Hell All, Can somebody Please provide me with a reliable source for studding and implementing a Reed Solomon Decoder capable of correcting Erasures? I have already implemented the syndrome detector, the Erasure Polynomial, Berlekamp � Massey Algorithm and the program (written in C using VC++) is capable of finding the correct error / erasure locator polynomial but for some reason the (Modified) Forney Algorithm does not work. I need a good source (and lot of examples) to study Forney Algorithm and implemented. Regards, Shriram
Request for the C Code for Erasure Decoding
Started by ●January 12, 2009
Reply by ●January 12, 20092009-01-12
Sriram_IFX <sriramshastry@gmail.com> wrote:>Can somebody Please provide me with a reliable source for studding and >implementing a Reed Solomon Decoder capable of correcting Erasures?>I have already implemented the syndrome detector, the Erasure >Polynomial, Berlekamp � Massey Algorithm and the program (written in C >using VC++) is capable of finding the correct error / erasure locator >polynomial but for some reason the (Modified) Forney Algorithm does >not work.Are you saying you can't find the error values even though the polynomials are correct? Start by debugging a really simple example, like the one-error case. Once that works it should not be too difficult to get the whole thing to work. Steve
Reply by ●January 13, 20092009-01-13
Hi Shriram, Do you need to perform errors-and-erasures decoding, or erasures-only decoding? Erasures-only decoding is a very simple process, which normally relies on solving a set of equations (which can be done by inverting some square matrix). With erasures-only decoding, you do not need to calculate the erasure polynomial, or use Forney's algorithm.
Reply by ●January 14, 20092009-01-14
Hi Shriram, I have matlab source code where I implemented an errors-and-erasures decoder: http://dept.ee.wits.ac.za/~versfeld/research_resources/index.html . Kind Regards, Jaco
