On May 23, 8:11 am, "c1910" <c_19...@hotmail.com> wrote:> hi, > i'm very new with DSP FIR. > i need to make a Bandpass filter with FIR design. first, i use the AM > signal for the input, then i want to get the information signal by > filtering the AM signal. > The problem is to get the value of transfer function of the FIR filter, i > need a mathematical equation, > i don't know where to start and what equation or theory to use?! > can you give me an equation to start? > or an example to design FIR filter? > this is for my thesis, and i'm using the DSK TMS320C54... > please give me some input...thanks... >You can get a mathematical equation by using a windowing method on an ideal bandpass filter. But then what? But for more practical concerns - why do you want to use an FIR structure for your band pass filter? FIRs are not usually the best thing for this. I believe that trying to directly go to a solution without any reason for choosing said solution will lead to diaster. If not that, then a lot of wasted time and effort. Get Rick Lyon's book "Understanding Digital Signal Processing" and invest the time there learning the subject. Then you will actually have a chance of getting your thesis material to work. I truly believe that this will be your path of least effort to success. Clay
Re: How to design FIR filter with matematical equation?
Started by ●May 23, 2007
