Let us assume that we have a bandlimited signal (with maximum frequency f_n) corrupted by additive white Gaussian noise. Before we can sample this signal, we pass the signal through an ideal anti-alias filter with cut-off frequency f_c >=f_n to avoid noise aliasing. The output of the anti-aliasing filter is fed into a matched filter matched to the symbol rate, (1/T)>=2f_n (i used f_n here because we intend to keep useful signal spectrum intact). As a prticular case we let I/T=10f_n and f_c=2f_n. My question is what will be the impact of sampling on the white noise in this case? Will it remain white? Will it not be the case that (bandlimited) noise will get oversampled so that power spectral density of noise will no more be flat over -pi and pi? My understanding is that noise is white (theoretically) in discrete-time domain if its PSD is flat over -pi to pi and hence over all frequencies in the discrete-time domain. And the noise will be colored if it is not flat over -pi to pi. Secondly suppose we have signal-plus-noise (in discrete-time domain) such that noise PSD is flat over -pi to pi whereas the spectrum of the signal is non-zero over -pi/M<omega<pi/M where M is a positive integer. We upsample signal-plus-noise by factor N. My question is what will be the impact of upsampling on PSD of noise. Will it be magnitude and frequency scaled? (Ref: Discrete-time signal processing by Alan V. Oppenheim, Ronald W. Schafer) Can somebody please help? RIMalhi
Sampling a signal corrupted by AWGN
Started by ●November 13, 2008
Reply by ●November 13, 20082008-11-13
On Nov 13, 6:12�pm, "RIMalhi" <m4ma...@yahoo.com> wrote:> Let us assume that we have a bandlimited signal (with maximum frequency > f_n) corrupted by additive white Gaussian noise. Before we can sample this > signal, we pass the signal through an ideal anti-alias filter with cut-off > frequency f_c >=f_n to avoid noise aliasing. The output of the > anti-aliasing filter is fed into a matched filter matched to the symbol > rate, (1/T)>=2f_n (i used f_n here because we intend to keep useful signal > spectrum intact). As a prticular case we let I/T=10f_n and f_c=2f_n. MyI'm _assuming_ by symbol rate you mean sampling rate. Correct me if that's not right. To get my bearings, we have 0 <= f_n <= f_c <= f_s where f_s is the sampling frequency. With your numbers, normalized to f_n = 1, 0 <= 1 <= 2 <= 10 So the Nyquist limit is at 5, therefore (- pi...+pi ) in discrete domain corresponds to -5 to +5 in original continuous frequency domain.> question is what will be the impact of sampling on the white noise in this > case? Will it remain white? Will it not be the case that (bandlimited) > noise will get oversampled so that power spectral density of noise will no > more be flat over -pi and pi?It *was* flat until you filtered it . But then you filtered it. So you now have (ideally) non-zero flat PSD from (-2 to 2). But you're sampling with Nyquist mapped to (-5,5). So I'd guess that your PSD in the discrete domain would be non-zero from (-2/5 pi ... +2/5 pi). That doesn't sound like what you want to call "white" in the discrete domain.> My understanding is that noise is white (theoretically) in discrete-time > domain if its PSD is flat over -pi to pi and hence over all frequencies in > the discrete-time domain. And the noise will be colored if it is not flat > over -pi to pi.So it sounds like your filter coloured it, then.> > Secondly suppose we have signal-plus-noise (in discrete-time domain) such > that noise PSD is flat over -pi to pi whereas the spectrum of the signal is > non-zero over -pi/M<omega<pi/M where M is a positive integer. We upsample > signal-plus-noise by factor N. My question is what will be the impact of > upsampling on PSD of noise. Will it be magnitude and frequency scaled? > (Ref: Discrete-time signal processing by Alan V. Oppenheim, Ronald W. > Schafer)It's like deja vu all over again. You start with a signal that's "full" of noise, pregnant with entropy for the entire omega spectrum. Then you stuff in some zeros (modulation), then