eric.jacobsen@ieee.org (Eric Jacobsen) writes:> On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates > <yates@digitalsignallabs.com> wrote: > >>"tarikkazaz" <50642@DSPRelated> writes: >> >>> Hi all, >>> >>> I am working on implementation of zigbee device on FPGA. Till now I have >>> made Tx which is compatible with commercial devices. Also I have Rx which >>> is working with my own Tx, but does not work with commercial devices. >>> Major reason why my receiver can not decode signals from commercial >>> devices is frequency offset. So far I tried to apply zero crossing >>> approach to decode signal, but that does not help >>> (http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=1615158&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D1615158). >>> Previously I have been doing correlation of known chips with received >>> signal (on that way I was able to decode signals from my own Tx). >>> >>> Because now I am planning to start with implementation of frequency offset >>> compensation for my receiver, I would like to get advice. Which estimator >>> do you suggest me to use? Or maybe I could use some simplified method, as >>> zigbee has known preamble of 256 chips, which is 128 chips in I branch, >>> and 128 chips in Q branch. Sampling rate of my ADC is 64Msps, and I was >>> doing down sapling to 4Msps. >> >>Hi, >> >>MSK is FM, right? > > No, MSK is not FM. It is essentially OQPSK with crappy filtering.PS: You are correct that it can be viewed as OQPSK with a sinusoidal pulse-shape. See section 2.1.3 here: http://www.digitalsignallabs.com/hw.pdf -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Frequency offset compensation for 802.15.4 (ZigBee-MSK)
Started by ●October 2, 2015
Reply by ●October 3, 20152015-10-03
>eric.jacobsen@ieee.org (Eric Jacobsen) writes: > >> On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates >> <yates@digitalsignallabs.com> wrote: >> >>>"tarikkazaz" <50642@DSPRelated> writes: >>> >>>> Hi all, >>>> >>>> I am working on implementation of zigbee device on FPGA. Till now I >have >>>> made Tx which is compatible with commercial devices. Also I have Rx >which >>>> is working with my own Tx, but does not work with commercialdevices.>>>> Major reason why my receiver can not decode signals from commercial >>>> devices is frequency offset. So far I tried to apply zero crossing >>>> approach to decode signal, but that does not help >>>> >(http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber15158&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D1615158). >>>> Previously I have been doing correlation of known chips withreceived>>>> signal (on that way I was able to decode signals from my own Tx). >>>> >>>> Because now I am planning to start with implementation of frequency >offset >>>> compensation for my receiver, I would like to get advice. Which >estimator >>>> do you suggest me to use? Or maybe I could use some simplifiedmethod,>as >>>> zigbee has known preamble of 256 chips, which is 128 chips in Ibranch,>>>> and 128 chips in Q branch. Sampling rate of my ADC is 64Msps, and Iwas>>>> doing down sapling to 4Msps. >>> >>>Hi, >>> >>>MSK is FM, right? >> >> No, MSK is not FM. > >I don't believe this is correct, Eric. MSK is a special limiting case of >FSK (the minimum frequency separation of FSK), and FSK is >frequency-shift keying, which is a form of FM. Thus by transitive logic, >MSK is a form of FM. > >If this is not correct, point out my error. >-- >Randy Yates >Digital Signal Labs >http://www.digitalsignallabs.comI think either way is correct. It is matter of perspective. We better focus on clock recovery and frequency offset solutions. Kaz --------------------------------------- Posted through http://www.DSPRelated.com
"kaz" <37480@DSPRelated> writes:>>eric.jacobsen@ieee.org (Eric Jacobsen) writes: >> >>> On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates >>> <yates@digitalsignallabs.com> wrote: >>> >>>>"tarikkazaz" <50642@DSPRelated> writes: >>>> >>>>> Hi all, >>>>> >>>>> I am working on implementation of zigbee device on FPGA. Till now I >>have >>>>> made Tx which is compatible with commercial devices. Also I have Rx >>which >>>>> is working with my own Tx, but does not work with commercial > devices. >>>>> Major reason why my receiver can not decode signals from commercial >>>>> devices is frequency offset. So far I tried to apply zero crossing >>>>> approach to decode signal, but that does not help >>>>> >>(http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber15158&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D1615158). >>>>> Previously I have been doing correlation of known chips with > received >>>>> signal (on that way I was able to decode signals from my own Tx). >>>>> >>>>> Because now I am planning to start with