How to draw a spectrum of Pulse Amplitude Modulated signal?
Started by May 7, 2007
Hello all!
I have a school project to do about PAM (Pulse Amplitude Modulation),
but these stuff aren't explained at all in our school class. I tried
searching google about PAM spectrum, but I almost didn't find
anything. Even in Wikipedia there was almost nothing useful about PAM.
I'm given a triangle signal with period=T,amplitude=A and a pulse
(square) carrier signal at 1MHz.
I can write this signal in a mathematical way, but I don't know how to
find its spectrum.
I have 2 things to do:
1) Write down an algoritm to calculate the spectrum of the modulated
signal.
2) Draw the spectrum of the modulated signal up to 6MHz.
If you help me with 1) I'll be able to do 2)
Thanks!
On May 7, 8:35 am, ivanat...@gmail.com wrote:
> Hello all! > > I have a school project to do about PAM (Pulse Amplitude Modulation), > but these stuff aren't explained at all in our school class. I tried > searching google about PAM spectrum, but I almost didn't find > anything. Even in Wikipedia there was almost nothing useful about PAM. > I'm given a triangle signal with period=T,amplitude=A and a pulse > (square) carrier signal at 1MHz. > I can write this signal in a mathematical way, but I don't know how to > find its spectrum. > I have 2 things to do: > 1) Write down an algoritm to calculate the spectrum of the modulated > signal. > 2) Draw the spectrum of the modulated signal up to 6MHz. > > If you help me with 1) I'll be able to do 2) > > Thanks!
Thanks for being honest that this is a school project. To go from the time domain to the frequency domain, you will need to do a Fourier transform. Hopefully your instructor has covered Fourier transforms, Discrete Fourier Transforms, and Fast Fourier Transforms. In the field of Fourier transformation, there are some useful theorems for shifting and modulation. You should be able to use these to accomplish what you need. There is even a theorem for the spectrum of periodic signals. I hope this points you in the right direction. Has your instructor worked a similar problem during lecture? If so try to follow his steps. But also look at what tools (theorems) he has given you. I don't think he expects you to invent something new. Clay
The truth is that our educational system sux - there are too few
lessons to cover the whole material, and even less hours of exercises.
When we are on exercies the only thing we do is clicking in Mathlab
and entering data, and then Mathlab script shows some specter or
graph... And our teacher thinks it is worthless to explain anything at
all 'becouse if you really need it you will find it somewhere'... Most
of my classmates pay to someone to make their school projects but I'm
trying to actually learn something.
On the subject: I know Fourier Transform, and can do FT on my signal
to get it as a sum of coss and sins. We have some theorems that I'm
sure won't go here: about how the FT changes when the signal is
shifted left or right, or if its amplitude is being multiplicated by a
fixed number...
I've seen FFT and DFT only on Mathcad examples and I don't really know
how to use them.
So as far as I undestood by now - I will need a Fourier Transform of
my signal, take frequencies of the gradients from there and here is a
part of my spectrum?
Thank you for your quick response.
On May 7, 10:00 am, ivanat...@gmail.com wrote:
> The truth is that our educational system sux - there are too few > lessons to cover the whole material, and even less hours of exercises. > When we are on exercies the only thing we do is clicking in Mathlab > and entering data, and then Mathlab script shows some specter or > graph... And our teacher thinks it is worthless to explain anything at > all 'becouse if you really need it you will find it somewhere'... Most > of my classmates pay to someone to make their school projects but I'm > trying to actually learn something. > > On the subject: I know Fourier Transform, and can do FT on my signal > to get it as a sum of coss and sins. We have some theorems that I'm > sure won't go here: about how the FT changes when the signal is > shifted left or right, or if its amplitude is being multiplicated by a > fixed number... > I've seen FFT and DFT only on Mathcad examples and I don't really know > how to use them. > > So as far as I undestood by now - I will need a Fourier Transform of > my signal, take frequencies of the gradients from there and here is a > part of my spectrum? > > Thank you for your quick response.
A book that will likely help you a lot is Paul Nahin's "Dr. Euler's Fabulous Formula." It covers all of the essential elements you need and then some. It also shows quite a few tricks. Clay
I've read some reviews on that book and I want to find it. I checked
in some libraries but no one have it. I wish I had a CC to order it
from Amazon...
Do you have this book in some sort of e-book variant (PDF, html or
etc)?
<ivanatora@gmail.com> wrote in message
news:1178541359.429108.295770@p77g2000hsh.googlegroups.com...
