Baseband Bandwidth
Started by Sharan123 November 21, 2015
Eric Jacobsen <eric.jacobsen@ieee.org> wrote:
(snip)
> "Baseband" generally means the signal is at it's lowest frequency for > simplest processing. For OFDM and most digital signals this means > that the signal spectrum is centered at 0 and the signal spans from > -BW/2 to +BW/2. For things like AM this means the signal may run > from 0 to BW (or BW/2 for a double-sideband signal).
In the case of ethernet, baseband is the alternative to broadband. As well as I know it, the 6MHz wide channels used for TV signals qualify as broad, relative to the carrier frequency (at VHF anyway). The 10broad36 ethernet form never got very popular, but fits the signal into a TV channel, such that it could be implemented on cable TV systems. Current cable modems are the successors, again using one (or more) TV channels to get the signal through. You can normally only have one baseband signal on a cable, but usually more than one non-baseband using different channels.
> Once the signal is mixed (i.e., translated) up to the frequency at > which it is sent over the air, it is at RF. It may go through a > two-step or multiple-step conversion to get to the RF frequency, and > the intermediate steps are called IF (Intermediate Frequency).
> Generally the signal will have the same bandwidth at baseband, IF and > RF. Things like double-sideband AM are an exception, where the > modulated bandwidth is really half of the RF signal bandwidth.
If you include the negative frequencies, then you can consider the AM bandwidth equal to the modulator input. -- glen
>> "Baseband" generally means the signal is at it's lowest frequency for >> simplest processing. For OFDM and most digital signals this means >> that the signal spectrum is centered at 0 and the signal spans from >> -BW/2 to +BW/2. For things like AM this means the signal may run >> from 0 to BW (or BW/2 for a double-sideband signal).
An older definition of "baseband" is a digital signal that is intended to be directly transmitted over a line. This corresponds, I think, to the terminology used in Ethernet. Steve
On Tue, 24 Nov 2015 00:14:33 +0000 (UTC), spope33@speedymail.org
(Steve Pope) wrote:
>glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote: > >>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >>> "Baseband" generally means the signal is at it's lowest frequency for >>> simplest processing. For OFDM and most digital signals this means >>> that the signal spectrum is centered at 0 and the signal spans from >>> -BW/2 to +BW/2. For things like AM this means the signal may run >>> from 0 to BW (or BW/2 for a double-sideband signal). > >>In the case of ethernet, baseband is the alternative to broadband. > >An older definition of "baseband" is a digital signal that is >intended to be directly transmitted over a line. This corresponds, >I think, to the terminology used in Ethernet. > >Steve
In other words, it hasn't been mixed up to some IF or RF or other channel frequency. If you look at it that way, it's consistent across a broader scope. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
(snip on ethernet, baseband, broadband, and such)
(Steve wrote)
>>An older definition of "baseband" is a digital signal that is >>intended to be directly transmitted over a line. This corresponds, >>I think, to the terminology used in Ethernet.
> In other words, it hasn't been mixed up to some IF or RF or other > channel frequency. If you look at it that way, it's consistent > across a broader scope.
I might have thought that you could create a non-baseband signal directly, without a mixer, but the process of doing that seems similar enough to a mixer that it might as well be called one. You could, for example, do all the modulation in the digital domain, then through a DAC, just a little filtering, and out to a wire or transmitter. No analog mixer. But the main time when the distinction is imporant is when you need another signal to fit below it. For example, DSL allows for a baseband analog telephone signal on the same line. -- glen
>(Steve wrote)
>>>An older definition of "baseband" is a digital signal that is >>>intended to be directly transmitted over a line. This corresponds, >>>I think, to the terminology used in Ethernet.
>> In other words, it hasn't been mixed up to some IF or RF or other >> channel frequency. If you look at it that way, it's consistent >> across a broader scope.
>I might have thought that you could create a non-baseband signal >directly, without a mixer, but the process of doing that seems >similar enough to a mixer that it might as well be called one.
>You could, for example, do all the modulation in the digital >domain, then through a DAC, just a little filtering, and out to >a wire or transmitter. No analog mixer.
>But the main time when the distinction is imporant is when you >need another signal to fit below it. For example, DSL allows >for a baseband analog telephone signal on the same line.
