On Jan 15, 4:16�pm, Gordon Sande <g.sa...@worldnet.att.net> wrote:> On 2009-01-15 16:58:07 -0400, glen herrmannsfeldt <g...@ugcs.caltech.edu> said: > > > The Fourier series is defined for periodic functions, integrating > > (or summing) over one period. �I believe that the FFT is misnamed > > (should be FFS) but it is a little late now. > > It is the correct Fourier Transform over its index group. It is > just that the classical mathematical physics never bothered with > sampled and periodic time. They did continuous unbounded, sampled > unbounded and continuous periodic time. Leaving out the only case > that could actual be subject to arithmetical procedures which > is the DFT and its efficient version called the FFT.the only context i have ever heard of the FFT is as the DFT, as Gordon says the FFT is an efficient method to compute the DFT. never heard of the "FFS". but, Gordon, i really agree with Glen that the DFT is identical in every respect to the DFS. two different names for the same thing. yes, the DFT can be thought of as the DTFT of a finite length sequence that is zero-padded and the DTFT is then sampled at equally spaced points on the unit circle. it's true, but i think the most fundamental definition of the DFT is that it maps a periodic sequence with period N in the "time" domain to another periodic sequence with the same period N in the reciprocal "time" domain. r b-j
Truncation error for Fourier transform?
Started by ●January 12, 2009
Reply by ●January 16, 20092009-01-16
On 16 Jan, 05:39, robert bristow-johnson <r...@audioimagination.com> wrote:> On Jan 15, 4:16�pm, Gordon Sande <g.sa...@worldnet.att.net> wrote: > > > On 2009-01-15 16:58:07 -0400, glen herrmannsfeldt <g...@ugcs.caltech.edu> said: > > > > The Fourier series is defined for periodic functions, integrating > > > (or summing) over one period. �I believe that the FFT is misnamed > > > (should be FFS) but it is a little late now. > > > It is the correct Fourier Transform over its index group. It is > > just that the classical mathematical physics never bothered with > > sampled and periodic time. They did continuous unbounded, sampled > > unbounded and continuous periodic time. Leaving out the only case > > that could actual be subject to arithmetical procedures which > > is the DFT and its efficient version called the FFT. > > the only context i have ever heard of the FFT is as the DFT, as Gordon > says the FFT is an efficient method to compute the DFT. �never heard > of the "FFS"."Fast Fourier Series"? The "Fourier Series" is, I believe, the conventional name for the series computed from a continuous function of finite duration. Extending it to be used with infinite-duration periodic signals is a more or less ad hoc practical adaption, on a par with using the DFT to estimate the spectra of infinite-length discrete sequences.> but, Gordon, i really agree with Glen that the DFT is identical in > every respect to the DFS. �two different names for the same thing.Depends on what they are. If the Fourier Series is indeed the series computed from the finite-duration continuous function, it is *not* the same as the DFT.> yes, the DFT can be thought of as the DTFT of a finite length sequence > that is zero-padded and the DTFT is then sampled at equally spaced > points on the unit circle. �it's true, but i think the most > fundamental definition of the DFT is that it maps a periodic sequence > with period N in the "time" domain to another periodic sequence with > the same period N in the reciprocal "time" domain.It *can* do that, but it's not necessary. The DFT is well-defined in its own right. The problem occurs when one, as Gordon says, use it to compute some quantity that *ought* tho have been computed with one of the other variations of the Fourier transform. Rune
On 2009-01-16 08:05:08 -0400, Rune Allnor <allnor@tele.ntnu.no> said:> On 16 Jan, 05:39, robert bristow-johnson <r...@audioimagination.com> > wrote: >> On Jan 15, 4:16�pm, Gordon Sande <g.sa...@worldnet.att.net> wrote: >> >>> On 2009-01-15 16:58:07 -0400, glen herrmannsfeldt <g...@ugcs.caltech.ed > u> said: >> >>>> The Fourier series is defined for periodic functions, integrating >>>> (or summing) over one period. �I believe that the FFT is misnamed >>>> (should be FFS) but it is a little late now. >> >>> It is the correct Fourier Transform over its index group. It is >>> just that the classical mathematical physics never bothered with >>> sampled and periodic time. They did continuous unbounded, sampled >>> unbounded and continuous periodic time. Leaving out the only case >>> that could actual be subject to arithmetical procedures which >>> is the DFT and its efficient version called the FFT. >> >> the only context i have ever heard of the FFT is as the DFT, as Gordon >> says the FFT is an efficient method to compute the DFT. �never heard >> of the "FFS". > > "Fast Fourier Series"? The "Fourier Series" is, I believe, the > conventional name for the series computed from a continuous function > of finite duration. Extending it to be used with infinite-duration > periodic signals is a more or less ad hoc practical adaption, on a > par with using the DFT to estimate the spectra of infinite-length > discrete sequences.As an undergraduate I learned about the Fourier Transform for unbounded continuous time. Then there was an extension for continuous periodic time to deal with rotating machinery with their discrete frequencies. As a mathematical curiosity there was its "paired" analysis of unbounded discrete time. The rotating machinery variant was called Fourier Series and the discrete time variant was labelled Fourier