Hi, It is clear that OFDM systems may have different SNR values for each subcarrier due to frequency selectivity of the channel. If an OFDM packet consists of n number of FEC blocks and in case of adaptive modulation and coding systems, a single FEC block may have different modulation scheme. However, is it possible for OFDM (e.g.IEEE 802.11a/n) systems that the block error probability of FEC blocks differ within the same packet? Also, is that possible to have different subcarrier allocation for different FEC blocks in a packet? Say for example first FEC blocks contains subcarriers 1,2,3; second FEC block contains 3,4 and so on. Thanks!
OFDM system
Started by ●August 28, 2008
Reply by ●August 28, 20082008-08-28
On Thu, 28 Aug 2008 13:03:34 -0500, "patrick_dbg" <sanindland@gmail.com> wrote:>Hi, > >It is clear that OFDM systems may have different SNR values for each >subcarrier due to frequency selectivity of the channel. If an OFDM packet >consists of n number of FEC blocks and in case of adaptive modulation and >coding systems, a single FEC block may have different modulation scheme. >However, is it possible for OFDM (e.g.IEEE 802.11a/n) systems that the >block error probability of FEC blocks differ within the same packet? Also, >is that possible to have different subcarrier allocation for different FEC >blocks in a packet? Say for example first FEC blocks contains subcarriers >1,2,3; second FEC block contains 3,4 and so on. > >Thanks!I think I understand the gist of your question, but if I don't, please feel free to clarify. First, 802.11 does not use subcarrier adaptation like you are describing. Nevertheless, just from an academice perspective, it is certainly possible to do what you describe and systems have been proposed that operate that way. If a block-oriented FEC is used and there is dynamic fading in the channel, then even if a constant modulation and code rate is used it is possible for the fading to affect each block differently. So even with constant modulation and coding the probability of block error can differ between FEC blocks. And if the modulation and coding is adapted differently between FEC blocks then the probability of error will very likely be different between blocks. The adaptation criterion and algorithm used would have a big effect on how the modulation and code was selected, so the performance would depend a lot on the adaptation algorithm. I hope that provides some insight. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Reply by ●September 9, 20082008-09-09
>I think I understand the gist of your question, but if I don't, please >feel free to clarify. > >First, 802.11 does not use subcarrier adaptation like you are >describing. Nevertheless, just from an academice perspective, it is >certainly possible to do what you describe and systems have been >proposed that operate that way. > >If a block-oriented FEC is used and there is dynamic fading in the >channel, then even if a constant modulation and code rate is used it >is possible for the fading to affect each block differently. So even >with constant modulation and coding the probability of block error can >differ between FEC blocks. > >And if the modulation and coding is adapted differently between FEC >blocks then the probability of error will very likely be different >between blocks. The adaptation criterion and algorithm used would >have a big effect on how the modulation and code was selected, so the >performance would depend a lot on the adaptation algorithm. > >I hope that provides some insight. > > >Eric Jacobsen >Minister of Algorithms >Abineau Communications >http://www.ericjacobsen.org > >Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php >I once again thank you for your response. Is IEEE 802.11a/n transmits encoded bits blockwise (several blocks in a packet for a user)? Then, what will the real meaning for block error probability, if I get acknowledge for packets that I have sent? Thanks a lot!
