On 10/1/2015 5:59 PM, Tim Wescott wrote:> On Thu, 01 Oct 2015 16:36:57 -0400, rickman wrote: > >> On 10/1/2015 4:27 PM, Tim Wescott wrote: >>> On Thu, 01 Oct 2015 15:52:09 -0400, rickman wrote: >>> >>>> On 10/1/2015 2:08 PM, Tim Wescott wrote: >>>>> On Thu, 01 Oct 2015 08:11:38 -0500, garengllc wrote: >>>>> >>>>>> All, thank you so much for all the feedback and explanations, I >>>>>> appreciate it! >>>>>> >>>>>> I've read through everything once, but I think I need to go through >>>>>> it a couple more times to make sure I am following everyone's >>>>>> points/counterpoints. >>>>>> >>>>>> Some quick answers (so that you know that I didn't disappear into >>>>>> the ether) is that I do need the output of rolling_average on every >>>>>> clock (probably why the original C coder called it a rolling average >>>>>> even though it isn't exactly acting like it). >>>>> >>>>> As Rick pointed out, "Cumulative moving average" is probably a better >>>>> name to use, if for no other reason than that's the name that >>>>> everyone else uses. >>>>> >>>>>> The rolling_average_num_max is an odd value to me. It is a constant >>>>>> variable that will not change once the FPGA is built. What it looks >>>>>> like to me is that rolling_average_num keeps track of the depth of >>>>>> window average from [0,rolling_average_num_max]. So even in the >>>>>> beginning when the average only has a few values in it, it will >>>>>> compute the average based on that. Once the system has been running >>>>>> for a while, rolling_average_num will always be equal to >>>>>> rolling_average_num_max, and that variable in the averaging equation >>>>>> will be a constant. That make sense? >>>>> >>>>> Yes it does. The "pure" cumulative moving average would be optimal >>>>> to estimate a value that never changes, but would eventually run into >>>>> word- >>>>> width limitations. Capping the divisor by a maximum will both help >>>>> with the word-width limitations, and will allow the algorithm to >>>>> follow a slowly moving (with respect to the sample rate) value. >>>> >>>> I'm not following what you mean by "capping". The OP sounds like he >>>> wants to use the max value in the calculations instead of the current >>>> value of the sample count. I don't see how that can produce anything >>>> useful. In fact, at that point it has become a low pass IIR filter. >>>> >>>> By "capping" do you mean to reset the count and sum and start a new >>>> average calculation? >>> >>> https://en.wiktionary.org/wiki/cap#Verb, definition 5. Sorry if I'm >>> being too obscure. >> >> Let *me* be clear on this. If you set an upper limit to just the >> divisor, you will have a corrupt calculation with a value that rises >> above the average. In other words you will have created an integrator, >> not a filter or an average. > > No. Review your math. If you use any variation of the OP's code you'll > start with a cumulative running average, and end up with a plain old 1st- > order IIR lowpass.Which is not what was spec'd. Your math or your description is not correct. But since you won't explain it I can't say which.>> Is that what you are proposing? If I misunderstand, perhaps it would be >> better if you were more explicit. > > "Cap" = "set maximum limit", just like both the dictionary definition and > the OP's post. I'm sorry that I confused things by using a different > word. > > When I talked about "capping" I meant using exactly the algorithm as the > OP described in C: you do all the math with his divisor variable, but you > only allow the divisor equal the actual count up to the maximum value > (i.e., the cap, because to most native English speakers "cap" and > "maximum value" can easily mean the same thing), after which the divisor > is held to the maximum value.You know what you think you are saying, but that isn't what you *are* saying. The divisor is just the divisor. I think you mean the sample count variable, which is not what you said.> By just about ever variation of the equation that he posted, the filter > starts out as a cumulative running average, and then transitions to a > simple linear IIR lowpass.??? Ok, we have reached a point of non-productivity. Enjoy. -- Rick
How to simplify a rolling average in an FPGA
Started by ●September 30, 2015
Reply by ●October 1, 20152015-10-01