you filter (your sinc filter). The filter is the hint here. You have more samples now but you've also rescaled omega, so the noise now looks like it lives only in (-pi/N to pi/N). The amplitude scaling idea is really tripping you up. Look at it this way: Imagine your original signal was DC: 1,1,1,1,1,... Now zero-stuff (N=4) 1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0... If you filter the stuffed signal with an ideal *unity-gain* filter, you'll get (in steady-state) 0.25, 0.25, 0.25, 0.25, ..... This is where the amplitude is lost. You either keep track of it in your head as a loss (i.e a fudge factor of 0.25) , or you redefine your upsampling filter to have a gain of 4 buried in it somewhere to make the upsampling unity gain as far as signal amplitude goes. It's all in our heads anyway :-)> > Can somebody please help? > > RIMalhiMaybe :-) - Kenn
Reply by ●November 14, 20082008-11-14
On Thu, 13 Nov 2008 17:12:57 -0600, RIMalhi wrote:> Let us assume that we have a bandlimited signal (with maximum frequency > f_n) corrupted by additive white Gaussian noise. Before we can sample > this signal, we pass the signal through an ideal anti-alias filter with > cut-off frequency f_c >=f_n to avoid noise aliasing. The output of the > anti-aliasing filter is fed into a matched filter matched to the symbol > rate, (1/T)>=2f_n (i used f_n here because we intend to keep useful > signal spectrum intact). As a prticular case we let I/T=10f_n and > f_c=2f_n. My question is what will be the impact of sampling on the > white noise in this case? Will it remain white? Will it not be the case > that (bandlimited) noise will get oversampled so that power spectral > density of noise will no more be flat over -pi and pi?At the point that you are sampling it is no longer white -- it is colored, because you have filtered it. If you have filtered it to have a bandwidth strictly less than the Nyquist rate, then it'll have the same spectrum in the sampled-time domain. You could construct a filter that rolls off symmetrically around the Nyquist rate; were you to do this then the resulting sampled-time noise would be white, even though sampled-time "white" means something different from continuous-time "white".> My understanding is that noise is white (theoretically) in discrete-time > domain if its PSD is flat over -pi to pi and hence over all frequencies > in the discrete-time domain. And the noise will be colored if it is not > flat over -pi to pi.Correct.> > Secondly suppose we have signal-plus-noise (in discrete-time domain) > such that noise PSD is flat over -pi to pi whereas the spectrum of the > signal is non-zero over -pi/M<omega<pi/M where M is a positive integer. > We upsample signal-plus-noise by factor N. My question is what will be > the impact of upsampling on PSD of noise. Will it be magnitude and > frequency scaled? (Ref: Discrete-time signal processing by Alan V. > Oppenheim, Ronald W. Schafer) >That depends on how you upsample. If you upsample by keeping all the original samples and filling in the spaces with N-1 long strings of ones, then your resulting noise will be white, although it will no longer be stationary. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Kenn Wrote>On Nov 13, 6:12=A0pm, "RIMalhi" <m4ma...@yahoo.com> wrote: >> Let us assume that we have a bandlimited signal (with maximumfrequency>> f_n) corrupted by additive white Gaussian noise. Before we can samplethi=>s >> signal, we pass the signal through an ideal anti-alias filter withcut-of=>f >> frequency f_c >=3Df_n to avoid noise aliasing. The output of the >> anti-aliasing filter is fed into a matched filter matched to thesymbol>> rate, (1/T)>=3D2f_n (i used f_n here because we intend to keep usefulsig=>nal >> spectrum intact). As a prticular case we let I/T=3D10f_n andf_c=3D2f_n. =>My > >I'm _assuming_ by symbol rate you mean sampling rate. Correct me if >that's not right. To get my bearings, we have > >0 <= f_n <= f_c <= f_s > >where f_s is the sampling frequency. With your numbers, normalized to >f_n =1, > >0 <= 1 <= 2 <= 10 > >So the Nyquist limit is at 5, therefore (- pi...