req help
Started by minu January 28, 2008
hello
i am a final yr project student, and i have to develop c language
codes for am and fm demodulation ... i will have to create a dll file
which can bbe accessed by labview for display.
i could not find any specific directives towards software
implementation of am/fm demodulation...can somebody pls help me out?
On Sun, 27 Jan 2008 20:51:18 -0800, minu wrote:
> hello > > i am a final yr project student, and i have to develop c language codes > for am and fm demodulation ... i will have to create a dll file which > can bbe accessed by labview for display. > > i could not find any specific directives towards software implementation > of am/fm demodulation...can somebody pls help me out?
Is English perhaps your second language? It sounds like you want to have the answer handed to you on a platter -- wouldn't that defeat the purpose of a senior project? I suggest that you go find some references on the web that include block diagrams of FM and AM demodulators, then implement them in code. Alternately, an ARRL (or, I believe, an RSGB) Handbook should have such block diagrams. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
minu wrote:
> hello > > i am a final yr project student, and i have to develop c language > codes for am and fm demodulation ... i will have to create a dll file > which can bbe accessed by labview for display. > > i could not find any specific directives towards software > implementation of am/fm demodulation...can somebody pls help me out?
This is really two problems: (1) find appropriate _algorithms_ for AM/FM demodulation - easy to do via a search engine (2) implement these algorithms in C in the form of a DLL - straightforward C programming task If you approach this one problem at a time then you should find it a lot easier. Good luck, Paul
