Reference on quantization noise modeling
Started by Thomas Arildsen December 8, 2008
Does anyone know some examples where quantization is modeled by a linear
model as follows:
  y = Q(x),
modeled as
  y = a*x + q,
where q is an additive noise, preferably white Gaussian.
See the following paper for an example:
Fletcher, A.; Rangan, S.; Goyal, V. & Ramchandran, K. Robust Predictive
Quantization: Analysis and Design Via Convex Optimization Selected Topics
in Signal Processing, IEEE Journal of, 2007, 1, 618-632
I am trying to find other examples of the use of this kind of quantizer
model.
Best regards,
Thomas Arildsen
All email to sender address is lost.
My real adress is at arildsen dot org for user thomas.
On 8 Des, 12:11, Thomas Arildsen <tha.es-aau...@spamgourmet.com>
wrote:
> Does anyone know some examples where quantization is modeled by a linear > model as follows: > &#2013266080; y = Q(x), > modeled as > &#2013266080; y = a*x + q, > where q is an additive noise, preferably white Gaussian.
It's been 15 years since I last looked up these things, but I'm pretty sure I saw it done like this in the book by Gersho & Gray: http://www.amazon.com/Quantization-Compression-Springer-International-Engineering/dp/0792391810/ref=sr_1_1?ie=UTF8&s=books&qid=1228735331&sr=8-1 Check out this or similar books in your local library. Rune
On Mon, 08 Dec 2008 03:26:28 -0800, Rune Allnor wrote:
> On 8 Des, 12:11, Thomas Arildsen <tha.es-aau...@spamgourmet.com> wrote: >> Does anyone know some examples where quantization is modeled by a >> linear model as follows: >> &nbsp; y = Q(x), >> modeled as >> &nbsp; y = a*x + q, >> where q is an additive noise, preferably white Gaussian. > > It's been 15 years since I last looked up these things, but I'm pretty > sure I saw it done like this in the book by Gersho & Gray: > > http://www.amazon.com/Quantization-Compression-Springer-International-
> > Check out this or similar books in your local library. > > Rune
Thanks. I have Gersho & Gray. I am flipping through just now. What I can find is the "Additive Noise Model of Quantization" on pp. 148-150. However, they do not seem to mention the gain part of the model I am considering... Thomas Arildsen -- All email to sender address is lost. My real adress is at arildsen dot org for user thomas.
On Mon, 08 Dec 2008 11:11:04 +0000, Thomas Arildsen wrote:
> Does anyone know some examples where quantization is modeled by a linear > model as follows: > y = Q(x), > modeled as > y = a*x + q, > where q is an additive noise, preferably white Gaussian. See the > following paper for an example: > > Fletcher, A.; Rangan, S.; Goyal, V. & Ramchandran, K. Robust Predictive > Quantization: Analysis and Design Via Convex Optimization Selected > Topics in Signal Processing, IEEE Journal of, 2007, 1, 618-632 > > I am trying to find other examples of the use of this kind of quantizer > model. > Best regards, > > Thomas Arildsen
It turns out that good old Jayant & Noll have a description of the model: Jayant, N. S. & Noll, P. Digital Coding of Waveforms - Principles and Applications to Speech and Video Prentice Hall, 1984 Thomas Arildsen -- All email to sender address is lost. My real adress is at arildsen dot org for user thomas.
Thomas Arildsen <tha.es-aau-dk@spamgourmet.com> writes:
> [...] > However, they do not seem to mention the gain part of the model I am > considering...
Just move the gain ahead of the quantizer into its own block: x -> a*x -> q(a*x) -- % Randy Yates % "Ticket to the moon, flight leaves here today %% Fuquay-Varina, NC % from Satellite 2" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://www.digitalsignallabs.com
