>Am Montag, 1. Februar 2016 15:23:12 UTC+1 schrieb Steve Pope: >> SG wrote: >> >> >I've already said the things I *can* say given the information you >> >gave: >> >> >(1) You're not supposed to change the filter parameters that quickly. >> >> "Not supposed to" according to who? > >Me. > >> OP stated this is a requirement, that it works in analog, and >> that there are existence proofs that it works in digital. > >That's why I've been suggesting oversampling twice already. With >enough oversampling the rate of change of the cutoff parameter >measured in sample periods can be made arbitrarily small and I believe >that's what's important to keep this time-varying filter stable. > >S0lo, please try oversampling. By oversampling I basically mean that >you operate at a much higher sampling rate internally but try to keep >the bandwidth of the signals you deal with more limited. For example: >Operate at a sampling rate of 192 kHz but make sure that your >sawtooth signal you feed into the filter is band-limited (no harmonics >above, say, 30 kHz. And after the time-varying filter you might need >to lowpass the result again to remove inaudible harmonics that could >get you into trouble during the next nonlinear processing step (if >there is any). > >If your current sawtooth generating code suffers from aliasing, try >looking for how to create band-limited steps (BLEPs) and compose your >waveform out of ramps and these BLEPs. Oversampling is also very >convenient here because it allows you to to keep the BLEP rather >short. With oversampling you have more "headroom" in the upper >frequencies where the step response does not have to be good or even >alias-free. For example, with 2X oversampling you can approximate a >band-limited step well with just 8 samples. You could create an >8x64 BLEP table for 64 sub-sample positions of the step. > >Cheers! >sgThanks, I've already tried oversampling as I said before, same problem, may be I'll do that again making sure that I've done it right. I also just tried a real sampling rate of 192Khz. Same thing, no improvement. Yes I'm using MinBLEP for the saw tooth, no aliasing at all, super clean even at 20Khz --------------------------------------- Posted through http://www.DSPRelated.com
Filter FM and sideband overload
Started by ●January 26, 2016
Reply by ●February 2, 20162016-02-02
