Hilbert Transformers, Question about delay needed to see 90 deg phase shift
Started by Mark March 15, 2005
The short definition of a HT is that it provides a +90 deg phase shift
for negative frequencies and a  -90 deg phase shift for positive
frequencies.   But phase shift relative to what?, relative to the HT
input?  Apparently not.  I used QED to design a HT and looked at the
phase response (for positive frequencies) expecting to see about a  -90
deg phase shift over the range of frequencies, but instead I saw the
usual sawtooth  (linear response with wrapping at +/-pi) shaped phase
response.    The phase response looks similar to that of any other
filter that has delay.  So my conclusion is that QED is graphing the
phase response of the output of the HT relative to the input to the HT
and most of that phase shift is due to the delay through the HT.   In
order to see a constant 90 deg relationship, you must compare the
output of the HT to a DELAYED version of the HT input.   Is this
correct?
I also conclude that it is difficult (impossible?) to create a 90 deg
phase shifted version of a given signal.   The HT and delay create a 90
deg phase shifted version between two signals (the HT output and the
delay output), but is there any device that can create a 90 deg phase
shift between its output and it's input?
thanks
Mark
Mark wrote:
> The short definition of a HT is that it provides a +90 deg phase shift > for negative frequencies and a -90 deg phase shift for positive > frequencies. But phase shift relative to what?, relative to the HT > input? Apparently not. I used QED to design a HT and looked at the > phase response (for positive frequencies) expecting to see about a -90 > deg phase shift over the range of frequencies, but instead I saw the > usual sawtooth (linear response with wrapping at +/-pi) shaped phase > response. The phase response looks similar to that of any other > filter that has delay. So my conclusion is that QED is graphing the > phase response of the output of the HT relative to the input to the HT > and most of that phase shift is due to the delay through the HT. In > order to see a constant 90 deg relationship, you must compare the > output of the HT to a DELAYED version of the HT input. Is this > correct?
Yes. The phase convention in symmetric FIR filters is to take the phase relative to the signal that's delayed to the center of the filter -- so if your filter is symmetrical around tap # 100 then you compare the phase shift to a signal that's delayed 100 samples.
> > I also conclude that it is difficult (impossible?) to create a 90 deg > phase shifted version of a given signal. The HT and delay create a 90 > deg phase shifted version between two signals (the HT output and the > delay output), but is there any device that can create a 90 deg phase > shift between its output and it's input? >
It's easy to create a 90 degree phase shifted signal -- just integrate. What's hard is to create a 90 degree phase shifted signal with constant amplitude. Even a "pure" hilbert transform with delay is impossible to implement in practice -- not only does the hilbert transform extend to infinite time in both directions requiring an infinitely long filter, but it also goes to infinity at DC, requiring infinite precision. In practice you can implement a band-limited hilbert transform with a lower frequency bound that restrains the amplitude and an upper frequency bound and frequency shaping that restrains the delay. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
in article 1110912454.975225.185480@f14g2000cwb.googlegroups.com, Mark at
makolber@yahoo.com wrote on 03/15/2005 13:47:
yes. the delay of the HT is like any other N tap causal, linear phase, FIR filter. the delay is (N-1)/2 samples. (now of your N taps, the HT will have, for odd N, (N-1)/2 zeros in the tap coefs, if you have half-band symmetry in your HT.) so to use this to mix with the non-HTed signal, you should delay the non-HT signal by the same amount. *then* the two signals will be 90 degrees out of phase.
a true Hilbert Transformer is a conceptual device since it requires both an infinite number of taps and it is non-causal. it has an impulse response that happens before the input impulse, thus is predicting the future. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
shift
-90
HT
> and most of that phase shift is due to the delay through the HT. In > order to see a constant 90 deg relationship, you must compare the > output of the HT to a DELAYED version of the HT input. Is this > correct? > > I also conclude that it is difficult (impossible?) to create a 90 deg > phase shifted version of a given signal. The HT and delay create a
90
> deg phase shifted version between two signals (the HT output and the > delay output), but is there any device that can create a 90 deg phase > shift between its output and it's input? > > thanks > Mark
I believe that a true "wideband" HT (90 degree phase shifter) is non-causal. To make it realizable you then convolve it with an FIR filter. So now you have built a Hilbert Transform + a filter. That is what QED gave you. To find the 90 degree phase shift, run the same input signal through the FIR filter (without the Hilbert Transform convolved in it). The output of these two filters will be 90 degrees out of phase (until you get close to the edges, where the HT doesn't match the FIR prototype). Building a narrowband 90 degree phase shifter is easy. If you want to do it in analog, search on quarter wave sections. In the digital domain, just delay the signal the appropriate amount of time (samples).
OK
By convention the phase shift is measured relative to the central tap.
thank you
And yes, my second question should have been.... can you create an
ALLPASS   90 deg phase shift OVER A RANGE OF FREQUENCIES.
I understand an integrator works but changes the amplitude so is not
allpass.
I understand a 1/4 wave line or digital delay works but it is
narrowbad.
I understand a HT works but not relative to the input signal itself.
thanks
Mark
"Mark" <makolber@yahoo.com> wrote in message
news:1110915462.157767.20360@z14g2000cwz.googlegroups.com...
> OK > By convention the phase shift is measured relative to the central tap. > thank you > > And yes, my second question should have been.... can you create an > ALLPASS 90 deg phase shift OVER A RANGE OF FREQUENCIES. > > I understand an integrator works but changes the amplitude so is not > allpass. > I understand a 1/4 wave line or digital delay works but it is > narrowbad. > I understand a HT works but not relative to the input signal itself.
BTW, if you are doing off-line processing (as opposed to real-time), non-causal filters are no problem. So you can create a true Hilbert filter where the output is 90 degrees phase shifted from the input, at least over some finite bandwidth. But for real-time, you have to delay your original signal to get the 90 degree offset.
OK got it
thank you to everybody
Mark
