Hi,all i write a m file to watch the benifit of convolution coding. 3 cases are compare: 1. no coding 2. CC coding, no puncture 3. CC coding, 4/6 puncture Strangely, the BER of case 3 is worse than case 1. Below is my matlab code. what's wrong? % ber=SNRveri(snr,code,repeat,punc) % input snr SNR % code % 0: encoding % 1: no coding % repeat repeat time % punc puncture rate % 0: no puncture % 1: 4/6 puncture % output % ber BER % example % ber=SNRveri(13,0,1000,1) % % function ber=SNRveri(snr,code,repeat,punc) % reset error bit number and total Tx bit number errnum=0; txnum=0; for ii=1:repeat %disp(ii); switch code case 0 switch punc case 0 % produce original binary array bitdata=randint(256*4*1/2-6,1); % coding tailIn=[bitdata; zeros(6,1)]; trel = poly2trellis(7,[171 133]); EncdBtVec=convenc(tailIn,trel); case 1 % produce original binary array bitdata=randint(256*4*3/4-6,1); % coding tailIn=[bitdata; zeros(6,1)]; punctpat=[1 1 0 1 0 1]; trel = poly2trellis(7,[171 133]); EncdBtVec=convenc(tailIn,trel,punctpat); end case 1 %no coding bitdata=randint(256*4,1); EncdBtVec=bitdata; end %modulation using matlab function h= modem.qammod(16); h.inputtype = 'bit'; SymVec=modulate(h,EncdBtVec); sam_time=SymVec; ch_sig=awgn(sam_time,snr,'measured'); sym_fre=ch_sig; %demodulate using matlab function rh=modem.qamdemod(16); rh.outputtype = 'bit'; DemodBtVec=demodulate(rh,sym_fre); switch code case 0 switch punc case 0 % decode trel = poly2trellis(7,[171 133]); tblen = 7; % Traceback length tailBtVec = vitdec(DemodBtVec,trel,tblen,'term','hard'); %Hard input decoder DecdBtVec=tailBtVec(1:length(tailBtVec)-6); %remove tail bits BitVecRx=DecdBtVec; case 1 % decode punctpat=[1 1 0 1 0 1]; trel = poly2trellis(7,[171 133]); tblen = 6; % Traceback length tailBtVec = vitdec(DemodBtVec,trel,tblen,'term','hard',punctpat); %Hard input decoder DecdBtVec=tailBtVec(1:length(tailBtVec)-6); %remove tail bits BitVecRx=DecdBtVec; end case 1 BitVecRx=DemodBtVec; end % calculate error bit number and correct bit number for current run err=0; crt=0; for jj=1:length(bitdata) if (bitdata(jj)==BitVecRx(jj)) crt=crt+1; else err=err+1; end end % add up error bit number and total transmitted bit number errnum=errnum+err; txnum=txnum+(err+crt); end ber=errnum/txnum; disp(ber);
the benifit of convolution code
Started by ●December 5, 2008
Reply by ●December 5, 20082008-12-05
minnows wrote:> Hi,all > i write a m file to watch the benifit of convolution coding. 3 cases > are compare: > 1. no coding > 2. CC coding, no puncture > 3. CC coding, 4/6 puncture > > Strangely, the BER of case 3 is worse than case 1. Below is my matlab > code. what's wrong?As the Eb/No decreases, the coding gain decreases, too. For any code, there is a critical SNR value where the coding gain == 1. If the SNR is below this value, the code only makes the things worse compared to the uncoded case. The weaker is the code, the higher is the critical SNR. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Fri, 05 Dec 2008 09:10:23 -0600, Vladimir Vassilevsky wrote:> minnows wrote: > >> Hi,all >> i write a m file to watch the benifit of convolution coding. 3 >> cases >> are compare: >> 1. no coding >> 2. CC coding, no puncture >> 3. CC coding, 4/6 puncture >> >> Strangely, the BER of case 3 is worse than case 1. Below is my matlab >> code. what's wrong? > > As the Eb/No decreases, the coding gain decreases, too. For any code, > there is a critical SNR value where the coding gain == 1. If the SNR is > below this value, the code only makes the things worse compared to the > uncoded case. The weaker is the code, the higher is the critical SNR. >Moreover when the decoded BER gets bad, it gets _really_ bad. You should plot your BER vs. Eb/No for a variety of Eb/No (or plot decoded BER vs. input BER) -- you'll see this effect right off. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
