So from what I searched in the net, DTFT is the continuous Fourier transform of a discrete (or quantized?) signal while DFT is the discrete Fourier transform of the quantized signal. Meaning DFT is used in actual Systems since it gives out data which can be processed by computer. If that is the case, what is DTFT for? Is it used in actual systems or just used for mathematical proving and analysis? --------------------------------------- Posted through http://www.DSPRelated.com
Discrete -Time Fourier Transform
Started by ●August 27, 2015
Reply by ●August 28, 20152015-08-28
"Shadow Flux" <108168@DSPRelated> writes:> So from what I searched in the net, DTFT is the continuous Fourier > transform of a discrete (or quantized?) signal while DFT is the discrete > Fourier transform of the quantized signal. Meaning DFT is used in actual > Systems since it gives out data which can be processed by computer. If > that is the case, what is DTFT for? Is it used in actual systems or just > used for mathematical proving and analysis?You're spot on, Shadow - just for analysis. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
