Hi all...
I am pretty new to signal processing...
Let say we sample a band limited signal... So the spectrum
of the sampled signal will have spectral replications of the band
limited signal and multiples of the Sampling frequency...
So in this case the resulting signal seems to have more
energy... since its spectrum is large compared to the bandpass signal
and the sampling impulse train... How does this happen...? From where
does this resulting signal get its energy from...? I think mostly
sampling circuits don't provide energy to the signals...!
Does this have anything to do with Power Spectral density
Vs FFT...? will FFT of the sampled signal be different from that of
its PSD...?
Thanks
Enery conservation during Sampling
Started by ●October 17, 2008
Reply by ●October 17, 20082008-10-17
Very good. It seems you just found the solution to the energy problem of America by digitizing a bandlimited signal. It is even better than a perpetual motion machine... My further question is, why do you want to conserve it? Let's just use it up. James www.go-ci.com
On Thu, 16 Oct 2008 22:24:55 -0700, lordsathish wrote:> Hi all... > I am pretty new to signal processing... > Let say we sample a band limited signal... So the spectrum > of the sampled signal will have spectral replications of the band > limited signal and multiples of the Sampling frequency... > So in this case the resulting signal seems to have more > energy... since its spectrum is large compared to the bandpass signal > and the sampling impulse train... How does this happen...? From where > does this resulting signal get its energy from...? I think mostly > sampling circuits don't provide energy to the signals...! > Does this have anything to do with Power Spectral density > Vs FFT...? will FFT of the sampled signal be different from that of its > PSD...? > > ThanksYou are confusing mathematics with reality. Sampling is mathematically modeled as multiplying the continuous-time signal with a chain of impulses. Since an impulse has infinite energy, a chain of impulses has infinite power. This is where your confusion comes in: you can't _really_ multiply a continuous-time signal with a chain of impulses, because no one can generate a chain of impulses, nor can anyone build a multiplier that would do anything useful with an impulse as an input. The _model_ has you multiplying the signal with a chain of impulses, but the _reality_ is that you measure the value of the signal around your chosen sampling instant, then do something with it (usually do an analog to digital conversion). If you try to do your mathematical analysis while leaving the sampling process all bound up with the reality of what you're doing you'll find the going very rough -- so you model the "ideal" sampled signal, then you model the rest of the signal processing chain. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
On 17 Okt, 07:24, lordsathish <lordsath...@gmail.com> wrote:> Hi all... > I am pretty new to signal processing... > � � � � � � Let say we sample a band limited signal... So the spectrum > of the sampled signal will have spectral replications of the band > limited signal and multiples of the Sampling frequency...Nope. The mathematical mappings back and forth between continuous time (CT) and discrete time (DT) domains are ambiguous. Unless one imposes some additional constraint (baseband or bandpass sampling) one can't tell which 'spectral mirror' corresponds to the physical signal and which are 'artificial'. Unless Nyquist's condition is satisfied one does not know whether the observed DT spectrum is at all relevant with respect to the CT spectrum.> � � � � � � So in this case the resulting signal seems to have more > energy...Don't confuse physical energy with mathemathical norm. One important mathemathical constraint behind the Fourier transform is that an integral or sum is finite (view with fixed-width font): b b integral |x(t)|^2 dt < ifinite, sum |x[n]| ^2 < infinite a n = a where the exact details vary from case to case. This is a bit like the constraint that energy in a physical system must be finite, and is called 'norm' in the context of math. So in the same way that the energy (or power) of a physical signal most be finite, the Fourier transform only works of the norm of the data is finite. In the case of sampled signals the integral or sum limits in the formulas above are chosen so that the sum or integral is take over a bandwidth of Fs, for instance [-Fs/2, Fs/2>, although other choises are possible.> since its spectrum is large compared to the bandpass signal > and the sampling impulse train... How does this happen...?It's a purely mathemathical artifact.> From where > does this resulting signal get its energy from...? I think mostly > sampling circuits don't provide energy to the signals...!They don't. ADCs take the signal from physical reality, where energy must be preserved, and maps it into a mathematical world where other rules apply. You might think of the ADC as the mirror in Lewis Carrol's 'Through the looking glass.'> � � � � � �Does this have anything to do with Power Spectral density > Vs FFT...?Nope.> will FFT of the sampled signal'FFT' is a computational algorithm, like addition. The resulting data is a Discrete Fourier Transform (DFT) of the data the same way that the 'sum' is the result of performing an 'addition'. The terms FFT and DFT are as (little) interchangable as the tems 'addition' and 'sum'.> be different from that of > its PSD...?Yes, but only partially because of sampling. Formally, the DFT can only be used to compute an *estimate* for the PSD. For real-valued signals the FFT computes a complex-valued spectrum, whereas the PSD is real-valued. So the PSD is fundamentally different from the DFT in that it contains only some of the the information you get in the DFT. Second, if you want to compute a 'true' estimate for the PSD, where the numbers match those from the physical world, you need to make the effort to calibrate the ADC to find whatever scale and conversion factors are involved in the sampling. That's a big deal in practice, so people don't calibrate the systems unless there are very good reasons for it. Rune
