On Thu, 26 Nov 2015 07:05:41 -0600, "Sharan123" <99077@DSPRelated> wrote:>Thanks, everyone > >I have a couple of follow-up questions based on responses above ... > >1) if we take 2 orthogonal signals and then multiply them individually >with some other signal then I assume that the resulting signals maintain >orthogonality. Is this correct? > >2) From the posts above, I understand that if a transmitted signal is >composed of orthogonal signals then it is easier to recover individual >signals. Is this correct?In 2), what really do you mean? The I and Q components of a typical communication signal are orthogonal to each other, which is a good thing since it doubles the spectral efficiency of the signal. Or are you thinking of spreading with orthogonal codes, like a CDMA system? Not quite sure what you have in mind, which makes it hard to provide a useful answer. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Orthogonol signals
Started by ●November 24, 2015
Reply by ●November 26, 20152015-11-26
Reply by ●November 27, 20152015-11-27
On Thu, 26 Nov 2015 07:05:41 -0600, Sharan123 wrote:> Thanks, everyone > > I have a couple of follow-up questions based on responses above ... > > 1) if we take 2 orthogonal signals and then multiply them individually > with some other signal then I assume that the resulting signals maintain > orthogonality. Is this correct?Ooh, good question. In general, no. For a lot of practical problems, yes -- this is how modulation works. But it has to be designed in (or inherited from something that's worked for years).> 2) From the posts above, I understand that if a transmitted signal is > composed of orthogonal signals then it is easier to recover individual > signals. Is this correct?Pretty much. More importantly, you waste less transmitted power. If you're serious about this stuff you may want to start studying communications theory. It's not a trivial subject -- it's usually something you start studying in your 3rd year of electronics engineering, and it's built on a lot of the preceding stuff. But if you take a formal course of study you'll get ALL of the relevant detail. -- www.wescottdesign.com
>On Thu, 26 Nov 2015 07:05:41 -0600, Sharan123 wrote: > >> Thanks, everyone >> >> I have a couple of follow-up questions based on responses above ... >> >> 1) if we take 2 orthogonal signals and then multiply them individually >> with some other signal then I assume that the resulting signalsmaintain>> orthogonality. Is this correct? > >Ooh, good question. > >In general, no. For a lot of practical problems, yes -- this is how >modulation works. But it has to be designed in (or inherited from >something that's worked for years).Dear Tim & others, My question above comes from what I have been reading about OFDM. So, essentially, we have a bunch of inputs and these get modulated by sub-carriers inside OFDM modulator and what we get orthogonal signal for each sub-carrier. So, I assumed that multiplying two orthogonal signals using arbitrary signals will retain orthogonality of the signals. I have seen conflicting responses above ... --------------------------------------- Posted through http://www.DSPRelated.com
On Fri, 27 Nov 2015 09:11:09 -0600, "Sharan123" <99077@DSPRelated> wrote:>>On Thu, 26 Nov 2015 07:05:41 -0600, Sharan123 wrote: >> >>> Thanks, everyone >>> >>> I have a couple of follow-up questions based on responses above ... >>> >>> 1) if we take 2 orthogonal signals and then multiply them individually >>> with some other signal then I assume that the resulting signals >maintain >>> orthogonality. Is this correct? >> >>Ooh, good question. >> >>In general, no. For a lot of practical problems, yes -- this is how >>modulation works. But it has to be designed in (or inherited from >>something that's worked for years). > >Dear Tim & others, > >My question above comes from what I have been reading about OFDM. > >So, essentially, we have a bunch of inputs and these get modulated by >sub-carriers inside OFDM modulator and what we get orthogonal signal for >each sub-carrier. So, I assumed that multiplying two orthogonal signals >using arbitrary signals will retain orthogonality of the signals. > >I have seen conflicting responses above ...The context helps a lot, as there were otherwise multiple ways to interpret what you were asking, and therefore going off in a less relevant direction. Subcarriers in OFDM are orthogonal to each other because the basis functions of the DFT are orthogonal to each other, so each bin output is orthogonal to the other bins. So if you're asking whether the modulation of a particular subcarrier affects any of the others, it does not because the orthogonality is assured by the FFT. One could also spread the subcarriers far apart from each other, so that they obtain frequency orthogonality just by having sufficient spacing between them. The advantage of using the FFT is that they are packed in frequency essentially as tightly as possible so that much less bandwidth is required, i.e., no guard bands between the subcarriers. Remember that a subcarrier's modulation is constant for the duration of the "symbol", i.e., the entire FFT length, and as long as that is true the magnitude and phase of the subcarrier can be whatever you want it to be. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Reply by ●November 28, 20152015-11-28
>The context helps a lot, as there were otherwise multiple ways to >interpret what you were asking, and therefore going off in a less >relevant direction.Dear Eric, I understand. I will take care in future postings.>Remember that a subcarrier's modulation is constant for the duration >of the "symbol", i.e., the entire FFT length, and as long as that is >true the magnitude and phase of the subcarrier can be whatever you >want it to be.While we are on the OFDM and FFT topic, I would like clarify something about FFT used for OFDM. Is iFFT specifically designed to handle 15 KHz subcarrier spacing and sub-carrier bandwidth? If not, how is this taken care? --------------------------------------- Posted through http://www.DSPRelated.com
