Hello, I have a question about filter implementation. If I have a sequence x[n] and divide it into blocks of M samples per block and do the following: 1) Update filter-coefficients 2) Filter the kth block 3) k=k+1 4) Go to 1 How should the filter be implemented ? In matlab I have 2 options: Either I implement the filter like this: [output,final_conditions]=filter(numerator_coefficients, denominator_coefficients, input_block, initial_conditions); initial_conditions=final_conditions; or output=filter(numerator_coefficients, denominator_coefficients, input_block) I would say that it doesn't really matter to use initial/final conditions because the accuracy of the initial and final conditions rely on the filter coefficients being constant and not time-varying. So since the filter coefficients are updated for each block why would I care about the initial and final conditions? Using initial and final conditions only makes sense in the case where the filter coefficients are constant. In that case it will ensure that I avoid transients, right? Or am I mistaken? Thanks :o)
Block Processing Issue
Started by ●October 25, 2005
Reply by ●October 25, 20052005-10-25
Lars, What type of signal are you filtering? How important is continuity? How/why are the coefficients changed from one block to the next? Do you piece the output blocks together? How? Does K samples in produce more than K samples out (from zero padding the end for example) ? Dirk
> What type of signal are you filtering?A noise degraded speech signal x=s+n where s is clean speech and n is colored, gaussian noise.> How important is continuity?I don't know to be honest. Maybe you can tell me why you ask that particular question?> How/why are the coefficients changed from one block to the next?One filter (whitening FIR filter) receives its filter coefficients from LPC-analysis based on the short-term autocorrelation of a 256 samples long frame Another filter (vocal tract IIR filter) receives its filter coefficients from LPC-analysis based on the modified power spectrum of the 256 samples long frame.> Do you piece the output blocks together?Yes.>How?If the output blocks are B1,B2,B3,.....,Bn then the estimated speech signal is: B1B2B3B4B5......Bn>Does K samples in > produce more than K samples out (from zero padding the end for example) > ?No. K samples in results in K samples out. Here is a short overview of my algorithm: 1. Send 16 samples (a block) through a pre-emphasis filter P(z). Output is stored in a cyclic buffer of length 256 2. Update frame (length 256) based on contents of cyclic buffer (*) 3. Use autocorrelation of frame to calculate LPC-coefficients and LPC-gain (Levinson-Durbin) 4. Send output from P(z) through a whitening FIR filter A(z) to obtain residual signal. A(z)'s filter coefficients are the LPC-coefficients (numerator) and LPC-gain (denominator) 5. Calculate the power spectrum of the frame and do some manipulation with it to obtain a less noisy spectrum. Convert spectrum to autocorrelation. Use autocorrelation to calculate LPC-coefficients and LPC-gain. 6. Send residual signal through a "vocal-tract" filter B(z) to obtain estimated speech signal. The filter B(z) is an IIR filter whose coefficients are the LPC-coefficients (denominator) and LPC-gain from item 5 7. De-emphasize estimated speech signal In general, I implemented the filters as: [output,final_conditions]=filter(numerator,denominator,signal,initial_conditions); initial_conditions=final_conditions; But the estimated speech sounded horrible until I replaced the above 2 commands with: output=filter(numerator,denominator,signal); In one of the tests I made I tried to use a noise-free speech signal as input to the algorithm. The algorithm should then output a copy of the input, but I could _only_ get output=input if I didn't use initial and final conditions in the above described filters. I hope that you can help me see what I am doing wrong or right :o) Thank you....
Reply by ●October 26, 20052005-10-26
Lars, I don't have time to look it up, but IIRC (and I may not, it has been quite a while) the lattice implementation using reflection coefficients allowed one to adjust the filter gradually within a block by interpolating between the current and next set of reflection coefficients as you progress through the block. Interpolation may have been done at pitch intervals.Look up 'MPE-LPC' and see if you find this explained. More common IIR implementations do not allow this gradual progression of the filter (can't interpolate the coefficients, for example, and be guaranteed stability), and as you say the internal state would not commonly transfer from one block to the next where the filter is updated on a block by block basis. I would not expect either of the filtering methods you have used to sound good on reasonable quality audio, since you would get periodic (annoying) errors at the block interval. When you say you got output=input with noise-free speech what criteria did you use to come to this conclusion? I would guess it must have been qualitative, rather than quantitative. Subtracting Output-Input I would expect to not get close to zero out. Consider the case where you don't change the filter taps at all, but called it uninititalized (zeroed internally) with each block, inputting K samples and outputting only K samples out, then the output signal at the block edges would not be correct. This last statement would even be true if the filter was an FIR constant coefficient filter. Hope this helps some, Dirk
