I can read and plot y as input value in matlab which is meaning that the interfacing is ok, but x3 which is imag value appear as a real. Yes I can change this value to imag by multiplying it by i but actually I want to read it directly as imag from ccs. Thank you.>Thanks a lot for all of you for reply, in fact I am using in my work67dsk>and CCS 2.1 version and I used C-language for programming my project. I >would like to display my result using contour function and because this >function is not available in CCS I used interfacing function between >MatLab and ccs and it was fine, but the problem I couldn't read the >complex value I got the both values as real values. Here both codes in >matlab and cccs: > >this a part from c code in CCS: > >for( i = 0 ; i < N/2 ; i++ ) > { > W[i].re = cos(D*i);// where N is = 512 (number of FFT points) > W[i].im = sin(D*i); > } > for( i = 0 ; i <N ; i++ ) > { > x[i].re=(float)((short)input_signal[i]); > x[i].im = 0 ; > y[i]=samples[i]; > } > > digitrev_index(iTwid, N/2, 2); > bitrev(W, iTwid, N/2); > > > cfftr2_dit(x, W, N ) ; > > digitrev_index(iData, N, 2); > bitrev(x, iData, N); > > for (i=0;i<512;i++){ > //x[i].re=2.2*i; > //x[i].im=4.3*i; > x4[i]=x[i].re; > x5[i]=x[i].im; > } > > for(i=0;i<512;i++) > simt[i]=i; > > for(i=0;i<N;i++) > { > l=i+1; > if(i>0) k=1; > for(j=0;j<4;j++) > {if(l>(N-1)) l=0; >x2[i][j]=x[l].re*k*exp(-2.0*PI*PI*simt[i]*simt[i]/(1.0*(j+1)*64*64*(j+1))); >x3[i][j]=x[l].im*k*exp(-2.0*PI*PI*simt[i]*simt[i]/(1.0*(j+1)*64*64*(j+1))); > //x4[j]=exp(-2.0*PI*PI*simt[j]*simt[j]/(16.0*(5.0)*(5.0))); > l++; > } > > matlab code(just a part from my code): > >cc=ccsdsp; > > x2 = read(cc,address(cc,'x2'),'single',512); > x3 = read(cc,address(cc,'x3'),'single',512); > > y= read(cc,address(cc,'y'),'single',512); >
reading of complex values
Started by ●July 3, 2007
Reply by ●July 4, 20072007-07-04
On 3 Jul, 19:39, julius <juli...@gmail.com> wrote:> On Jul 3, 9:37 am, Jerry Avins <j...@ieee.org> wrote: > > [snip] > > > Now, the tools have grown so powerful that many operations require only > > a knowledge of the appropriate incantation. These sorcerers' apprentices > > just turn the crank, without knowledge of the machinery that the crank > > connects to, or even realizing that machinery is part of the process. > > > It has been some years since a CE graduate asked me how computer > > hardware distinguished between bits that represent numbers, and those > > that represent ASCII. He put me down as an ignoramus because I told him > > that was software's province. "Can't be!" > > > Programs like Matlab that let one deal with concepts without bogging > > down in details allow one to seem useful without understanding the > > concepts at all. EE seems to be going the way that CE went. > > > Jerry > > Although I agree with much of what Jerry is saying, it should be > noted that the drive to learn to apply more "advanced" science and > technology and teaching this to undergraduates means that we > have to choose and limit what the focus is.Which is why everything fails. Using Jerry's example with the nail, one can not appreciate the function and usefulness of the compresed- air nailgun unless one have tried using at least a hammer in very awkward positions or for a long time. As far as I am concerned, the world works from a very simple principle: One can not understand -- "understand", not "use" -- the advanced stuff unless one *understands* the basic stuff. The conclusion is obvious: To teach advanced stuff, focus on the basics.> Most of the time, it's > done by encapsulating things into nice, well-behaved "black boxes" > that the users do not have to know what is inside.But science and engineering students are not merely *users* of black boxes; they are expected -- by me if by nobody else -- to *understand* what is inside and -- infinitely worse -- make one. Rune
