Is the sole criterion for two signals to be orthogonal a cross correlation type relationship? Could two signals that have some frequency cancellation when added together still be viewed as orthogonal? For example. if x(t) has fourier transform X(f), which has a magnitude of 1 over some BW, B. And y(t) has fourier transform Y(f), has a magnitude of 1 over the same band. If the sole requirement for signals to be orthogonal is int(x(t)*y(t))dt = 0 over a time interval and x(t)^2 + y(t)^2 = (x(t)+y(t))^2., this is an enery/power like criterion' and the equation doesnt necessarily say X(f)+Y(f) have to equal 1.41 over that the bandwith B. The equation just alludes to the energy in the 2 singals needing to be preseved, not necessarily the energy in any one particular frequency. Could there be frequency cancellation/addtion in X(f)+Y(f) and the signals still be deemed orthogonal as long as the power is conserved? I hope im asking this question the right way..
Orthogonal Signals Question
Started by ●October 9, 2008
Reply by ●October 9, 20082008-10-09
On Oct 9, 10:03�am, "westocl" <cwest...@hotmail.com> wrote:> Is the sole criterion for two signals to be orthogonal a cross correlation > type relationship? Could two signals that have some frequency cancellation > when added together still be viewed as orthogonal?I dont think any canceallation would occur, because that would imply that one of them has a component projected into the other's space. I can see a frequency addition taking place (as the vector sum increases because the two signals are orthogonal) but I cannot see a subtraction. I might be mistaken here though. Look at the sine and cosine as an example, the amplitude of their sums (or difference) is always bigger than their individual components.
On Oct 9, 9:03�am, "westocl" <cwest...@hotmail.com> wrote:> Is the sole criterion for two signals to be orthogonal a cross correlation > type relationship? Could two signals that have some frequency cancellation > when added together still be viewed as orthogonal? > > For example. if x(t) has fourier transform X(f), which has a magnitude of > 1 over some BW, B. And y(t) has fourier transform Y(f), has a magnitude of > 1 over the same band. > > If the sole requirement for signals to be orthogonal is int(x(t)*y(t))dt = > 0 over a time interval and x(t)^2 + y(t)^2 = (x(t)+y(t))^2., this is an > enery/power like criterion' and the equation doesnt necessarily say > X(f)+Y(f) have to equal 1.41 over that the bandwith B. The equation just > alludes to the energy in the 2 singals needing to be preseved, not > necessarily the energy in any one particular frequency.You seem to have an unusual definition of orthogonality. If [x(t)]^2 + [y(t)]^2 = [x(t) + y(t)]^2 for all t, then it must be that for each value of t, x(t)y(t) = 0, that is, at least one of the two signals is 0. If this is so, then obviously int(x(t)*y(t))dt = 0 over *any* time interval because the integrand is always 0. A less restrictive (and very much more widely accepted) definition of orthogonality (for all time or over some specified time interval) is that the inner product int(x(t)*y(t))dt have value 0 where the integral is over all time, or over the specified time interval, whichever is appropriate.
Reply by ●October 12, 20082008-10-12
westocl wrote:> Is the sole criterion for two signals to be orthogonal a cross correlation > type relationship? Could two signals that have some frequency cancellation > when added together still be viewed as orthogonal?> For example. if x(t) has fourier transform X(f), which has a magnitude of > 1 over some BW, B. And y(t) has fourier transform Y(f), has a magnitude of > 1 over the same band.> If the sole requirement for signals to be orthogonal is int(x(t)*y(t))dt = > 0 over a time interval and x(t)^2 + y(t)^2 = (x(t)+y(t))^2.,The ones I am used to have a w(t) weighting term. It is often 1, but in some cases it is another function. http://en.wikipedia.org/wiki/Orthogonal#Orthogonal_functions -- glen