implementation of frequency >>offset >>>>> compensation for my receiver, I would like to get advice. Which >>estimator >>>>> do you suggest me to use? Or maybe I could use some simplified > method, >>as >>>>> zigbee has known preamble of 256 chips, which is 128 chips in I > branch, >>>>> and 128 chips in Q branch. Sampling rate of my ADC is 64Msps, and I > was >>>>> doing down sapling to 4Msps. >>>> >>>>Hi, >>>> >>>>MSK is FM, right? >>> >>> No, MSK is not FM. >> >>I don't believe this is correct, Eric. MSK is a special limiting case of >>FSK (the minimum frequency separation of FSK), and FSK is >>frequency-shift keying, which is a form of FM. Thus by transitive logic, >>MSK is a form of FM. >> >>If this is not correct, point out my error. >>-- >>Randy Yates >>Digital Signal Labs >>http://www.digitalsignallabs.com > > I think either way is correct. It is matter of perspective. We better > focus on clock recovery and frequency offset solutions.The OP didn't ask for timing, just frequency offset, hence my suggestion. But I agree with your general sentiment, Kaz. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
>eric.jacobsen@ieee.org (Eric Jacobsen) writes: > >> On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates >> <yates@digitalsignallabs.com> wrote: >> >>>"tarikkazaz" <50642@DSPRelated> writes: >>> >>>> Hi all, >>>> >>>> I am working on implementation of zigbee device on FPGA. Till now I >have >>>> made Tx which is compatible with commercial devices. Also I have Rx >which >>>> is working with my own Tx, but does not work with commercialdevices.>>>> Major reason why my receiver can not decode signals from commercial >>>> devices is frequency offset. So far I tried to apply zero crossing >>>> approach to decode signal, but that does not help >>>> >(http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber15158&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D1615158). >>>> Previously I have been doing correlation of known chips withreceived>>>> signal (on that way I was able to decode signals from my own Tx). >>>> >>>> Because now I am planning to start with implementation of frequency >offset >>>> compensation for my receiver, I would like to get advice. Which >estimator >>>> do you suggest me to use? Or maybe I could use some simplifiedmethod,>as >>>> zigbee has known preamble of 256 chips, which is 128 chips in Ibranch,>>>> and 128 chips in Q branch. Sampling rate of my ADC is 64Msps, and Iwas>>>> doing down sapling to 4Msps. >>> >>>Hi, >>> >>>MSK is FM, right? >> >> No, MSK is not FM. > >I don't believe this is correct, Eric. MSK is a special limiting case of >FSK (the minimum frequency separation of FSK), and FSK is >frequency-shift keying, which is a form of FM. Thus by transitive logic, >MSK is a form of FM. > >If this is not correct, point out my error. >-- >Randy Yates >Digital Signal Labs >http://www.digitalsignallabs.comHi Randy, MSK can be interpreted as FM, and based on papers can be demodulated with FM demodulator. For example gnuradio implementation is using FM demodulator in RX chain of zigbee receiver. http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.179.31&rep=rep1&type=pdf --------------------------------------- Posted through http://www.DSPRelated.com
On Sat, 03 Oct 2015 12:28:42 -0400, Randy Yates <yates@digitalsignallabs.com> wrote:>eric.jacobsen@ieee.org (Eric Jacobsen) writes: > >> On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates >> <yates@digitalsignallabs.com> wrote: >> >>>"tarikkazaz" <50642@DSPRelated> writes: >>> >>>> Hi all, >>>> >>>> I am working on implementation of zigbee device on FPGA. Till now I have >>>> made Tx which is compatible with commercial devices. Also I have Rx which >>>> is working with my own Tx, but does not work with commercial devices. >>>> Major reason why my receiver can not decode signals from commercial >>>> devices is frequency offset. So far I tried to apply zero crossing >>>> approach to decode signal, but that does not help >>>> (http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=1615158&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D1615158). >>>> Previously I have been doing correlation of known chips with received >>>> signal (on that way I was able to decode signals from my own Tx). >>>> >>>> Because now I am planning to start with implementation of frequency offset >>>> compensation for my receiver, I would like to get advice. Which estimator >>>> do you suggest me to use? Or maybe I could use some simplified method, as >>>> zigbee has known preamble of 256 chips, which is 128 chips in I branch, >>>> and 128 chips in Q branch. Sampling rate of my ADC is 64Msps, and I was >>>> doing down sapling to 4Msps. >>> >>>Hi, >>> >>>MSK is FM, right? >> >> No, MSK is not FM. > >I don't believe this is correct, Eric. MSK is a special limiting case of >FSK (the minimum frequency separation of FSK), and FSK is >frequency-shift keying, which is a form of FM. Thus by transitive logic, >MSK is a form of FM. > >If this is not correct, point out my error.It's right from that perspective, but using an FM demodulator to receive MSK is highly suboptimal. Emphasis on highly. