Richard Owlett wrote:> Rune Allnor wrote: > >> On 14 Aug, 23:50, Richard Owlett <rowl...@atlascomm.net> wrote: >> >>> Rune Allnor wrote: >> >> >> ... >> >>>>> Success *GRIN* >>>>> ;)http://www.virtual-bird.com/songs/gavia-arctica.mp3givesa very nice >>>>> display. I'll post some samples as soon as my ISP solves a glitch. >> >> >> ... >> >>>>> Rune, you mentioned having used a spectrogram to demonstrate >>>>> overtones. >>>>> I didn't spot any with the loon recording I used. What did you use? >>> >>> >>>> A standard spectrogram. The frequency range was 0-5kHz, if I remember >>>> correctly, and that was sufficient bandwidth to see the overtones. >>> >>> >>> I'll have to find a better recording. The background noise has a sharp >>> drop-off ~3-3.5 kHz but there is relatively strong blip 7.1-7.3 kHz. I'm >>> suspicious that it's an artifact rather than a signal. >> >> >> >> If I interpret the link you posted correctly, you've used an MP3 >> file. >> That might not be the best choise, as MP3s have been beaten and >> battered >> in all sorts of ways to compress the sound. >> >> Try and see if you can find a .wav file. >> >> Rune > > > Chuckle ;) I had found a .wav file but chose to to use the .mp3 file > because it sounded "cleaner". >Tried the .wav file I had. I was as bad as it sounded. But the noise did display nicely ;/
Vocal glissandro as swept frequency source
Started by ●August 11, 2008
Reply by ●August 15, 20082008-08-15
Rune Allnor wrote:> On 14 Aug, 18:51, Richard Owlett <rowl...@atlascomm.net> wrote: > >>Rune, you mentioned having used a spectrogram to demonstrate overtones. >>I didn't spot any with the loon recording I used. What did you use? > > > A standard spectrogram. The frequency range was 0-5kHz, if I remember > correctly, and that was sufficient bandwidth to see the overtones. >After a little more experimentation, I'm going to guess your spectrogram was based on log(intensity). I was doing things linear. A side effect of Scilab's contour() limited me to a 30:1 dynamic range. I tried a log(intensity) approach and saw some additional structure at the expense of a horrible redisplay time. There was also an annoying amount of background clutter. That made me realize that my real objection to spectrograms wasn't to displaying intensity by shade/color but to their cluttered appearance. I'm also getting some better quality recordings. The local library has a CD with recordings by the Cornell Laboratory of Ornithology and the Borror Laboratory of Bioacoustics. www.google.com/search?q=birds%20recording%20wav%20-mp3 also gives some useful hits.
