Using correlation to find the right group delay compensation for a FIR
Started by arturi November 21, 2007
Hello,
I am filtering a test signal (Tsig) with a FIR and then calculating the
RMS error against a reference signal (Ref).
The FIR adds a group delay to my test signal which needs to be compensated
before I can calculate the error.
For an FIR, I believe that delay compensation should be N/2, where N is
the number of taps, or filter order.
After looking carefully at the waveforms I see that I can still fine tune
the group delay compensation. Is there a way to mathematically find the
perfect group delay compensation required?
Can I use the correlation between Tsig and Ref to find out the best group
compensation? If yes, how?
cheers
arturi wrote:
> Hello, > > I am filtering a test signal (Tsig) with a FIR and then calculating the > RMS error against a reference signal (Ref). > > The FIR adds a group delay to my test signal which needs to be compensated > before I can calculate the error. > > For an FIR, I believe that delay compensation should be N/2, where N is > the number of taps, or filter order. > > After looking carefully at the waveforms I see that I can still fine tune > the group delay compensation. Is there a way to mathematically find the > perfect group delay compensation required? > > Can I use the correlation between Tsig and Ref to find out the best group > compensation? If yes, how?
Only a symmetric FIR has a constant group delay. For any FIR, the delay is (N-1)/2. A symmetric FIR with an odd number of taps is needed to get an integer delay. For such a filter, the properly delayed signal is available at the middle tap. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Only a symmetric FIR has a constant group delay. For any such FIR, the delay ^^^^
> is (N-1)/2. A symmetric FIR with an odd number of taps is needed to get > an integer delay. For such a filter, the properly delayed signal is > available at the middle tap. > > Jerry
My head hurts from too much thinking, so I use brute force:
http://www.dsprelated.com/showarticle/26.php
-mn
>Jerry Avins wrote: > > ... > >> Only a symmetric FIR has a constant group delay. For any FIR, the delay
> >Only a symmetric FIR has a constant group delay. For any such FIR, the >delay ^^^^ >> is (N-1)/2. A symmetric FIR with an odd number of taps is needed to get
>> an integer delay. For such a filter, the properly delayed signal is >> available at the middle tap. >> >> Jerry > > >-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >
Thanks Jerry! I forgot to mention that my test signal is being zero order held before filtering. The ZOH is also inserting a group delay which needs to be compensated, that was actually confusing me. cheers
arturi wrote:
>> Jerry Avins wrote: >> >> ... >> >>> Only a symmetric FIR has a constant group delay. For any FIR, the delay > >> Only a symmetric FIR has a constant group delay. For any such FIR, the >> delay ^^^^ >>> is (N-1)/2. A symmetric FIR with an odd number of taps is needed to get > >>> an integer delay. For such a filter, the properly delayed signal is >>> available at the middle tap.
> I forgot to mention that my test signal is being zero order held before > filtering. The ZOH is also inserting a group delay which needs to be > compensated, that was actually confusing me.
What are you comparing against? If I'm thinking clearly, the ZOH is a half-sample delay. Are you comparing analog signals? If not an ADC's output, what is the ZOH for? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