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:>On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates>>MSK is FM, right?>No, MSK is not FM. It is essentially OQPSK with crappy filtering.Interesting perspective. MSK is a subcategory of FSK which is a subcategory of FM. 2-MSK is equivalent to "OQPSK", but "OQPSK" is simply language that appears in some standards documents and the fact that they are equivalent is more of a construction than anything else. "OQPSK" terminology has since back-filtered into some modern textbooks. n-MSK for n > 2 is not equivalent to OQPSK. MSK, unqualified, might refer to the modulation without any filtering, or might refer to the modulation without reference to the filtering that has been applied. Gaussian filtering (e.g. GMSK) is very common (and is not particularly bad). I would usually say that GMSK is a subcategory of MSK. But that can get into arguments of the form, "That's not MSK, it's GMSK" ... these tend to be content-free arguments. Steve
On Sat, 3 Oct 2015 18:36:53 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >>On Sat, 03 Oct 2015 07:54:15 -0400, Randy Yates > >>>MSK is FM, right? > >>No, MSK is not FM. It is essentially OQPSK with crappy filtering. > >Interesting perspective. > >MSK is a subcategory of FSK which is a subcategory of FM. > >2-MSK is equivalent to "OQPSK", but "OQPSK" is simply language that >appears in some standards documents and the fact that they are >equivalent is more of a construction than anything else. "OQPSK" >terminology has since back-filtered into some modern textbooks.OQPSK is QPSK with either the I or Q channel shifted in time by 1/2 symbol. I'm not sure what you mean by "construction", but it's been around for a long time, is part of many standards going back a long, long time, and is very often implemented just as I described: a half-symbol shift in the modulator or demodulator. It reduces the PAPR of QPSK significantly, and avoids transitions through the origin, without giving up any of the performance or spectral properties of QPSK. It also limits spectral regrowth (compared to QPSK) when hitting the PA hard. This was significant back in the days when PAs weren't as linear or efficient as they are now, and when channel filtering wasn't as tight but channels were. If you degrade the filtering from a typical Nyquist matched-filter to a half-sine per symbol, you get MSK. If you demodulate MSK as though it was OQPSK with crappy filtering, it does a pretty good job. Better than many other methods.>n-MSK for n > 2 is not equivalent to OQPSK.Just like n-PSK isnt equal to QPSK for n>2.>MSK, unqualified, might refer to the modulation without any filtering, >or might refer to the modulation without reference to the filtering >that has been applied. Gaussian filtering (e.g. GMSK) is very common >(and is not particularly bad).MSK is named so because it is, as Randy stated, the limiting case of smooshing 2-FSK down to minimum shifts. The optimal receiver is not an FSK or FM receiver, though. GMSK makes it a partial response system and tries to further control the spectral regrowth when transmitted through a limiting amplifier.>I would usually say that GMSK is a subcategory of MSK. But that >can get into arguments of the form, "That's not MSK, it's GMSK" ... >these tend to be content-free arguments. > >SteveIt's MSK with even crappier filtering. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:>On Sat, 03 Oct 2015 12:28:42 -0400, Randy Yates>>I don't believe this is correct, Eric. MSK is a special limiting case of >>FSK (the minimum frequency separation of FSK), and FSK is >>frequency-shift keying, which is a form of FM. Thus by transitive logic, >>MSK is a form of FM.>>If this is not correct, point out my error.>It's right from that perspective, but using an FM demodulator to >receive MSK is highly suboptimal. Emphasis on highly.Certainly suboptimal. Depending on parameters, you can count on about a 2 dB loss if one uses a frequency discriminator to demodulate 2MSK, compared to maximum-likelyhood. The loss is worse for coded modulation. 802.15, Bluetooth, and the like have a lot of uncoded modulation modes and using a frequency discrminator in the receiver is commonly done for simplicity and low-power. Whereas something like GSM, where the demodulation, decoding and equalization (and maybe even doppler correction) are co-designed, you would not use a simple frequency discriminator for detection. The OP stated he's using a zero-crossing demodulator, which is evem more simplistic than a frequency discriminator, yet the OP stated this is satisfactory. (Whether it remains satisfactory as they get deeper into their design is TBD.) I've "inherited" zero-crossing-detected FSK systems and they certainly work, but I would not set out to design a system that way. Steve
