When it comes to basic modulation method, ASK/FSK/PSK, there is a sentence in some textbooks: the carrier frequency should be far more than the baseband signal frequency. However, no one give the detail. I need to analyze the data rate upper limit of a communication system using QPSK coherent demodulation in a band-limited AWGN channel when the carrier frequency and channel bandwidth is known. Shannon-Hartley Capacity Theorem give some information, but without the carrier frequency.
How much are the carrier frequency higher than the baseband signal frequency for a band-limited AWGN channel?
Started by ●December 19, 2008
Reply by ●December 19, 20082008-12-19
On Dec 19, 9:31 am, "X.Y." <Xieyu1...@gmail.com> wrote:> When it comes to basic modulation method, ASK/FSK/PSK, there is a > sentence in some textbooks: the carrier frequency should be far more > than the baseband signal frequency. However, no one give the detail. I > need to analyze the data rate upper limit of a communication system > using QPSK coherent demodulation in a band-limited AWGN channel when > the carrier frequency and channel bandwidth is known. Shannon-Hartley > Capacity Theorem give some information, but without the carrier > frequency.This is a difficult question, at least in the way you posed it. Coarsely speaking, the carrier frequency should at least be sufficiently high such that carrier modulation can translate a complex-valued baseband signal into a real-valued baseband signal. I am assuming that your channel is real-valued, correct? Then using ideal sinc filters the answer is fc>R the symbol rate. But in practice you have to use something like raised cosine pulse shaping, and truncated lowpass filters for image rejection in demodulation. So in this sense you will "lose" some performance if you do symbol-by-symbol detection per the usual textbook coherent QPSK demodulation technique. How much you lose is determined by how sharp you can make your filters in the frequency domain. Hope this helps. Julius
Reply by ●December 22, 20082008-12-22
On Dec 20, 12:44�am, julius <juli...@gmail.com> wrote:> On Dec 19, 9:31 am, "X.Y." <Xieyu1...@gmail.com> wrote: > > > When it comes to basic modulation method, ASK/FSK/PSK, there is a > > sentence in some textbooks: the carrier frequency should be far more > > than the baseband signal frequency. However, no one give the detail. I > > need to analyze the data rate upper limit of a communication system > > using QPSK coherent demodulation in a band-limited AWGN channel when > > the carrier frequency and channel bandwidth is known. Shannon-Hartley > > Capacity Theorem give some information, but without the carrier > > frequency. > > This is a difficult question, at least in the way you posed it. > > Coarsely speaking, the carrier frequency should at least be > sufficiently > high such that carrier modulation can translate a complex-valued > baseband signal into a real-valued baseband signal. �I am assuming > that your channel is real-valued, correct? > > Then using ideal sinc filters the answer is fc>R the symbol rate. > But in practice you have to use something like raised cosine pulse > shaping, and truncated lowpass filters for image rejection in > demodulation. �So in this sense you will "lose" some performance > if you do symbol-by-symbol detection per the usual textbook coherent > QPSK demodulation technique. �How much you lose is determined by > how sharp you can make your filters in the frequency domain. > > Hope this helps. > JuliusHi,Julius, Thanks for your reply. what you means is to analyze this question from the point of filter, am I right? The transmitter, channel and receiver can all be seen as filters. As you mentioned, � How much you lose is determined by how sharp you can make your filters in the frequency domain.� In this case, �lose� means lose of frequency components. Correspondingly, a square wave becomes a sine wave, right? In the channel of my system, there is a LC tank circuit, and the carrier frequency is the same as the LC resonance frequency. So these filters just influent baseband signal. The question is how much the baseband signal is harmed, especially its shaped is changed, that it cannot be coherent demodulated?
On Dec 22, 1:31 am, "X.Y." <Xieyu1...@gmail.com> wrote:> On Dec 20, 12:44 am, julius <juli...@gmail.com> wrote: > > > > > On Dec 19, 9:31 am, "X.Y." <Xieyu1...@gmail.com> wrote: > > > > When it comes to basic modulation method, ASK/FSK/PSK, there is a > > > sentence in some textbooks: the carrier frequency should be far more > > > than the baseband signal frequency. However, no one give the detail. I > > > need to analyze the data rate upper limit of a communication system > > > using QPSK coherent demodulation in a band-limited AWGN channel when > > > the carrier frequency and channel bandwidth is known. Shannon-Hartley > > > Capacity Theorem give some information, but without the carrier > > > frequency. > > > This is a difficult question, at least in the way you posed it. > > > Coarsely speaking, the carrier frequency should at least be > > sufficiently > > high such that carrier modulation can translate a complex-valued > > baseband signal into a real-valued baseband signal. I am assuming > > that your channel is real-valued, correct? > > > Then using ideal sinc filters the answer is fc>R the symbol rate. > > But in practice you have to use something like raised cosine pulse > > shaping, and truncated lowpass filters for image rejection in > > demodulation. So in this sense you will "lose" some performance > > if you do symbol-by-symbol detection per the usual textbook coherent > > QPSK demodulation technique. How much you lose is determined by > > how sharp you can make your filters in the frequency domain. > > > Hope this helps. > > Julius > > Hi,Julius, Thanks for your reply. > > what you means is to analyze this question from the point of filter, > am I right? The transmitter, channel and receiver can all be seen as > filters. As you mentioned, � How much you lose is determined by how > sharp you can make your filters in the frequency domain.� In this > case, �lose� means lose of frequency components.> Correspondingly, a > square wave becomes a sine wave, right?I don't understand what you said here... square wave in what domain?> In the channel of my system, > there is a LC tank circuit, and the carrier frequency is the same as > the LC resonance frequency. So these filters just influent baseband > signal.No. When you convert from passband to baseband you have to cancel the carrier images at 2fc. So unless you have ideal lowpass filters, these images will have aliasing into the baseband signal, too.> The question is how much the baseband signal is harmed, > especially its shaped is changed, that it cannot be coherent > demodulated?Here you seem to be asking a question about inter-symbol interference, or equivalently of distortion of your signal shape due to a linear, time-invariant filter that is your "channel". This can be derived simply by sending a single symbol through your passband channel, and using matched filtering at the output. Assuming that your pulse shape satisfies the Nyquist ISI criterion, then you can evaluate the output of the matched filters at integer multiples of the symbol rate, and you can think of this as your "effective" baseband channel. It seems to me that you are confusing a bunch of things at once, you should realize that I've mentioned a few issues here: 1. Effect of non-ideal lowpass filters when converting from passband to baseband. This effect is NOT linear and time-invariant. In most cases you can model this effect as additive white Gaussian noise. If you want to be more accurate then you have to better characterize your transmitted signal, since this is the only source of randomness of this "noise". 2. Effect of the passband channel viewed by the baseband modulator/demodulator. This effect CAN be modeled as linear and time-invariant. Hope this helps. Julius