+pi ) in discrete >domain corresponds to -5 to +5 in original continuous frequency >domain. > >> question is what will be the impact of sampling on the white noise inthi=>s >> case? Will it remain white? Will it not be the case that (bandlimited) >> noise will get oversampled so that power spectral density of noise willn=>o >> more be flat over -pi and pi? > >It *was* flat until you filtered it . But then you filtered it. So you >now have (ideally) non-zero flat PSD from (-2 to 2). But you're >sampling with Nyquist mapped to (-5,5). So I'd guess that your PSD in >the discrete domain would be non-zero from (-2/5 pi ... +2/5 pi). That >doesn't sound like what you want to call "white" in the discrete >domain. > >> My understanding is that noise is white (theoretically) indiscrete-time>> domain if its PSD is flat over -pi to pi and hence over all frequenciesi=>n >> the discrete-time domain. And the noise will be colored if it is notflat>> over -pi to pi. > >So it sounds like your filter coloured it, then. > >> >> Secondly suppose we have signal-plus-noise (in discrete-time domain)such>> that noise PSD is flat over -pi to pi whereas the spectrum of thesignal =>is >> non-zero over -pi/M<omega<pi/M where M is a positive integer. Weupsample>> signal-plus-noise by factor N. My question is what will be the impactof>> upsampling on PSD of noise. Will it be magnitude and frequency scaled? >> (Ref: Discrete-time signal processing by Alan V. Oppenheim, Ronald W. >> Schafer) > >It's like deja vu all over again. > >You start with a signal that's "full" of noise, pregnant with entropy >for the entire omega spectrum. Then you stuff in some zeros >(modulation), then you filter (your sinc filter). The filter is the >hint here. You have more samples now but you've also rescaled omega, >so the noise now looks like it lives only in (-pi/N to pi/N). > >The amplitude scaling idea is really tripping you up. Look at it this >way: Imagine your original signal was DC: > >1,1,1,1,1,... > >Now zero-stuff (N=3D4) > >1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0... > >If you filter the stuffed signal with an ideal *unity-gain* filter, >you'll get (in steady-state) > >0.25, 0.25, 0.25, 0.25, ..... > >This is where the amplitude is lost. You either keep track of it in >your head as a loss (i.e a fudge factor of 0.25) , or you redefine >your upsampling filter to have a gain of 4 buried in it somewhere to >make the upsampling unity gain as far as signal amplitude goes. It's >all in our heads anyway :-)Hi Kenn, We have flat spectrum in the frequency domain. But we do not stuff any zeros in the flat spectrum. We stff zeros in time domain and are seeking its impact on the spectrum. We know that contraction in time domain results in expansion in frequency domain and vice versa. So when we upsample a signal in the time domain, we are in fact expanding it. Therefore, in frequency domain we should observe an equal contraction in the spectrum. What confuses me is this: Some people (e.g., look at url http://sipc.eecs.berkeley.edu/ee123/ee123handoutPSD.pdf) suggest that after upsampling (or downsampling) white noise remains white. By theory, when we stuff time domain signal corrupted by noise with zeros, we should observe contraction of the spectrum of the signal and noise (noise is additive and is independent of the signal!). Before upsampling, the noise had flat PSD=N_0 over -pi to pi. If the suggestion that noise remains white after upsampling is TRUE, then there must not be any change in both magnitude of PSD of noise and the frequency. Why? Because for noise to be white, its PSD must remain flat over -pi to pi which requires that Upsampling must not cause any contraction in the spectrum of noise. And if that suggestion is NOT true, white noise should be colored after upsampling! So my question is whether the noise remains white or becomes colored after Upsampling? And regarding Tim's explanation:> > Secondly suppose we have signal-plus-noise (in