> Hello all! > > I have a school project to do about PAM (Pulse Amplitude Modulation), > but these stuff aren't explained at all in our school class. I tried > searching google about PAM spectrum, but I almost didn't find > anything. Even in Wikipedia there was almost nothing useful about PAM. > I'm given a triangle signal with period=T,amplitude=A and a pulse > (square) carrier signal at 1MHz. > I can write this signal in a mathematical way, but I don't know how to > find its spectrum. > I have 2 things to do: > 1) Write down an algoritm to calculate the spectrum of the modulated > signal. > 2) Draw the spectrum of the modulated signal up to 6MHz. > > If you help me with 1) I'll be able to do 2) > > Thanks! >
Well one way to do this is if you can write this signal in a mathematical way you can generate samples of that signal, that you can later subject to a frequency transform. If your interested in frequencies up to 6 MHz then Nyquist says you need a sample rate of at least 12MHz (I personally would go beyond just Nyquist). Then generate an array of samples with respect to time. i.e. t=0 t=8.3E-8 t=1.66E-7 t=2.5E-7 are the first four samples at Nyquist. Then you can do a DFT or FFT on the samples to get the spectrum. Whatever the required frequency resolution will determine how many samples are generated. Thomas Magma
On May 7, 11:53 am, ivanat...@gmail.com wrote:
> I've read some reviews on that book and I want to find it. I checked > in some libraries but no one have it. I wish I had a CC to order it > from Amazon... > Do you have this book in some sort of e-book variant (PDF, html or > etc)?
I have the book in a quaint form - hardcover. I bought it in a bookstore (Barnes & Noble) last summer. I have other books by Nahin, so I was sure this would be a keeper, and it is. Clay On your original problem, find the FT of a solitary pulse. Then think about how you would find the FT of two pulses side by side using the Heaviside shifting theorem. Then extend the idea to an infinity of pulses.
Clay wrote:
> On May 7, 11:53 am, ivanat...@gmail.com wrote: >> I've read some reviews on that book and I want to find it. I checked >> in some libraries but no one have it. I wish I had a CC to order it >> from Amazon... >> Do you have this book in some sort of e-book variant (PDF, html or >> etc)? > > I have the book in a quaint form - hardcover. I bought it in a > bookstore (Barnes & Noble) last summer. I have other books by Nahin, > so I was sure this would be a keeper, and it is. > > Clay > > On your original problem, find the FT of a solitary pulse. Then think > about how you would find the FT of two pulses side by side using the > Heaviside shifting theorem. Then extend the idea to an infinity of > pulses.
I don't think a PAM spectrum can be deduced in the abstract. One needs the modulating signal, just as for AM or FM. Adjacent pulses will have different amplitudes. (The duty cycle needs to be specified too, and in practice, the splatter filter will round the corners of the pulses. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
On May 7, 9:02 pm, Jerry Avins <j...@ieee.org> wrote:
> Clay wrote: > > On May 7, 11:53 am, ivanat...@gmail.com wrote: > >> I've read some reviews on that book and I want to find it. I checked > >> in some libraries but no one have it. I wish I had a CC to order it > >> from Amazon... > >> Do you have this book in some sort of e-book variant (PDF, html or > >> etc)? > > > I have the book in a quaint form - hardcover. I bought it in a > > bookstore (Barnes & Noble) last summer. I have other books by Nahin, > > so I was sure this would be a keeper, and it is. > > > Clay > > > On your original problem, find the FT of a solitary pulse. Then think > > about how you would find the FT of two pulses side by side using the > > Heaviside shifting theorem. Then extend the idea to an infinity of > > pulses. > > I don't think a PAM spectrum can be deduced in the abstract. One needs > the modulating signal, just as for AM or FM. Adjacent pulses will have > different amplitudes. (The duty cycle needs to be specified too, and in > practice, the splatter filter will round the corners of the pulses. > > Jerry > --
He just ends up with a summation where each term is weighted by the corresponding PAM value. For special sets of PAM values, the summation can be reduced. Clay
Clay wrote:
>> I don't think a PAM spectrum can be deduced in the abstract. One needs >> the modulating signal, just as for AM or FM. Adjacent pulses will have >> different amplitudes. (The duty cycle needs to be specified too, and in >> practice, the splatter filter will round the corners of the pulses. >> >> Jerry >> -- > > He just ends up with a summation where each term is weighted by the > corresponding PAM value. For special sets of PAM values, the summation > can be reduced.
Sure. There are even some interesting observations to be made about the overall statistical properties of the summation. There are some spectral effects that don't appear when all the pulses have the same amplitude. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
