On 25.11.2015 15:25, Steve Pope wrote:> kaz <37480@DSPRelated> wrote: > >> [attribution lost] wrote, > >>> Orthogonal means that if you multiply them, multiply by a weight >>> function (which might be one) and integrate over the appropriate >>> interval, the result is zero. > >> Does this apply to say sine/cosine waveforms. I generated 2^20 samples >> each. multiplied them and integrated but can't see the above definition >> apply. What am I missing? > > Except for truncation errors you should get zero correlation > between a sine and a cosine of the same frequency.... and between any sine or cosine of different (positive)frequencies> > If you get a non-zero value, compare it to the correlation of > just the sine signal with itself; the latter value should be > much much larger. > > Steve >
Orthogonol signals
Started by ●November 24, 2015
Reply by ●December 10, 20152015-12-10
