Measuring the correct SNR for image in matlab
Started by bamerni February 16, 2016
Hello all,
I am trying to add noise of 5dB to an image in matlab according to the
following steps
SNR = 5;
Id = double(Io) / 255;
v = var(Id(:)) / 10^(SNR/10);
I_my_noisy = imnoise(Id, 'gaussian', 0, v);
but when I measure the SNR by using the matlab command
[peaksnr,snr] = psnr(I_my_noisy, Id)
I get SNR equal 10. So, what is the wrong in my code? and why the result
differ from my add dB?
Posted through http://www.DSPRelated.com
On 2016-02-16 7:55, bamerni wrote:
> Hello all, > > I am trying to add noise of 5dB to an image in matlab according to the > following steps > > SNR = 5; > Id = double(Io) / 255; > v = var(Id(:)) / 10^(SNR/10); > I_my_noisy = imnoise(Id, 'gaussian', 0, v); > > > but when I measure the SNR by using the matlab command > > [peaksnr,snr] = psnr(I_my_noisy, Id) > > I get SNR equal 10. So, what is the wrong in my code? and why the result > differ from my add dB?
What do you get if you use SNR3 = 10*log10(var(Id)/var(I_my_noisy-Id)) ? What does psnr return for a simple ideal image with one single pixel "1" (all other 0) and with the noisy image containing 2.7783 ?
