Hai, Basically i am little bit confused with FIR filter cutoff frequency and sampling frequency relation....Both the terms are very much familier to me separately but i dont know how to relate each other?? Few standard sampling frequencies for audio applications are 8,44.1,48,96,192Khz...For this sampling frequencies wat should be the minimum cutoff frequency for LP,HP,BP,BR FIR filter.... example fs=8khz...fc=??? regards, faz
cutoff and sampling frequency
Started by ●June 1, 2008
Reply by ●June 1, 20082008-06-01
Hai, Continuation to the above questions....As per sampling theorem fs>2fm (where fm-maximum input freq.) to avoid aliasing... Should i have to follow this relation for cutoff frequency also ....i mean fs>2fc(where fc is the cutoff frequency) or in wat way i should assume the sampling frequency for any specific cutoff frequency will they related or not?? regards, faz On Jun 1, 4:35�pm, faz <fazulu.v...@gmail.com> wrote:> Hai, > > Basically i am little bit confused with FIR filter cutoff frequency > and sampling frequency relation....Both the terms are very much > familier to me separately but i dont know how to relate each other?? > > Few standard sampling frequencies for audio applications are > 8,44.1,48,96,192Khz...For this sampling frequencies wat should be the > minimum cutoff frequency for LP,HP,BP,BR FIR filter.... > > example fs=8khz...fc=??? > > regards, > faz
faz wrote:> Hai, > > Basically i am little bit confused with FIR filter cutoff frequency > and sampling frequency relation....Both the terms are very much > familier to me separately but i dont know how to relate each other?? > > Few standard sampling frequencies for audio applications are > 8,44.1,48,96,192Khz...For this sampling frequencies wat should be the > minimum cutoff frequency for LP,HP,BP,BR FIR filter.... > > example fs=8khz...fc=???fc = any frequency up to fs/2. Consider only signals that extend to (or very near to) DC. Any sample rate is possible provided that it exceeds twice the highest frequency if the signal. That requirement is often met by using an analog low-pass filter before the signal is digitized. The designer chooses the cutoff frequency of a filter to suit his purpose. It is a fraction of the sample rate, so that the same filter used in a system with, say, twice the sample rate will have double the cutoff frequency. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
faz wrote:> Hai, > > Continuation to the above questions....As per sampling theorem fs>2fm > (where fm-maximum input freq.) to avoid aliasing... > > Should i have to follow this relation for cutoff frequency also ....i > mean fs>2fc(where fc is the cutoff frequency) or in wat way i should > assume the sampling frequency for any specific cutoff frequency will > they related or not??For a sample frequency fs, all components of the signal are less than fs/2. Of course, the cutoff frequency and all other significant frequencies also need to be less than fs/2 in order to make sense. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
faz wrote:> Hai, > > Basically i am little bit confused with FIR filter cutoff frequency > and sampling frequency relation....Both the terms are very much > familier to me separately but i dont know how to relate each other?? > > Few standard sampling frequencies for audio applications are > 8,44.1,48,96,192Khz...For this sampling frequencies wat should be the > minimum cutoff frequency for LP,HP,BP,BR FIR filter.... > > example fs=8khz...fc=??? > > regards, > fazIt's more complicated than that. The term "Cut off frequency" makes it sound like the signal will be, well, cut off. In reality a filter's stated cut off frequency may often be where the signal is a mere 3dB down from the filter's nominal pass frequency value. In fact, no finite-length, finite delay filter will give you "perfect" cut off -- the best you can ever do is reach a compromise where the filter attenuates the signals enough at the aliasing frequencies that your sound is adequate -- and different people, in different situations, have different definitions of "adequate". Read this, see if it helps you out: http://www.wescottdesign.com/articles/Sampling/sampling.html. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
On Jun 1, 5:37 am, faz <fazulu.v...@gmail.com> wrote:> Continuation to the above questions....As per sampling theorem fs>2fm > (where fm-maximum input freq.) to avoid aliasing... > > Should i have to follow this relation for cutoff frequency also ....i > mean fs>2fc(where fc is the cutoff frequency) or in wat way i should > assume the sampling frequency for any specific cutoff frequency will > they related or not??Filters which can be constructed at reasonable cost or operate with a finite time delay are not infinitely sharp. Therefore you have to leave a gap between 2fc and fs which depends on the steepness (and other characteristics) of the filter you choose, or else you will have aliasing and/or distortion near the filter's skirt. IMHO. YMMV.