On Fri, 05 Dec 2008 09:10:23 -0600, Vladimir Vassilevsky wrote:> minnows wrote: > >> Hi,all >> i write a m file to watch the benifit of convolution coding. 3 >> cases >> are compare: >> 1. no coding >> 2. CC coding, no puncture >> 3. CC coding, 4/6 puncture >> >> Strangely, the BER of case 3 is worse than case 1. Below is my matlab >> code. what's wrong? > > As the Eb/No decreases, the coding gain decreases, too. For any code, > there is a critical SNR value where the coding gain == 1. If the SNR is > below this value, the code only makes the things worse compared to the > uncoded case. The weaker is the code, the higher is the critical SNR. >This reminds me of an epiphanette* I had about FM radio, specifically that it has an input SNR to output SNR curve that is very reminiscent of an error correcting code. This makes sense because FM uses redundant information (TX bandwidth higher than signal bandwidth) in a not- immediately-obvious manner. It's interesting that it has the same "when things go to hell they go to hell fast" character of digital FEC. * An epiphanette happens when you suddenly see the true nature of a small and insignificant thing. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Tim Wescott wrote:> On Fri, 05 Dec 2008 09:10:23 -0600, Vladimir Vassilevsky wrote: > >> minnows wrote: >> >>> Hi,all >>> i write a m file to watch the benifit of convolution coding. 3 >>> cases >>> are compare: >>> 1. no coding >>> 2. CC coding, no puncture >>> 3. CC coding, 4/6 puncture >>> >>> Strangely, the BER of case 3 is worse than case 1. Below is my matlab >>> code. what's wrong? >> As the Eb/No decreases, the coding gain decreases, too. For any code, >> there is a critical SNR value where the coding gain == 1. If the SNR is >> below this value, the code only makes the things worse compared to the >> uncoded case. The weaker is the code, the higher is the critical SNR. >> > This reminds me of an epiphanette* I had about FM radio, specifically > that it has an input SNR to output SNR curve that is very reminiscent of > an error correcting code. This makes sense because FM uses redundant > information (TX bandwidth higher than signal bandwidth) in a not- > immediately-obvious manner. It's interesting that it has the same "when > things go to hell they go to hell fast" character of digital FEC.With me, it was the other way round. When firdt reading up on coding, my reaction was, "Gee! Just like FM."> * An epiphanette happens when you suddenly see the true nature of a small > and insignificant thing.Thanks for augmenting my vocabulary! Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
> > >minnows wrote: > >> Hi,all >> i write a m file to watch the benifit of convolution coding. 3cases>> are compare: >> 1. no coding >> 2. CC coding, no puncture >> 3. CC coding, 4/6 puncture >> >> Strangely, the BER of case 3 is worse than case 1. Below is my matlab >> code. what's wrong? > >As the Eb/No decreases, the coding gain decreases, too. For any code, >there is a critical SNR value where the coding gain == 1. If the SNR is >below this value, the code only makes the things worse compared to the >uncoded case. The weaker is the code, the higher is the critical SNR. > > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com >i think there must be something wrong in my matlab code. as you can see, the BER of case 2 is lower than case 1. but puncture make things worse. set SNR=20dB and run my code for each case, i get: 1. BERveri(20,1,1000,0) no coding case: BER=4.88e-6 2. BERveri(20,0,1000,0) cc coding case: BER=0 3. BERveri(20,0,1000,1) cc coding and puncture case: BER=2e-5 the CC with puncture won't bring any benifits even in very high SNR. And this happens under any SNR value from very low to very high. so, there must be something wrong with my code.
> > This reminds me of an epiphanette* I had about FM radio, specifically > > that it has an input SNR to output SNR curve that is very reminiscent of > > an error correcting code. �This makes sense because FM uses redundant > > information (TX bandwidth higher than signal bandwidth) in a not- > > immediately-obvious manner. �It's interesting that it has the same "when > > things go to hell they go to hell fast" character of digital FEC. > >With me, it was the other way round. When firdt reading up on coding, my> reaction was, "Gee! Just like FM." > > >YES EXACTLY ME TOO!!! Mark
