Good old Hilbert Transform question
Started by NiCad June 24, 2006
Hello everyone,
just a little question about the good old Hilbert Transform.
- Goal: obtain analytic signal (a(n)+j�(n)) from an in-phase signal
(a(n));
- Tool: Blackfin BF537. I get a sampled signal, and i compute it's hilbert
transform using a FIR filter with coefficients obtained using
Matlab/Scilab's "Hilb" function.
-Problem: I have to create the analytic signal in a numeric fashion... The
signal �(n) coming out of the filter is longer than the initial signal
a(n), by the amount of taps/coeffs in the filter. So, when i reassemble
both signals in a .re and .im structure, the imaginary part is longer...
The question is, can i just truncate the imaginary signal so that i have
equivalent length signal components? Or should i use a smaller length
signal applied to the input of the filter? This way, i would have:
 - initial signal a[n] of length N
 - filter h length M
 - yields:   �[N]=a[N-M]*h[M]
Although i have not noticed anyproblems with this method, I am not sure if
this is a correct way of proceeding, or if some better method exists...
Thanks for your time DSPers!
NickelCadmium - NiCad - keeps on going, and going, and going..
NiCad wrote:
> Hello everyone, > > just a little question about the good old Hilbert Transform. > > - Goal: obtain analytic signal (a(n)+j=E2(n)) from an in-phase signal > (a(n)); > - Tool: Blackfin BF537. I get a sampled signal, and i compute it's hilbert > transform using a FIR filter with coefficients obtained using > Matlab/Scilab's "Hilb" function. > -Problem: I have to create the analytic signal in a numeric fashion... The > signal =E2(n) coming out of the filter is longer than the initial signal > a(n), by the amount of taps/coeffs in the filter. So, when i reassemble > both signals in a .re and .im structure, the imaginary part is longer... > > The question is, can i just truncate the imaginary signal so that i have > equivalent length signal components? Or should i use a smaller length > signal applied to the input of the filter? This way, i would have: > - initial signal a[n] of length N > - filter h length M > - yields: =E2[N]=3Da[N-M]*h[M] > > Although i have not noticed anyproblems with this method, I am not sure if > this is a correct way of proceeding, or if some better method exists... > > Thanks for your time DSPers! > > ----------------------------------- > NickelCadmium - NiCad - keeps on going, and going, and going..
Since you are doing a Hilbert transform via an FIR filter, then simply delay your in-phase part by the delay of the Hilbert and then pair the two together to make your analytic signal. Linear phase FIRs have a delay of (N+1)/2 samples where N is the number of taps in the filter. Clay
Clay wrote:
> NiCad wrote: >> Hello everyone, >> >> just a little question about the good old Hilbert Transform. >> >> - Goal: obtain analytic signal (a(n)+j�(n)) from an in-phase signal >> (a(n)); >> - Tool: Blackfin BF537. I get a sampled signal, and i compute it's hilbert >> transform using a FIR filter with coefficients obtained using >> Matlab/Scilab's "Hilb" function. >> -Problem: I have to create the analytic signal in a numeric fashion... The >> signal �(n) coming out of the filter is longer than the initial signal >> a(n), by the amount of taps/coeffs in the filter. So, when i reassemble >> both signals in a .re and .im structure, the imaginary part is longer... >> >> The question is, can i just truncate the imaginary signal so that i have >> equivalent length signal components? Or should i use a smaller length >> signal applied to the input of the filter? This way, i would have: >> - initial signal a[n] of length N >> - filter h length M >> - yields: �[N]=a[N-M]*h[M] >> >> Although i have not noticed anyproblems with this method, I am not sure if >> this is a correct way of proceeding, or if some better method exists... >> >> Thanks for your time DSPers! >> >> ----------------------------------- >> NickelCadmium - NiCad - keeps on going, and going, and going.. > > > Since you are doing a Hilbert transform via an FIR filter, then simply > delay your in-phase part by the delay of the Hilbert and then pair the > two together to make your analytic signal. Linear phase FIRs have a > delay of (N+1)/2 samples where N is the number of taps in the filter.
If your HT has an even number of taps, the necessary delay will not be a whole number of sample times. If your HT has an odd number of taps, the properly delayed I signal is available at the middle tap of the HT delay structure. Both ends of a filtered signal are corrupted with transients. While the whole output is longer than the input by twice the filter length, the uncorrupted output is shorter by the same amount. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>Clay wrote: >> NiCad wrote: >>> Hello everyone, >>> >>> just a little question about the good old Hilbert Transform. >>> >>> - Goal: obtain analytic signal (a(n)+j�(n)) from an in-phase signal >>> (a(n)); >>> - Tool: Blackfin BF537. I get a sampled signal, and i compute it's
hilbert
>>> transform using a FIR filter with coefficients obtained using >>> Matlab/Scilab's "Hilb" function. >>> -Problem: I have to create the analytic signal in a numeric fashion...
The
signal
reassemble
longer...
have
>>> equivalent length signal components? Or should i use a smaller length >>> signal applied to the input of the filter? This way, i would have: >>> - initial signal a[n] of length N >>> - filter h length M >>> - yields: �[N]=a[N-M]*h[M] >>> >>> Although i have not noticed anyproblems with this method, I am not
sure if
exists...
>>> >>> Thanks for your time DSPers! >>> >>> ----------------------------------- >>> NickelCadmium - NiCad - keeps on going, and going, and going.. >> >> >> Since you are doing a Hilbert transform via an FIR filter, then simply >> delay your in-phase part by the delay of the Hilbert and then pair the >> two together to make your analytic signal. Linear phase FIRs have a >> delay of (N+1)/2 samples where N is the number of taps in the filter. > >If your HT has an even number of taps, the necessary delay will not be a
>whole number of sample times. If your HT has an odd number of taps, the >properly delayed I signal is available at the middle tap of the HT delay
> While the whole output is longer than the input by twice the filter >length, the uncorrupted output is shorter by the same amount. > >Jerry >-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >
Thanks alot for the good info Nic ----------------------------------- NickelCadmium