discrete-time domain) > such that noise PSD is flat over -pi to pi whereas the spectrum of the > signal is non-zero over -pi/M<omega<pi/M where M is a positive integer. > We upsample signal-plus-noise by factor N. My question is what will be > the impact of upsampling on PSD of noise. Will it be magnitude and > frequency scaled? (Ref: Discrete-time signal processing by Alan V. > Oppenheim, Ronald W. Schafer) >That depends on how you upsample. If you upsample by keeping all the original samples and filling in the spaces with N-1 long strings of ones, then your resulting noise will be white, although it will no longer be stationary. Yes Tim, we keep original samples and stuff N-1 zeros between two consecutive samples. You said that noise will no more be stationary which is something confusing me. Could you please explain a bit? Thanks,
RIMalhi wrote:> Kenn Wrote > >> On Nov 13, 6:12=A0pm, "RIMalhi" <m4ma...@yahoo.com> wrote: >>> Let us assume that we have a bandlimited signal (with maximum > frequency >>> f_n) corrupted by additive white Gaussian noise. Before we can sample > thi= >> s >>> signal, we pass the signal through an ideal anti-alias filter with > cut-of= >> f >>> frequency f_c >=3Df_n to avoid noise aliasing. The output of the >>> anti-aliasing filter is fed into a matched filter matched to the > symbol >>> rate, (1/T)>=3D2f_n (i used f_n here because we intend to keep useful > sig= >> nal >>> spectrum intact). As a prticular case we let I/T=3D10f_n and > f_c=3D2f_n. = >> My >> >> I'm _assuming_ by symbol rate you mean sampling rate. Correct me if >> that's not right. To get my bearings, we have >> >> 0 <= f_n <= f_c <= f_s >> >> where f_s is the sampling frequency. With your numbers, normalized to >> f_n =1, >> >> 0 <= 1 <= 2 <= 10 >> >> So the Nyquist limit is at 5, therefore (- pi...+pi ) in discrete >> domain corresponds to -5 to +5 in original continuous frequency >> domain. >> >>> question is what will be the impact of sampling on the white noise in > thi= >> s >>> case? Will it remain white? Will it not be the case that (bandlimited) >>> noise will get oversampled so that power spectral density of noise will > n= >> o >>> more be flat over -pi and pi? >> It *was* flat until you filtered it . But then you filtered it. So you >> now have (ideally) non-zero flat PSD from (-2 to 2). But you're >> sampling with Nyquist mapped to (-5,5). So I'd guess that your PSD in >> the discrete domain would be non-zero from (-2/5 pi ... +2/5 pi). That >> doesn't sound like what you want to call "white" in the discrete >> domain. >> >>> My understanding is that noise is white (theoretically) in > discrete-time >>> domain if its PSD is flat over -pi to pi and hence over all frequencies > i= >> n >>> the discrete-time domain. And the noise will be colored if it is not > flat >>> over -pi to pi. >> So it sounds like your filter coloured it, then. >> >>> Secondly suppose we have signal-plus-noise (in discrete-time domain) > such >>> that noise PSD is flat over -pi to pi whereas the spectrum of the > signal = >> is >>> non-zero over -pi/M<omega<pi/M where M is a positive integer. We > upsample >>> signal-plus-noise by factor N. My question is what will be the impact > of >>> upsampling on PSD of noise. Will it be magnitude and frequency scaled? >>> (Ref: Discrete-time signal processing by Alan V. Oppenheim, Ronald W. >>> Schafer) >> It's like deja vu all over again. >> >> You start with a signal that's "full" of noise, pregnant with entropy >> for the entire omega spectrum. Then you stuff in some zeros >> (modulation), then you filter (your sinc filter). The filter is the >> hint here. You have more samples now but you've also rescaled omega, >> so the noise now looks like it lives only in (-pi/N to pi/N). >> >> The amplitude scaling idea is really tripping you up. Look at it this >> way: Imagine your original signal was DC: >> >> 1,1,1,1,1,... >> >> Now zero-stuff (N=3D4) >> >> 1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0... >> >> If you filter the stuffed signal with an ideal *unity-gain* filter, >> you'll get (in steady-state) >> >> 0.25, 0.25, 0.25, 0.25, ..... >> >> This is where the amplitude is lost. You either keep track of it in >> your head as a loss (i.e a fudge factor of 0.25) , or you redefine >> your upsampling filter to have a gain of 4 buried in it somewhere to >> make the upsampling unity gain as far as signal amplitude goes. It's >> all in our heads anyway :-) > > > > Hi Kenn, > We have flat spectrum in the frequency domain. But we do not stuff any > zeros in the flat spectrum. We stff zeros in time domain and are seeking > its impact on the spectrum. We know that contraction in time domain results > in expansion in frequency domain and vice versa. So when we upsample a > signal in the time domain, we are in fact expanding it. Therefore, in > frequency domain we should observe an equal contraction in the spectrum. > What confuses me is this: Some people (e.g., look at url > http://sipc.eecs.berkeley.edu/ee123/ee123handoutPSD.pdf) suggest that > after upsampling (or downsampling) white noise remains white. By theory, > when we stuff time domain signal corrupted by noise with zeros, we should > observe contraction of the spectrum of the signal and noise (noise is > additive and is independent of the signal!). Before upsampling, the noise > had flat PSD=N_0 over -pi to pi. If the suggestion that noise remains white > after upsampling is TRUE, then there must not be any change in both > magnitude of PSD of noise and the frequency. Why? Because for noise to be > white, its PSD must remain flat over -pi to pi which requires that > Upsampling must not cause any contraction in the spectrum of noise.Think about what the range -pi < w < +pi means before upsampling and what it means after. I suspect that you are confusing yourself with equations and trying to correct that with logic. Complete this thought: "The frequencies pi and -pi are normalized to the sample rate. When you alter the sample rate ..." ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●November 19, 20082008-11-19
>RIMalhi wrote: >> Kenn Wrote >> >>> On Nov 13, 6:12=A0pm, "RIMalhi" <m4ma...@yahoo.com> wrote: >>>> Let us assume that we have a bandlimited signal (with maximum >> frequency >>>> f_n) corrupted by additive white Gaussian noise. Before we cansample>> thi= >>> s >>>> signal, we pass the signal through an ideal anti-alias filter with >> cut-of= >>> f >>>> frequency f_c >=3Df_n to avoid noise aliasing. The output of the >>>> anti-aliasing filter is fed into a matched filter matched to the >> symbol >>>> rate, (1/T)>=3D2f_n (i used f_n here because we intend to keepuseful>> sig= >>> nal >>>> spectrum intact). As a prticular case we let I/T=3D10f_n and >> f_c=3D2f_n. = >>> My >>> >>> I'm _assuming_ by symbol rate you mean sampling rate. Correct me if >>> that's not right. To get my bearings, we have >>> >>> 0 <= f_n <= f_c <= f_s >>> >>> where f_s is the sampling frequency. With your numbers, normalized to >>> f_n =1, >>> >>> 0 <= 1 <= 2 <= 10 >>> >>> So the Nyquist limit is at 5, therefore (- pi...+pi ) in discrete >>> domain corresponds to -5 to +5 in original continuous frequency >>> domain. >>> >>>> question is what will be the impact of sampling on the white noisein>> thi= >>> s >>>> case? Will it remain white? Will it not be the case that(bandlimited)>>>> noise will get oversampled so that power spectral density of noisewill>> n= >>> o >>>> more be flat over -pi and pi? >>> It *was* flat until you filtered it . But then you filtered it. Soyou>>> now have (ideally) non-zero flat PSD from (-2 to 2). But you're >>> sampling with Nyquist mapped to (-5,5). So I'd guess that your PSD in >>> the discrete domain would be non-zero from (-2/5 pi ... +2/5 pi).That>>> doesn't sound like what you want to call "white" in the discrete >>> domain. >>> >>>> My understanding is that noise is white (theoretically) in >> discrete-time >>>> domain if its PSD is flat over -pi to pi and hence over allfrequencies>> i= >>> n >>>> the discrete-time domain. And the noise will be colored if it is not >> flat >>>> over -pi to pi. >>> So it sounds like your filter coloured it, then. >>> >>>> Secondly suppose we have signal-plus-noise (in discrete-time domain) >> such >>>> that noise PSD is flat over -pi to pi whereas the spectrum of the >> signal = >>> is >>>> non-zero over -pi/M<omega<pi/M where M is a positive integer. We >> upsample >>>> signal-plus-noise by factor N. My question is what will be theimpact>> of >>>> upsampling on PSD of noise. Will it be magnitude and frequencyscaled?