On Sat, 28 Nov 2015 12:11:46 -0600, "Sharan123" <99077@DSPRelated> wrote:>>The context helps a lot, as there were otherwise multiple ways to >>interpret what you were asking, and therefore going off in a less >>relevant direction. > >Dear Eric, > >I understand. I will take care in future postings. > >>Remember that a subcarrier's modulation is constant for the duration >>of the "symbol", i.e., the entire FFT length, and as long as that is >>true the magnitude and phase of the subcarrier can be whatever you >>want it to be. > >While we are on the OFDM and FFT topic, I would like clarify something >about FFT used for OFDM. Is iFFT specifically designed to handle 15 KHz >subcarrier spacing and sub-carrier bandwidth? If not, how is this taken >care?The size of the FFT and the output sample rate. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
>>The context helps a lot, as there were otherwise multiple ways to >>interpret what you were asking, and therefore going off in a less >>relevant direction. > >Dear Eric, > >I understand. I will take care in future postings. > >>Remember that a subcarrier's modulation is constant for the duration >>of the "symbol", i.e., the entire FFT length, and as long as that is >>true the magnitude and phase of the subcarrier can be whatever you >>want it to be. > >While we are on the OFDM and FFT topic, I would like clarify something >about FFT used for OFDM. Is iFFT specifically designed to handle 15 KHz >subcarrier spacing and sub-carrier bandwidth? If not, how is this taken >care? > >--------------------------------------- >Posted through http://www.DSPRelated.comIn your other thread on ifft I posted: 15KHz comes from 7.68MHz/512 (for lte 5MHz as example) so what determines 15KHz???? Kaz --------------------------------------- Posted through http://www.DSPRelated.com
On Sat, 28 Nov 2015 14:36:15 -0600, "kaz" <37480@DSPRelated> wrote:>>>The context helps a lot, as there were otherwise multiple ways to >>>interpret what you were asking, and therefore going off in a less >>>relevant direction. >> >>Dear Eric, >> >>I understand. I will take care in future postings. >> >>>Remember that a subcarrier's modulation is constant for the duration >>>of the "symbol", i.e., the entire FFT length, and as long as that is >>>true the magnitude and phase of the subcarrier can be whatever you >>>want it to be. >> >>While we are on the OFDM and FFT topic, I would like clarify something >>about FFT used for OFDM. Is iFFT specifically designed to handle 15 KHz >>subcarrier spacing and sub-carrier bandwidth? If not, how is this taken >>care? >> >>--------------------------------------- >>Posted through http://www.DSPRelated.com > >In your other thread on ifft I posted: > >15KHz comes from 7.68MHz/512 (for lte 5MHz as example) > >so what determines 15KHz???? > >KazIn the modulator, the length of the FFT and the sample rate via the usual relationship of df = fs/N, where df is the bin spacing, fs is the sample rate and N is the FFT size. It's no different than sorting out the bin width for any other FFT application. Since the spec dictates a 15kHz subcarrier spacing, for the N = 512 case the effective output sample rate (barring interpolation for signal conditioning, etc.), is then fs = 15e3*512 = 7.68MHz. There's a table of the rates here: http://lteuniversity.com/ask_the_expert/f/59/t/2636.aspx Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Reply by ●November 29, 20152015-11-29
On Sat, 28 Nov 2015 14:36:15 -0600, "kaz" <37480@DSPRelated> wrote:>>>The context helps a lot, as there were otherwise multiple ways to >>>interpret what you were asking, and therefore going off in a less >>>relevant direction. >> >>Dear Eric, >> >>I understand. I will take care in future postings. >> >>>Remember that a subcarrier's modulation is constant for the duration >>>of the "symbol", i.e., the entire FFT length, and as long as that is >>>true the magnitude and phase of the subcarrier can be whatever you >>>want it to be. >> >>While we are on the OFDM and FFT topic, I would like clarify something >>about FFT used for OFDM. Is iFFT specifically designed to handle 15 KHz >>subcarrier spacing and sub-carrier bandwidth? If not, how is this taken >>care? >> >>--------------------------------------- >>Posted through http://www.DSPRelated.com > >In your other thread on ifft I posted: > >15KHz comes from 7.68MHz/512 (for lte 5MHz as example) > >so what determines 15KHz???? > >KazI answered previously with the technical implementation answer, but it occurred to me that you might be asking why 15kHz was chosen for the subcarriers. The short answer is because the spec says so. My guess as to why the spec says so is that it provided a good solution for the tradeoff space that they (i.e., the standard working group) were managing given the channel models for the expected environments. Too narrow and the system becomes susceptible to phase noise, too wide and the subcarrier fading in the encountered channels may not be flat (which defeats the purpose of OFDM). Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
Reply by ●December 1, 20152015-12-01
>Hello, > >I would like to know definition of orthogonal signals and why they are >significant in communication? > >Thanks, >--------------------------------------- >Posted through http://www.DSPRelated.comOrthogonal signals integrate to zero, interchangeably their dot product are zero. We can obtain find them by solving Sturm–Liouville differential equations. They are important in detection. when we want to demodulate the signal to detect the symbols, this orthogonality helps us to separate the I and Q. If we multiply the received signal by one of the basis functions all other terms will add up to zero. --------------------------------------- Posted through http://www.DSPRelated.com
