One of the properties of the FT is f(-t) <-------> F(-w) Does this mean that if we take the FFT of a signal and compute F(-w) then inverse FFT we have a reverse-time representation? K
Fourier Transform Question
Started by ●July 23, 2008
Reply by ●July 23, 20082008-07-23
>One of the properties of the FT is > > >f(-t) <-------> F(-w) > >Does this mean that if we take the FFT of a signal and compute F(-w) >then inverse FFT we have a reverse-time representation? > > >KThat's a property of the Fourier transform, not the discrete Fourier transform. So no. Also, when you take the FFT of a signal, you don't get F in w (omega), you get a discrete function. Take a look at a table of DFT properties. For DFTs x[-n] <---> X*[k]
Reply by ●July 24, 20082008-07-24
kronecker@yahoo.co.uk wrote:> Does this mean that if we take the FFT of a signal and compute F(-w) > then inverse FFT we have a reverse-time representation?See: http://en.wikipedia.org/wiki/Nonlinear_optics#Optical_phase_conjugation It can be done with real (optical) signals. Even more, it is possible to build a phase conjugate mirror with gain, such that the time reversed signal has a larger amplitude than the signal going in. -- glen
