Steve Pope <spope33@speedymail.org> wrote:> Randy Yates <yates@digitalsignallabs.com> wrote:>>I've never understood how preemphasis/deemphasis mitigates bad data >>converters. Can you please explain it?> AFAIK it does not mitigate "bad" data converters per se; it mitigates any > source of additive white noise (an accurate and properly dithered > data converter being an example of such). It can do this because > the original audio is not spectrally flat, and the pre-emphasis is > a poor-man's whitening filter.Sounds right to me. FM radio has pre-emphasis for about the same reason. Vinyl records and audio tape have slightly more complicated equalization functions, but again the pre-emphasis helps with high frequency noise. -- glen
De Emphasis FIR Filter
Started by ●November 20, 2015
Reply by ●November 21, 20152015-11-21
Reply by ●November 23, 20152015-11-23
>An fir version is a different story, you'll definitely want to use an >optimizer for that. But if your hardware can do either IIR or FIR I don'tknow>why you wouldn't choose IIR. > >BobCan someone, please, explain what kind of optimizer? Using already existing FIR is the only option. Do others agree that I can use IIR impulse response simulated in some software as FIR filter coefficients? I am just trying to find the easiest and quickest method that does not require learning some completely new concepts. How do I know if phase matters? I am trying to demodulate audio signal. Thank you very much for your answers on how to resolve this problem. --------------------------------------- Posted through http://www.DSPRelated.com
Reply by ●November 24, 20152015-11-24