>>>> (Ref: Discrete-time signal processing by Alan V. Oppenheim, RonaldW.>>>> Schafer) >>> It's like deja vu all over again. >>> >>> You start with a signal that's "full" of noise, pregnant with entropy >>> for the entire omega spectrum. Then you stuff in some zeros >>> (modulation), then you filter (your sinc filter). The filter is the >>> hint here. You have more samples now but you've also rescaled omega, >>> so the noise now looks like it lives only in (-pi/N to pi/N). >>> >>> The amplitude scaling idea is really tripping you up. Look at it this >>> way: Imagine your original signal was DC: >>> >>> 1,1,1,1,1,... >>> >>> Now zero-stuff (N=3D4) >>> >>> 1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0... >>> >>> If you filter the stuffed signal with an ideal *unity-gain* filter, >>> you'll get (in steady-state) >>> >>> 0.25, 0.25, 0.25, 0.25, ..... >>> >>> This is where the amplitude is lost. You either keep track of it in >>> your head as a loss (i.e a fudge factor of 0.25) , or you redefine >>> your upsampling filter to have a gain of 4 buried in it somewhere to >>> make the upsampling unity gain as far as signal amplitude goes. It's >>> all in our heads anyway :-) >> >> >> >> Hi Kenn, >> We have flat spectrum in the frequency domain. But we do not stuff any >> zeros in the flat spectrum. We stff zeros in time domain and areseeking>> its impact on the spectrum. We know that contraction in time domainresults>> in expansion in frequency domain and vice versa. So when we upsample a >> signal in the time domain, we are in fact expanding it. Therefore, in >> frequency domain we should observe an equal contraction in thespectrum.>> What confuses me is this: Some people (e.g., look at url >> http://sipc.eecs.berkeley.edu/ee123/ee123handoutPSD.pdf) suggest that >> after upsampling (or downsampling) white noise remains white. Bytheory,>> when we stuff time domain signal corrupted by noise with zeros, weshould>> observe contraction of the spectrum of the signal and noise (noise is >> additive and is independent of the signal!). Before upsampling, thenoise>> had flat PSD=N_0 over -pi to pi. If the suggestion that noise remainswhite>> after upsampling is TRUE, then there must not be any change in both >> magnitude of PSD of noise and the frequency. Why? Because for noise tobe>> white, its PSD must remain flat over -pi to pi which requires that >> Upsampling must not cause any contraction in the spectrum of noise. > >Think about what the range -pi < w < +pi means before upsampling and >what it means after. I suspect that you are confusing yourself with >equations and trying to correct that with logic. > >Complete this thought: "The frequencies pi and -pi are normalized to the>sample rate. When you alter the sample rate ..." > > ... > >Jerry >-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >Hi Jerry, Thank you very much making me clear about the confusion that i described. -pi < w < +pi is the fundamental spectrum of the sampled sgnal where pi is equal to half the sampling frequency. When we upsample or downsample the sequence, we also change pi < w < +pi. There is one more thing that i wish to ask. At the receiver end in a communication system, before we can sample we have to limit the bandwidth of the received signal. Suppose we have the following model of received signal in continuous-time domain y(t)=c(t)s(t)+n(t); whete c(t) and s(t) are bandlimited processes and n(t) is AWGN. To get sampled version of y(t), we first have to use anti-alias filter to limit the bandwidth of the input signal to avoid