doubts in the design of FIR filter
Started by faz May 29, 2008
Dear all,
I have some doubts in the design of FIR filter...pls clarify
1.Can i set  the clock frequency of the FIR filter at any frequency i
want but pretty much higher than the sample rate?
  for example :Fc=3.5khz
                    Fs=8khz
         can i clock as any value >8khz say 1Mhz(considering the max
clock for target device)
2.For 256 taps ..Which is the best FIR filter design method for lower
cut off frequncies say upto 100khz and for higher cut off frequency
range say from Mhz to Ghz??
3.Whether direct form non-symmetric filter structure can support
symmetric coefficients??whether the response computed is same as
symmetric filter structure??
4.In addition to impulse test(basic test to check FIR filter
operation),step test,sine wave test.What are other test that has to be
compulsorily performed in time domain to check the proper working
filter operation before giving any arbitary input to the filter??
regards,
faz
On 29 Mai, 10:22, faz <fazulu.v...@gmail.com> wrote:
> Dear all, > > I have some doubts in the design of FIR filter...pls clarify > > 1.Can i set &#4294967295;the clock frequency of the FIR filter at any frequency i > want but pretty much higher than the sample rate? > &#4294967295; for example :Fc=3.5khz > &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; Fs=8khz > &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;can i clock as any value >8khz say 1Mhz(considering the max > clock for target device)
This is a question on hardware, not FIR design. One does not 'set the clock frequency' of a FIR filter. One specifies the sampling frequency of the system and works out the frequency response from there. If there is a restriction on the clock frequency wrt sampling frequency, it will be determined by hardware considerations.
> 2.For 256 taps ..Which is the best FIR filter design method for lower > cut off frequncies say upto 100khz and for higher cut off frequency > range say from Mhz to Ghz??
The question doesn't make sense. Filters are designed in terms of normalized frequency responses, not the number of coefficients or frequency range.
> 3.Whether direct form non-symmetric filter structure can support > symmetric coefficients??whether the response computed is same as > symmetric filter structure??
Again, that's a hardware-specific question. I have no particular knowledge about what is smart to do in hardware, but if a system *requires* FIRs to be symmetric it will be because one wants so save some area or memory on an IC by re-using internal data or adders/multipliers. There is no conceptual difference between symmetric and non-symetric FIRs.
> 4.In addition to impulse test(basic test to check FIR filter > operation),step test,sine wave test.What are other test that has to be > compulsorily performed in time domain to check the proper working > filter operation before giving any arbitary input to the filter??
None in particular, that I can think of. You might want to have a look at finite-word-length effects if you use fixed- point arithmetics, but FIRs ought to be straightforward. Rune
hai,
Rune:One specifies the sampling frequency of the system and works out
the frequency
faz:Again this sampling frequency depends on the max.frequency of
input signal and in the application where we use this filter..
Rune:There is no conceptual difference between symmetric and non-
symetric FIRs.
Faz:Structure and implementation resources wise both are different.But
might be response wise both are same..
Rune: Filters are designed in terms of normalized frequency responses
Faz:Ok,for normalized LP frequency response which filter design method
is most suited??
Rune:None in particular, that I can think of.
faz:How about checking with random white noise input?
regards,
faz
Rune Allnor wrote:
> On 29 Mai, 10:22, faz <fazulu.v...@gmail.com> wrote: > > Dear all, > > > > I have some doubts in the design of FIR filter...pls clarify > > > > 1.Can i set &#65533;the clock frequency of the FIR filter at any frequency i > > want but pretty much higher than the sample rate? > > &#65533; for example :Fc=3.5khz > > &#65533; &#65533; &#65533; &#65533; &#65533; &#65533; &#65533; &#65533; &#65533; &#65533; Fs=8khz > > &#65533; &#65533; &#65533; &#65533; &#65533;can i clock as any value >8khz say 1Mhz(considering the max > > clock for target device) > > This is a question on hardware, not FIR design. One does not > 'set the clock frequency' of a FIR filter. One specifies the > sampling frequency of the system and works out the frequency > response from there. > > If there is a restriction on the clock frequency wrt sampling > frequency, it will be determined by hardware considerations. > > > 2.For 256 taps ..Which is the best FIR filter design method for lower > > cut off frequncies say upto 100khz and for higher cut off frequency > > range say from Mhz to Ghz?? > > The question doesn't make sense. Filters are designed in terms > of normalized frequency responses, not the number of coefficients > or frequency range. > > > 3.Whether direct form non-symmetric filter structure can support > > symmetric coefficients??whether the response computed is same as > > symmetric filter structure?? > > Again, that's a hardware-specific question. I have no particular > knowledge about what is smart to do in hardware, but if a system > *requires* FIRs to be symmetric it will be because one wants so > save some area or memory on an IC by re-using internal data > or adders/multipliers. > > There is no conceptual difference between symmetric and > non-symetric FIRs. > > > 4.In addition to impulse test(basic test to check FIR filter > > operation),step test,sine wave test.What are other test that has to be > > compulsorily performed in time domain to check the proper working > > filter operation before giving any arbitary input to the filter?? > > None in particular, that I can think of. You might want to > have a look at finite-word-length effects if you use fixed- > point arithmetics, but FIRs ought to be straightforward. > > Rune