Reply by ●June 2, 20082008-06-02
Ron N wrote:> On Jun 1, 5:37 am, faz <fazulu.v...@gmail.com> wrote: >> Continuation to the above questions....As per sampling theorem fs>2fm >> (where fm-maximum input freq.) to avoid aliasing... >> >> Should i have to follow this relation for cutoff frequency also ....i >> mean fs>2fc(where fc is the cutoff frequency) or in wat way i should >> assume the sampling frequency for any specific cutoff frequency will >> they related or not?? > > Filters which can be constructed at reasonable cost or operate > with a finite time delay are not infinitely sharp. Therefore > you have to leave a gap between 2fc and fs which depends on > the steepness (and other characteristics) of the filter you > choose, or else you will have aliasing and/or distortion near > the filter's skirt. > > > IMHO. YMMV.I know what you mean but, for the record, the gap is between fc and fs/2. Regards, John
John Monro wrote:> Ron N wrote:(snip)>> Filters which can be constructed at reasonable cost or operate >> with a finite time delay are not infinitely sharp. Therefore >> you have to leave a gap between 2fc and fs which depends on >> the steepness (and other characteristics) of the filter you >> choose, or else you will have aliasing and/or distortion near >> the filter's skirt.> I know what you mean but, for the record, the gap is between fc and fs/2.For a digital filter, it is only the ratio of the filter frequencies to the sample rate that matters. For analog filters, the filter complexity (order) depends on the ratio of the cutoff rate to the frequency. Since most CD players use oversampling and digital filters, it is more likely 16fc and 8fs. (Or whatever the current numbers are.) -- glen
glen herrmannsfeldt wrote:> John Monro wrote: >> Ron N wrote: > (snip) > >>> Filters which can be constructed at reasonable cost or operate >>> with a finite time delay are not infinitely sharp. Therefore >>> you have to leave a gap between 2fc and fs which depends on >>> the steepness (and other characteristics) of the filter you >>> choose, or else you will have aliasing and/or distortion near >>> the filter's skirt. > >> I know what you mean but, for the record, the gap is between fc and fs/2. > > For a digital filter, it is only the ratio of the filter frequencies > to the sample rate that matters. For analog filters, the filter > complexity (order) depends on the ratio of the cutoff rate to the > frequency. Since most CD players use oversampling and digital > filters, it is more likely 16fc and 8fs. (Or whatever the > current numbers are.) > > -- glen >Glen,I can't grasp the point you are making here. It appears that you are saying that the filter order is 16fc and 8fs, which is clearly not correct. Regards, John
Reply by ●June 6, 20082008-06-06
John Monro wrote: (snip)>> For a digital filter, it is only the ratio of the filter frequencies >> to the sample rate that matters. For analog filters, the filter >> complexity (order) depends on the ratio of the cutoff rate to the >> frequency. Since most CD players use oversampling and digital >> filters, it is more likely 16fc and 8fs. (Or whatever the >> current numbers are.)> Glen,I can't grasp the point you are making here. It appears that you > are saying that the filter order is 16fc and 8fs, which is clearly not > correct.Yes, I didn't explain it very well. It is usual in CD players to use digital filters to generate a signal with a much higher sampling rate, and use analog filters on the result. Described in terms of the original sample rate, fs, the filter cutoff will be much higher. I don't know what the current state-of-the-art is for CD players, though. -- glen