Lordsathish: The simple answer is that it is an illusion to believe that your multiple bandlimited spectra replicated for each multiple of sampling frequency has "infinite" energy. These bandlimited spectra are simply the observation if the A/D samples at these frequencies to the same time domain signals. James www.go-ci.com
Rune Allnor wrote: (snip regarding sampling and energy)> They don't. ADCs take the signal from physical reality, where > energy must be preserved, and maps it into a mathematical > world where other rules apply. You might think of the ADC > as the mirror in Lewis Carrol's 'Through the looking glass.'(snip) I was thinking just last week about one discussed here not so long ago. If you consider the sampled signal of period three { -1, 1, 1 } and reconstruct the band limited signal you find the amplitude greater than one. (Or peak-to-peak greater than two.) It might seem that you can't get an output greater than one or less than -1 out of that, but you can. You can also consider the period four sampled signal { 1, -1 ,-1, 1 } Compute the output power of the continuous signal and compare it to the power in the discrete signal.> Formally, the DFT can only be used to compute an *estimate* > for the PSD. For real-valued signals the FFT computes a > complex-valued spectrum, whereas the PSD is real-valued. > So the PSD is fundamentally different from the DFT in that > it contains only some of the the information you get in > the DFT.> Second, if you want to compute a 'true' estimate for the PSD, > where the numbers match those from the physical world, you need > to make the effort to calibrate the ADC to find whatever scale > and conversion factors are involved in the sampling. That's > a big deal in practice, so people don't calibrate the systems > unless there are very good reasons for it.-- glen
Tim Wescott wrote: (snip)> You are confusing mathematics with reality.> Sampling is mathematically modeled as multiplying the continuous-time > signal with a chain of impulses. Since an impulse has infinite energy, a > chain of impulses has infinite power.Well, delta has finite area, so if you integrate over it you get a finite power.> This is where your confusion comes in: you can't _really_ multiply a > continuous-time signal with a chain of impulses, because no one can > generate a chain of impulses, nor can anyone build a multiplier that > would do anything useful with an impulse as an input.This is true, but you can still figure out the power from the sampled signal. If you take an analog signal voltage as a function of time, the sampled signal still has units of volts. Similar to integrating the square of the voltage and dividing by the time, you can sum the square of the sample values and divide by the number of samples. To get actual power you need a load resistance in both cases.> The _model_ has you multiplying the signal with a chain of impulses, but > the _reality_ is that you measure the value of the signal around your > chosen sampling instant, then do something with it (usually do an analog > to digital conversion). If you try to do your mathematical analysis > while leaving the sampling process all bound up with the reality of what > you're doing you'll find the going very rough -- so you model the "ideal" > sampled signal, then you model the rest of the signal processing chain.Hopefully the signal is changing slowly relative to the sampling window width. Then the measured samples are a good approximation of the instantaneous sample value. -- glen
On Fri, 17 Oct 2008 15:17:15 -0800, glen herrmannsfeldt wrote:> Tim Wescott wrote: > (snip) > >> You are confusing mathematics with reality. > >> Sampling is mathematically modeled as multiplying the continuous-time >> signal with a chain of impulses. Since an impulse has infinite energy, >> a chain of impulses has infinite power. > > Well, delta has finite area, so if you integrate over it you get a > finite power.But not after you square it to get power. If you take the delta functional to be a pulse 1/a wide and a tall, then in the limit as a -> infinity the area stays at 1 and the height goes to infinity. But when you square it to find the energy, the area = a, and goes to infinity as well. So, infinite energy (or at least an infinite mathematical norm) per pulse. Ergo infinite power... -- snip -- -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●October 18, 20082008-10-18
Tim Wescott wrote: (snip)>>Well, delta has finite area, so if you integrate over it you get a >>finite power.> But not after you square it to get power.> If you take the delta functional to be a pulse 1/a wide and a tall, then > in the limit as a -> infinity the area stays at 1 and the height goes to > infinity. But when you square it to find the energy, the area = a, and > goes to infinity as well.There has to be an answer to this, but I agree that I don't know what it is. Quantum mechanics uses delta functions where the probability (square of the amplitude) better not be greater than one. -- glen