aliasing. Firstly the queston is what should be the bandwidth of the anti-aliasing filter ideally? An intuitive answer to this question is that the filter bandwidth should be equal the maximum frequency in the useful signal. In our case that signal is u(t)=c(t)s(t). As we know multiplication in the time-domain implies convolution in the frequency domain, the maximum frequency present in the useful signal is equal to the SUM of the maximum frequencies in individual spectra of c(t) and s(t). Let that frequency be f_N. If the sampling frequency is P times the Nyquist rate corresponding to that frequency i.e., fs=P 2 f_N, the noise will no more be white in the discrete-time domain (it will be white if we sample at Nyquist rate corresponding to f_N). Then why do we make an assumption of white noise in the discrete-time domain? Is it just a matter of mathematical convenience? Do the state-of-the-art receivers assume the noise to be white? If we have the following sequence (recall that u[n]=s[n]c[n]) ... c[-3] u[-2] u[-1] c[0] u[1] u[2] c[3] u[4] u[5].... and u(t) has maximum fequency f_N and c(t) has maximum frequency f_c. My question is what will be the maximum frequency of this sequence? Regards, RIMalhi
RIMalhi wrote: ...> Hi Jerry, > Thank you very much making me clear about the confusion that i described. > -pi < w < +pi is the fundamental spectrum of the sampled sgnal where pi is > equal to half the sampling frequency. When we upsample or downsample the > sequence, we also change pi < w < +pi.Indeed! some things become much simpler when we stand back and look at the larger picture.> There is one more thing that i wish to ask. At the receiver end in a > communication system, before we can sample we have to limit the bandwidth > of the received signal. Suppose we have the following model of received > signal in continuous-time domain > > y(t)=c(t)s(t)+n(t); > > whete c(t) and s(t) are bandlimited processes and n(t) is AWGN.The noise is also bandlimited. We call it white because it it behaves white within the band of interest. (All noise is bandlimited. If it weren't, what would its upper frequency be?)> To get sampled version of y(t), we first have to use anti-alias filter to > limit the bandwidth of the input signal to avoid aliasing. Firstly the > queston is what should be the bandwidth of the anti-aliasing filter > ideally? An intuitive answer to this question is that the filter bandwidth > should be equal the maximum frequency in the useful signal. In our case > that signal is u(t)=c(t)s(t). As we know multiplication in the time-domain > implies convolution in the frequency domain, the maximum frequency present > in the useful signal is equal to the SUM of the maximum frequencies in > individual spectra of c(t) and s(t). Let that frequency be f_N. If the > sampling frequency is P times the Nyquist rate corresponding to that > frequency i.e., fs=P 2 f_N, the noise will no more be white in the > discrete-time domain (it will be white if we sample at Nyquist rate > corresponding to f_N). Then why do we make an assumption of white noise in > the discrete-time domain? Is it just a matter of mathematical convenience? > Do the state-of-the-art receivers assume the noise to be white? > > If we have the following sequence (recall that u[n]=s[n]c[n]) > > ... c[-3] u[-2] u[-1] c[0] u[1] u[2] c[3] u[4] u[5].... > > and u(t) has maximum fequency f_N and c(t) has maximum frequency f_c. My > question is what will be the maximum frequency of this sequence?Most receivers have IF sections. Even direct-conversion receivers pass the signal through tuned circuits. There is not usually an additional anti-alias filter in front of the sampler, and even if there were, the received noise would be filtered by it. By the time the signal is handed off to the sampler, noise and signal have the same bandwidth. Simulations that add broadband noise to a simulated detector output are incomplete and therefore misleading. Don't be misled! Jerry -- Engineering is the art of making what you want from things you can get.