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:>On Sat, 3 Oct 2015 18:36:53 +0000 (UTC), spope33@speedymail.org (Steve>>MSK is a subcategory of FSK which is a subcategory of FM.>>2-MSK is equivalent to "OQPSK", but "OQPSK" is simply language that >>appears in some standards documents and the fact that they are >>equivalent is more of a construction than anything else. "OQPSK" >>terminology has since back-filtered into some modern textbooks.>OQPSK is QPSK with either the I or Q channel shifted in time by 1/2 >symbol. I'm not sure what you mean by "construction", but it's been >around for a long time, is part of many standards going back a long, >long time,Thanks, you are correct. Part of my perspective is that for a long long time before that, 2MSK was in the literature and in the field without anybody having performed the "equivalent to OQPSK" construction. I call this a construction, in this case, because it's possible to completely analyze 2MSK behavior without making the analogy to QPSK, and it you go far enough back in the literature, that is how it is done. But, if one looks at OQPSK methods that are not equivalent to MSK (say, with different pulse shapes) then it has become a thing of its own rather than a construction. (But, please don't ask me for a airtight scientific definition of "thing of its own"...)>and is very often implemented just as I described: a >half-symbol shift in the modulator or demodulator.>It reduces the PAPR of QPSK significantly,Well, this is true but it's a bit of an odd angle to view it from: fundamentally FM is constant envelope, AM is not.>and avoids transitions >through the origin, without giving up any of the performance or >spectral properties of QPSK. It also limits spectral regrowth >(compared to QPSK) when hitting the PA hard. This was significant >back in the days when PAs weren't as linear or efficient as they are >now, and when channel filtering wasn't as tight but channels were.Yes, you get all the advantages of FM when you use... FM. (But we know from Shannon's theorem that a constant envelope loses capacity, so there's the trade-off. I'm suspecting, but am not absolutely certain, that in this discussion "crappy filtering" means filtering that moves you even further from capacity.)>If you demodulate MSK as though it was OQPSK with crappy filtering, it >does a pretty good job. Better than many other methods.I'm going go out on a limb and assert that a maximum likelyhood demodulator for MSK gives you the same result whether or not you have decomposed the signal into its OQPSK components, and further that this is true regardless of filtering or coding so long as your ML algorithm is applied correctly. (Sub-optimal demodulators often exploit the structure or chosen form of representation of the signal to narrow things down to a much simpler approach.) Steve
On Sat, 3 Oct 2015 19:39:33 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >>On Sat, 3 Oct 2015 18:36:53 +0000 (UTC), spope33@speedymail.org (Steve > >>>MSK is a subcategory of FSK which is a subcategory of FM. > >>>2-MSK is equivalent to "OQPSK", but "OQPSK" is simply language that >>>appears in some standards documents and the fact that they are >>>equivalent is more of a construction than anything else. "OQPSK" >>>terminology has since back-filtered into some modern textbooks. > >>OQPSK is QPSK with either the I or Q channel shifted in time by 1/2 >>symbol. I'm not sure what you mean by "construction", but it's been >>around for a long time, is part of many standards going back a long, >>long time, > >Thanks, you are correct. > >Part of my perspective is that for a long long time before that, 2MSK >was in the literature and in the field without anybody having performed >the "equivalent to OQPSK" construction. I call this a construction, >in this case, because it's possible to completely analyze 2MSK behavior >without making the analogy to QPSK, and it you go far enough >back in the literature, that is how it is done. > >But, if one looks at OQPSK methods that are not equivalent to >MSK (say, with different pulse shapes) then it has become >a thing of its own rather than a construction. > >(But, please don't ask me for a airtight scientific definition of >"thing of its own"...) > >>and is very often implemented just as I described: a >>half-symbol shift in the modulator or demodulator. > >>It reduces the PAPR