The older definition I had in mind above is specifically meant to convey that digital communications is occuring, but with a digital logic signal being simply buffered and sent on the line, without there being a modem per se -- just digital line drivers/receivers. So in that sense, things like NRZ, Manchester, RZ, RLL, RS-232, were all thought of as baseband signals, whereas V.22 was not a baseband signal. The more modern treatment might be that this distinction is too easily blurred -- e.g. a Manchester encoded signal might nonetheless involve preambles, equalization, shaping, on other features commonly thought of as components of a modem. More recently, "the baseband" refers to that part of a PHY layer that is not at IF or RF, regardless of modulation method, as Eric notes above. Steve
Dear Steve, Glen, Eric,
I am opening this thread to seek some more clarifications ... I am keeping
questions generic as sometimes standard specific terminologies tend to
mask the underlying explanations (to me).
1) If I have to design a baseband transmission system and bandwidth is
allocated or known to me then what is the lever I have in hand to limit
the baseband modulated signal to baseband bandwidth. Is it the rate at
which data arrives for baseband modulation?
2) On the RF side, are there multiple ways to carry baseband signal over
the air? Is one better than the other?
In the above responses, it was said that AM tends to occupy smaller RF
BW.
So, sometimes baseband bandwidth of X does not always translated to X
bandwidth at the carrier frequency. Is this correct?
BTW, I am also interested to know if converting baseband signal into RF in
mobile communication is called modulation (in the above response, it was
mentioned as I/Q modulation)? If so, is this the best way to carry I/Q or
baseband data over air?
Once again, thanks
Posted through http://www.DSPRelated.com
On Tue, 29 Dec 2015 09:54:05 -0600, "Sharan123" <99077@DSPRelated>
wrote:
>Dear Steve, Glen, Eric, > >I am opening this thread to seek some more clarifications ... I am keeping >questions generic as sometimes standard specific terminologies tend to >mask the underlying explanations (to me). > >1) If I have to design a baseband transmission system and bandwidth is >allocated or known to me then what is the lever I have in hand to limit >the baseband modulated signal to baseband bandwidth. Is it the rate at >which data arrives for baseband modulation?
I don't think there's a single way to answer this, and there are a lot of nuanced tradeoffs and different ways to do things. In general, though, the bandwidth will be approximated by the data rate (bits/sec) divided by the modulation density (bits/Hz). Increasing modulation density usually costs range or reliability. If you're starting with a particular bandwidth, for a single-carrier system the bandwidth is essentially the symbol rate, and the modulation density can be increased by increasing the modulation order (e.g., moving up from QPSK -> 16QAM -> 64QAM, etc., etc.). For a multi-carrier system you can pick how many subcarriers, how wide they are, etc., etc., to fill up your usable bandwidth.
>2) On the RF side, are there multiple ways to carry baseband signal over >the air? Is one better than the other?
Generally the RF transmission system and the baseband modulation are matched for compatibility. e.g., it makes no sense to send an OFDM baseband waveform into either an RF phase modulator or a class-C power amplifier. Beyond that I'm not sure what you're asking.
>In the above responses, it was said that AM tends to occupy smaller RF >BW. >So, sometimes baseband bandwidth of X does not always translated to X >bandwidth at the carrier frequency. Is this correct?
FM doesn't inherently occupy more bandwidth than AM. Generally analog FM systems adjust the modulation index in order to get an improvement in SNR in the receiver. So, yes, in analog FM the modulation index can be adjusted so that the signal bandwidth and the RF bandwidth differ by controllable amounts. This is similar to changing the modulation density or modulation order in a digital system.
>BTW, I am also interested to know if converting baseband signal into RF in >mobile communication is called modulation (in the above response, it was >mentioned as I/Q modulation)? If so, is this the best way to carry I/Q or >baseband data over air?
Yes, the word "modulation" is overloaded and means both the type of modulation that is used as well as the conversion process from baseband to IF/RF.
>Once again, thanks > >--------------------------------------- >Posted through http://www.DSPRelated.com
Okay, I am skipping your question (1) as Eric has answered it.
One could define there between two majorly different ways of doing this: carrying the signal in the near-field or in the far-field. But in many (most) circumstances the designer doesn't really have this as a choice. Much more frequently one is faced with designing and/or specifying the antenna design. Antennas are crucial to system performance, can be quite complex, and there is a vast number of different antenna types. Additionally this is one place where combining may be used (beamforming or MIMO).
That is correct, in that selectivity can be obtained either within the baseband processor or at an IF or RF stage, or quite commonly both; and this applies separately to the transmitter and the receiver.
As Eric stated, this is often called modulation, but it could be more precisely be called mixing. How exactly this is approached is related to, or a part of, the frequency plan for your system. Having a good frequency plan is important. Steve
Once again, thanks ...
