>So a complex-valued channel gain per antenna gets multiplied by the >complex-valued baseband signal received at that antenna. From this >perspective the phase is really only relevant to model the phase >differences between antennas. For a single antenna system a >flat-fading channel would only require a scalar amplitude coefficient, >but for multiple antennas the relative phases matter.Dear Eric & Steve, Thanks. I assume that the complex-valued channel gain per antenna is a single value (one point on complex plane) and not a vector by itself for a given antenna ... PS: it is possible that these values could change quasi-dynamically based on channel conditions and can vary per antenna --------------------------------------- Posted through http://www.DSPRelated.com
Signal multiplication with complex number
Started by ●January 30, 2016
Reply by ●February 2, 20162016-02-02
On Tue, 02 Feb 2016 07:00:45 -0600, "Sharan123" <99077@DSPRelated> wrote:>>So a complex-valued channel gain per antenna gets multiplied by the >>complex-valued baseband signal received at that antenna. From this >>perspective the phase is really only relevant to model the phase >>differences between antennas. For a single antenna system a >>flat-fading channel would only require a scalar amplitude coefficient, >>but for multiple antennas the relative phases matter. > >Dear Eric & Steve, > >Thanks. I assume that the complex-valued channel gain per antenna is a >single value (one point on complex plane) and not a vector by itself for a >given antenna ...Actually, it can be either. Generally, basic MIMO processing only needs independent flat-fading (i.e., single value) channel coefficients to work. In practice, there is often multipath where the channel impulse response has a delay spread that is represented by a vector rather than a single coefficient.>PS: it is possible that these values could change quasi-dynamically based >on channel conditions and can vary per antennaYes. For MIMO to work the individual channels coefficients for each antenna must be independent of each other to a high degree. That isn't always the case in practice, but often it is. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Tue, 02 Feb 2016 07:00:45 -0600, Sharan123 wrote:>>So a complex-valued channel gain per antenna gets multiplied by the >>complex-valued baseband signal received at that antenna. From this >>perspective the phase is really only relevant to model the phase >>differences between antennas. For a single antenna system a >>flat-fading channel would only require a scalar amplitude coefficient, >>but for multiple antennas the relative phases matter. > > Dear Eric & Steve, > > Thanks. I assume that the complex-valued channel gain per antenna is a > single value (one point on complex plane) and not a vector by itself for > a given antenna ...I'm not sure if it's entirely clear from the discussion so far, but the underlying process that you're modeling with antenna stuff is that the signal goes out from the transmitter, bounces off of random stuff "out there", and then various bits of it hit the antenna at various delays. For delays that are a good portion of a cycle of RF, but are small compared to any modulation interval, the best model is a simple phase shift and gain (or attenuation). This, in turn, is best modeled as multiplying the signal with a complex gain. For delays that are a good portion, or more than one, modulation interval, then the best model is that delay, plus the afore-mentioned complex gain. This case is going to be most prevalent when you're dealing with a spread-spectrum service, because the chipping rate will tend to be a much healthier portion of the carrier frequency than the underlying bit rate (or analog signal bandwidth). There's no reason you can't have multiple paths; for how to handle that do a search on "rake receiver".> PS: it is possible that these values could change quasi-dynamically > based on channel conditions and can vary per antennaIf either your antennas or the things that your signal is reflecting off of are moving, then yes. So definitely yes if the transmitter or receiver is mobile (like a cell phone). Buildings, walls, and towers don't generally get up and walk around, so varying multipath isn't as much of an issue with fixed stations -- but in a fringe reception area you can get significant propagation from airplanes and other moving phenomenon. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●February 3, 20162016-02-03
Dear Eric, Tim, Thanks a lot. THis helps a lot --------------------------------------- Posted through http://www.DSPRelated.com
