On Sep 25, 9:25 pm, John <sampson...@gmail.com> wrote:> On Sep 25, 2:31 pm, Jaco Naude <naude.j...@gmail.com> wrote: > > > > > >> Why Gold codes? What are you trying to accomplish by that? > > > I am trying to create a simple DSSS Modem, similar to the that > > described inhttp://www.altera.com/literature/fs/fs14_dsss.pdf > > The type of spreading sequence does not matter. Gold codes are the > > easiest to implement on a Xilinx FPGA using the SLR16 macro. > > > >> So you don't know how to multiply a complex number by a real number or what? > > > I know that the complex spreading sequence has c_r and c_i codewords. > > c_r is a gold code obviously, but is c_i = 0 or is it another gold > > code? That was the question really. I know how to multiply a real > > number with a complex number. > > > John thanks for the answer. However Jerry said yes to my initial > > thoughts that c_i = 0. Thanks for that as well. Maybe it is dependent > > on the application? However it does not look like this is the place to > > find that out. > > > Thanks for the replies. > > Jaco > > Even if the imaginary spreading code is zero at the transmitter, which > as I said before is not the typical case, you will not want to > despread with zero imaginary at the receiver. This is because the > complex received signal is in general scaled and rotated by the > channel. Despread the real and imaginary both by the real spreading > code used in transmit. The resulting peaks will look like Aexp(j*phi) > and -Aexp(j*phi) where phi is the phase shift seen in the channel and > A is related to channel gain and transmit power. > > JohnThanks for all the help, Jaco
Practical use of Gold Codes
Started by ●September 25, 2007
Reply by ●September 27, 20072007-09-27
