Hi, I am building QPSK demodulator on FPGA. I am basically performing demodulation with the help of Costas loop. My QPSK Digital Demodulator should have following features: 1)It should adhere with DVB-S, DVB-S2 Standard. 2)It should perform carrier phase recovery and clock recovery. I have the following querries: 1)Costas loop need Sine/Cosine table for multiplication with the incoming modulated samples. On what factors does this table depend on? 2)How can I decide on Samples/Symbol. According to my understanding samples/symbol=(Bit-rate)/(Sampling frequency of the ADC) Note: ADC is the one which converts (receives) analog modulated data and converts it into digital. Is my understanding correct?? 3)What will be the Carrier Frequency for DVB-S2 System? 4)For the carrier phase recovery using Costas loop, after calculating the phase difference, How can I apply this "phase error" for next iteration? Should I update the Sine/Cosien tables? how can I control it? 5) how can I decide on the parameters for Low pass filter and Loop Filter used in the Costas Loop. Regards, Nithin
QPSK Demodulator for DVB-S2
Started by ●November 6, 2008
Reply by ●November 7, 20082008-11-07
On Thu, 06 Nov 2008 04:35:59 -0600, isnithin wrote:> Hi, > I am building QPSK demodulator on FPGA. I am basically performing > demodulation with the help of Costas loop. > > My QPSK Digital Demodulator should have following features: > > 1)It should adhere with DVB-S, DVB-S2 Standard. 2)It should perform > carrier phase recovery and clock recovery. > > > I have the following querries: > > 1)Costas loop need Sine/Cosine table for multiplication with the > incoming modulated samples. On what factors does this table depend on? > > 2)How can I decide on Samples/Symbol. According to my understanding > samples/symbol=(Bit-rate)/(Sampling frequency of the ADC) > Note: ADC is the one which converts (receives) analog modulated data and > converts it into digital. > Is my understanding correct?? > > 3)What will be the Carrier Frequency for DVB-S2 System? > > 4)For the carrier phase recovery using Costas loop, after calculating > the phase difference, How can I apply this "phase error" for next > iteration? Should I update the Sine/Cosien tables? how can I control it? > > 5) how can I decide on the parameters for Low pass filter and Loop > Filter used in the Costas Loop. > > Regards, > NithinAnd don't multiple-post. Check the Wikipedia entry on "cross posting" for a discussion of the difference between cross- and multiple- posting. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
