<makolber@yahoo.com> wrote:> spp wrote,>> When I visualize this, it seems it violates the antenna >> recipricocity theorem as it would suggest driving the antenna >> with a given power would create twice that power in the EM >> field. Something it not right with the idea, and I'd like >> to see more of a description, perhaps a literature reference.>that was my statement. (not Peters)Oops. Sorry, Peter.>I spent a little time doing a literature search but didn't find anything >worth quoting..>but I'll give you these thoughts....>every conductor with accelerated charges (which I will now refer to as current) >radiates a field.>If you place an antenna in an existing field, there will be a current >induced into the conductors.>The current distribution will be changed depending upon how the antenna >terminals are terminated. The three corner cases are open circuit, >short circuit and matched. Since the current distribution changes, the >re-radiated field changes. You can think of it in terms of conservation >of energy as well, the power delivered to the LNA must be taken from the >EM field and hence the field is changed by the presence of the loaded >antenna. And the EM field is changed differently if the antenna is >shorted or open instead or matched.>Another thought is the operation of a Yagi antenna. The reflector and >directors obviously re-radiate a field in that case. The spacing and >length of these are adjusted such that the rre-radiated field >re-enforces the field at the "driven element".>Due to conservation of energy (ignoring losses) a shorted or open >antenna must re-radiate ALL the energy it absorbs. A matched antenna >delivers some power to the load, therefore the amount re-radiated must >be less.Hmm. Last I checked, light is EM radiation. So let's say you have a 200" telesope mirror pointed in the direction of a light source and an optically back object in its focal plane. I cannot see how any significant fraction of the power incident on the mirror is "re-radiated". When you get down to something like a dipole, there is significant re-radiation going on by the mechanisms you describe, but these factors are already taken into account when stating the antenna gain in dBi. Thus a 0 dBi antenna has a cross-sectional area of (IIRC) 0.06 * (lambda)^2 . The receiver designer (in the far-field case) can correctly assume that the RF flux incident on a region of this area is 100% coupled into the receiver front end, assuming no mismatch, resistive losses, or similar inefficiencies. So in the typical case the receiver designer does not need to worry about these re-radiation effects, and they are not part of what needs to be modeled in this thread. Steve
Adding noise given by Noise Factor
Started by ●February 11, 2016
Reply by ●February 26, 20162016-02-26