>> Hi Jerry, >> Thank you very much making me clear about the confusion that idescribed.>> -pi < w < +pi is the fundamental spectrum of the sampled sgnal where piis>> equal to half the sampling frequency. When we upsample or downsamplethe>> sequence, we also change pi < w < +pi. > >Indeed! some things become much simpler when we stand back and look at >the larger picture. > >> There is one more thing that i wish to ask. At the receiver end in a >> communication system, before we can sample we have to limit thebandwidth>> of the received signal. Suppose we have the following model ofreceived>> signal in continuous-time domain >> >> y(t)=c(t)s(t)+n(t); >> >> whete c(t) and s(t) are bandlimited processes and n(t) is AWGN. > >The noise is also bandlimited. We call it white because it it behaves >white within the band of interest. (All noise is bandlimited. If it >weren't, what would its upper frequency be?) > >> To get sampled version of y(t), we first have to use anti-alias filterto>> limit the bandwidth of the input signal to avoid aliasing. Firstly the >> queston is what should be the bandwidth of the anti-aliasing filter >> ideally? An intuitive answer to this question is that the filterbandwidth>> should be equal the maximum frequency in the useful signal. In ourcase>> that signal is u(t)=c(t)s(t). As we know multiplication in thetime-domain>> implies convolution in the frequency domain, the maximum frequencypresent>> in the useful signal is equal to the SUM of the maximum frequencies in >> individual spectra of c(t) and s(t). Let that frequency be f_N. If the >> sampling frequency is P times the Nyquist rate corresponding to that >> frequency i.e., fs=P 2 f_N, the noise will no more be white in the >> discrete-time domain (it will be white if we sample at Nyquist rate >> corresponding to f_N). Then why do we make an assumption of white noisein>> the discrete-time domain? Is it just a matter of mathematicalconvenience?>> Do the state-of-the-art receivers assume the noise to be white? >> >> If we have the following sequence (recall that u[n]=s[n]c[n]) >> >> ... c[-3] u[-2] u[-1] c[0] u[1] u[2] c[3] u[4] u[5].... >> >> and u(t) has maximum fequency f_N and c(t) has maximum frequency f_c.My>> question is what will be the maximum frequency of this sequence? > >Most receivers have IF sections. Even direct-conversion receivers pass >the signal through tuned circuits. There is not usually an additional >anti-alias filter in front of the sampler, and even if there were, the >received noise would be filtered by it. By the time the signal is handed>off to the sampler, noise and signal have the same bandwidth. >Simulations that add broadband noise to a simulated detector output are >incomplete and therefore misleading. Don't be misled! > >Jerry >-- >Engineering is the art of making what you want from things you can get. >Hi Jerry, Thanks for your reply. Can you please give an idea about the maximum frequency in the above sequence? I think it can be considered as two multiplexed streams. But the question is how to determine spectrum of the composite stream? RIMalhi
Reply by ●November 20, 20082008-11-20
RIMalhi wrote: ...> Hi Jerry, > Thanks for your reply. Can you please give an idea about the maximum > frequency in the above sequence? I think it can be considered as two > multiplexed streams. But the question is how to determine spectrum of the > composite stream?I don't understand your question. In a radio receiver, signal and noise come through the same filters and therefore have the same bandwidth. The receiver does generate some internal noise, but that is only significant in the input stage and most of the filtering happens after that. Jerry -- Engineering is the art of making what you want from things you can get.
>RIMalhi wrote: > > > ... > >> Hi Jerry, >> Thanks for your reply. Can you please give an idea about the maximum >> frequency in the above sequence? I think it can be considered as two >> multiplexed streams. But the question is how to determine spectrum ofthe>> composite stream? > >I don't understand your question. In a radio receiver, signal and noise >come through the same filters and therefore have the same bandwidth. The>receiver does generate some internal noise, but that is only significant>in the input stage and most of the filtering happens after that. > >Jerry >-- >Engineering is the art of making what you want from things you can get. >Hi Jerry, Thanks for your reply. The bandwidth of the filters will be dicatated by the spectrum of the useful signal. My question was related to the bandwidth of the useful signal. I restate my question here. Let us forget any filters or any receiver. I have an i.i.d. random process s(t). We make a new process s'(t) such that we have the following realizations of s'(t) ....s1 s2 s3 1 s4 s5 s6 1 s7 s8 s9 1.... where s1,s2... are realization from random process s(t). Now if random process s(t) has maximum frequency f_c. My question is what will be the maximum frequency of s'(t)? Can we say something at least qualitatively that the maximum frequency in the spectrum of s'(t) is equal to or greater than s(t)? The above sequence is simply s(t) with 1's multiplexed into it (we can consider that way because s(t) is i.i.d.).
