 4G's, or 8G's) and so in fact the binary > point is physical and not purely conceptual. > > So in the 4G range case there really are two bits to the left of the > binary poiint. And they also seem to consider rounding to a decimal > number to be of value (it looks like, so one can report in > milli-G's.What he said... -- Rick
