There have occasionally been threads here on visual presentation of displaying time sequential spectra. Spectrograms (gray scale or color) are very popular. [e.g. http://en.wikipedia.org/wiki/Image:Praat-spectrogram-tatata.png ] I sat for many hours in front of RF spectrum analyzers, so I'm not oriented to that format. Scilab is free and has reasonable graphics, so I wrote my own. I post it (as it is relatively short) as some might find it useful and with hope of constructive comments. Enjoy. // A 3D alternative to spectrogram popular in speech recognition and related fields // (q.v. // http://en.wikipedia.org/wiki/Image:Praat-spectrogram-tatata.png // http://en.wikipedia.org/wiki/Spectrogram ) // Richard Owlett (rowlett@atlascomm.net) Aug 6,2008 meg = 1000000; // I like to look at ridiculously large data sets stacksize(10 * meg); set("old_style","off"); // force new graphics mode as default datafile = xgetfile('*.wav','C:\ATEST\',title = 'Chose an input WAV file') [data,y] = loadwave(datafile); maxpoints = y(7)/2; rate = y(3); time_plot = scf(); plot2d((1:maxpoints)/rate,data) // menu for choosing fft parameters labels=["First Window";"Last Window";"Window Offset";"Window Width"]; [ok,t0,tlast,toffset,twidth]=getvalue("Define FFT parameters (all times in seconds)", ... labels, list("vec",1,"vec",1,"vec",1,"vec",1),["0.";"1.";".01";".05";]); // t0 -- start time of first fft window // tlast -- start time of last fft window // toffset -- offset between each window // twidth -- fft window width n0 = max(int(t0*rate),1); // start point offset = int(toffset*rate); // offset in points width = int(twidth*rate); // window width 1024 points nw = int((tlast-t0)/twidth); // max number of fft's nc = int(width/2); // other half of fft is redundant zz = 1; deltapoints = width-1; while zz <= nw; stpoint = (zz-1) * deltapoints + n0; endpoint = stpoint + deltapoints; if (maxpoints >= endpoint) then v = data(stpoint:endpoint) .* window('kr',width,8.6) ; aa = abs(fft(v,1)); f(zz,1:nc) = aa(1:nc); xx(zz,1:nc)=zz; end zz = zz+1; end; maxf = rate * .0005; // plot spectrum in kHz nr=size(f,1); bb = [1:nc]; yy = bb(ones([1:nr]),:); spectra_plot =scf(); drawlater // postpone drawing to avoid annoying redraws param3d1(xx', yy' * maxf/nc , 10 * f'/max(f)) a=get("current_axes"); //get the handle of the newly created axes a.axes_reverse = ["on","off","off"]; a.data_bounds = [t0,0,0;nw,int(maxf),10]; // a.x_ticks.locations // reminder to improve visuals a.x_ticks.labels = string(t0+toffset*(a.x_ticks.locations-1)); h=a.children; //get the handle of the param3d entity: an Compound composed of nr curves h.children(:).mark_mode="on"; h.children(:).line_mode="off"; h.children(:).mark_style = 0; h.children(:).mark_size=0; xset("fpf"," ") // null labels for each contour contour(xx(:,1) ,yy(1,:)* maxf/nc ,10 * f/max(f),4,flag=[0 0 4]) drawnow
Started by ●August 6, 2008
