I was just about to post when I saw yours. This was what I was going to say: Gordon's post brings up an excellent point that may be the source of your problem. I presumed that when you zero pad your frequency data that you're adding zeros between your output points. Perhaps you're doing it differently by appending zeros to your frequency data and then inverse transforming? That could very well be the problem. How exactly are you zero padding your frequency data? OK. I think your post answered it - you're appending zeros. That's fine if you're zero padding a time domain sequence, but the frequency domain is different. By adding zeros between your points, you're keeping all the frequency domain points in the same relative positions when you use a doubled N. So try adding zeros between your frequency domain points, and see if that solves your problem. I'll be back later tonight when I rest up from the (too much) food I had earlier.
numerical precision of FFTs when interpolating
Started by ●November 26, 2008
Reply by ●November 28, 20082008-11-28
I looked at that post I wrote at 3:51 AM, and I have no idea why I added that comment about adding zeros between the frequency data. I think it had to do with something I once did when I was trying to accomplish some entirely different task. So today I ran a simple C++ test program to see what I could find. This is how it works: I generate 8 points of a sawtooth wave (sum of 4 sine waves of different amplitudes and frequencies 0f to 3f). Then I generate 16 points over the same time span to see what I should get when I use the FFT to interpolate the 8 point data. Then I did an 8 point FFT on the 8 point data. I get the proper amplitudes and phases at points 0, 1, 2, 3 and 5, 6, 7. The point at 4 (fs/2) is zero because my data is exactly periodic within the 8 points. I zero pad by adding 8 zeros to the center of the data, so points 0, 1, 2, and 3 remain the same, and points 5, 6, and 7 become points 13, 14, and 15. Then I inverse FFT with 16 points. Everything works out perfectly - the 16 points obtained via FFT interpolation are exactly the same as the points I expected to get (the first 15 decimal digits of both data sets are identical, and my imaginary parts via the FFT are all zero up to 15 digits as well). So far, so good (now the fun begins). I know that things won't work out as well when I have input data that isn't periodic in the sampling interval, so I changed the sawtooth input to get a non-periodic data set. As expected, I got a non-zero FFT output at point 4. So I have 8 outputs and they all have non-zero real and imaginary parts (except for point 4, which has a zero imaginary part, as it should, since my input data is real). To zero pad this, I add 8 zeros after the 4 point. I also split the real part of point 4 between point 4 and point 12 (this is what Gordon's post was referring to). So now I have my zero padded data in points 0, 1, 2, 3, and 4(half of what it was), and points 12 (half of the former 4 point), 13, 14, and 15. All the other points are zero. After inverse transforming, my imaginary results are all zero up to 15 decimal digits, which leads me to believe that the algorithm is correct. The even numbered outputs are excellent (they differ by, at most, the number in decimal digit 16). But the odd numbered points are an entirely different story. One of them starts to differ from the expected result in the first point to the right of the decimal point. More than likely, this is a Gibbs type 'rippling' effect (which has already been pointed out by other posters). I've seen it before when using certain types of image processing filters, but I never expected to see so much of it when doing interpolation. So it would seem that if your data is not periodic within the sampling interval, then the interpolation process is subject to the Gibbs effect, which will cause output errors. I suppose you could window your 3D data before the FFTs - that would help to minimize the errors. I�ll check my code again just to make sure (and I might try some windowing).
Thanks for the helpful comments everyone. As correctly predicted by Gordon, my issue was dealing with the Nyquist frequency incorrectly. I was neglecting to copy the nyquist component to both negative and positive frequencies (and dividing by sqrt 2) in the padded spectrum, since I had even FFTs. This resulted in my spectrum being non-Hermitian, and then when I took a complex-to-real IFFT I lost some of the data, hence my norm wasn't quite 1.0. Dealing with the Nyquist frequencies gets a little tricky with 3D data, but I managed to get it coded and it's all working beautifully now. I can interpolate and undo the interpolation and the vectors match within 1.0E-15. As for the Gibb's phenomenon stuff, that's expected, and I don't want to filter. Essentially what I'm doing this for is to do a linear convolution in reciprocal space via the usual Pad, FFT, diagonal matrix multiply, IFFT. Thanks for all the help folks! -- Will