of QPSK significantly, > >Well, this is true but it's a bit of an odd angle to view it from: >fundamentally FM is constant envelope, AM is not.It's not odd at all, because QPSK provides a very power-efficient modulation, but the PAPR limited transmit power in some cases. The slight modification to get OQPSK provided a greatly reduced PAPR to get more Tx power in the link without sacrificing any of the power efficiency of the modulation. The gain comes at the cost of some added complexity in the demodulator, but nothing terrible. FSK and MSK allow full saturation of the transmit PA, but aren't as power efficient as QPSK, so you still may not get as efficient of a link as OQPSK, and may not be able to close the link in some cases. In my experience FSK and MSK were historically used when the cost or complexity of a full PSK system was prohibitive. One of the motivations for GMSK in cellular systems was channel management where carriers, even with poor frequency control, could be jammed closer to each other while still using a cheap Class C amplifier that didn't drain the battery of the transmitter as fast. Most of these things are non-issues today. Even linear(ish) amplifiers for handsets are pretty efficient, and PAPR is not much of a concern any more, even places where you used to expect it, like satellite channels.>>and avoids transitions >>through the origin, without giving up any of the performance or >>spectral properties of QPSK. It also limits spectral regrowth >>(compared to QPSK) when hitting the PA hard. This was significant >>back in the days when PAs weren't as linear or efficient as they are >>now, and when channel filtering wasn't as tight but channels were. > >Yes, you get all the advantages of FM when you use... FM. > >(But we know from Shannon's theorem that a constant envelope >loses capacity, so there's the trade-off. I'm suspecting, but >am not absolutely certain, that in this discussion "crappy filtering" >means filtering that moves you even further from capacity.)Or that it just doesn't contain the spectrum well. You can filter QPSK or OQPSK with whatever pulse shape you want, and these days RRC with 10% excess bandwidth is not uncommon. This gives a nice, tight channel occupation with not a lot of guard band needed. MSK, on the other hand...you gotta leave a lot of room for that sprectrally. If you're paying for bandwidth, it's not a friendly modulation scheme.>>If you demodulate MSK as though it was OQPSK with crappy filtering, it >>does a pretty good job. Better than many other methods. > >I'm going go out on a limb and assert that a maximum likelyhood >demodulator for MSK gives you the same result whether or not you have >decomposed the signal into its OQPSK components, and further that this >is true regardless of filtering or coding so long as your ML algorithm >is applied correctly.Not sure what you mean by decomposing the signal into its OQPSK components. The waveforms are the same except for the pulse shape, and the MSK pulse shape does still allow for fully coherent demodulation with no ISI, so from that perspective the performance potentials for the two are essentially the same, although the spectral occupancy can be different. Depending on how that works into one's cost metrics, it can make a difference. The spectral efficiencies of the two are quite different when different pulse shapes are used for OQPSK. The pulse shape cannot be changed for MSK without turning it into something that's not MSK (like GMSK). For whatever reason people tend to demodulate them differently, and often think of MSK as a phase trellis, since the simplest, CPM, modulator operates that way conceptually. This means using a Viterbi demodulator to track the phase trellis, rather than just coherent synchronization and using a decoder on the detected data like you would with PSK. They don't perform the same. So I don't know which demodulation style you would select for MSK when going out on a limb to analyze an ML demodulator, or which metric you would be maximizing. Treat it as CPM? Treat it as minimum-shift 2FSK? Treat it as a special case of PSK? The performance is different for each case, sometimes by quite a bit.>(Sub-optimal demodulators often exploit the structure or chosen >form of representation of the signal to narrow things down to >a much simpler approach.)Complexity is usually an important tradeoff when using a modulation scheme with less capacity than other candidates. As time goes on complexity becomes less and less of an issue, so many of these things you don't see as much any more, except for older standards. Zigbee is starting to age, but it works well enough for many applications that it still has a large market.>SteveEric Jacobsen Anchor Hill Communications http://www.anchorhill.com