Sequences. The impression was that there was no good name with sequences being "something other than series" and a borrowed name from Taylor series and such. The secondary names seemed mostly to allow the several book chapters and sections to have distinct short titles. As a graduate student one quickly learned that FTs are associated with groups. The approximation of one FT by another is really an issue of how well one indexing group captures the properties of another. The discussion seems more rational (and much less heated) when posed in terms of how the indexing groups approximate each other. Much better to avoid statments like "Fourier Series are only an approximate form of Fourier Transform" when the intent is to notice that periodic time is only like unbounded time when the period is quite long. The commmon names are more for convenience of engineering style cook books. Discussions over the correct name are about as serious as those over which is the better beer. As a grad student there was a local beer store that carried a nice Beck bock beer seasonally and some dark German beers the rest of the time so I never got into the discussions of Schlitz (Milwaukee) vrs Smidts (Philly). It was a chemistry grad student friend who found the good beer store although the late night beer and pasta joint we went to did not have the imports.>> but, Gordon, i really agree with Glen that the DFT is identical in >> every respect to the DFS. �two different names for the same thing. > > Depends on what they are. If the Fourier Series is indeed the > series computed from the finite-duration continuous function, > it is *not* the same as the DFT. > >> yes, the DFT can be thought of as the DTFT of a finite length sequence >> that is zero-padded and the DTFT is then sampled at equally spaced >> points on the unit circle. �it's true, but i think the most >> fundamental definition of the DFT is that it maps a periodic sequence >> with period N in the "time" domain to another periodic sequence with >> the same period N in the reciprocal "time" domain. > > It *can* do that, but it's not necessary. The DFT is well-defined > in its own right. The problem occurs when one, as Gordon says, > use it to compute some quantity that *ought* tho have been > computed with one of the other variations of the Fourier transform. > > Rune
On 16 Jan, 15:32, Gordon Sande <g.sa...@worldnet.att.net> wrote:> On 2009-01-16 08:05:08 -0400, Rune Allnor <all...@tele.ntnu.no> said:> > On 16 Jan, 05:39, robert bristow-johnson <r...@audioimagination.com> > > wrote: > >> On Jan 15, 4:16�pm, Gordon Sande <g.sa...@worldnet.att.net> wrote: > > >>> On 2009-01-15 16:58:07 -0400, glen herrmannsfeldt <g...@ugcs.caltech.ed > > u> said: > > >>>> The Fourier series is defined for periodic functions, integrating > >>>> (or summing) over one period. �I believe that the FFT is misnamed > >>>> (should be FFS) but it is a little late now. > > >>> It is the correct Fourier Transform over its index group. It is > >>> just that the classical mathematical physics never bothered with > >>> sampled and periodic time. They did continuous unbounded, sampled > >>> unbounded and continuous periodic time. Leaving out the only case > >>> that could actual be subject to arithmetical procedures which > >>> is the DFT and its efficient version called the FFT. > > >> the only context i have ever heard of the FFT is as the DFT, as Gordon > >> says the FFT is an efficient method to compute the DFT. �never heard > >> of the "FFS". > > > "Fast Fourier Series"? The "Fourier Series" is, I believe, the > > conventional name for the series computed from a continuous function > > of finite duration. Extending it to be used with infinite-duration > > periodic signals is a more or less ad hoc practical adaption, on a > > par with using the DFT to estimate the spectra of infinite-length > > discrete sequences. > > As an undergraduate I learned about the Fourier Transform for unbounded > continuous time. Then there was an extension for continuous periodic > timeDon't have the books available, but as I remember it, we were taught the Fourier series in the oposite order: First for infinite periodic continuous functions, then - in a different class, on differential equations - for continuous functions on an finite domain. Years later, on DSP, the discrete variations came in. It was years before I understood that the different variants of the Fourier transform were in fact different. Can't point to specific dates, but it was at least five, maybe ten, years from I had my first class on the Fourier transform till I started to see the whole picture. Or at least get the sense there was a bigger picture.> Discussions over the correct name are about as serious as > those over which is the better beer.Beg to differ. If one had a good education, as you seems to have, where the terms are introduced one by one in a sensible, cohesive way, the discussion might seem ludacris. My experience is that one sees the difference between the different variants of the FT only after close scrutiny. Insight is only achived after verbalizing the differences between the variants. If at all. Rune
Gordon Sande <g.sande@worldnet.att.net> wrote: (snip on naming of transforms)> As an undergraduate I learned about the Fourier Transform for unbounded > continuous time. Then there was an extension for continuous periodic > time to deal with rotating machinery with their discrete frequencies.Well, if you learn it that way... I knew about the Fourier series many years before undergrad, at least that a square wave could be represented as an infinite sum of sines. (But not yet how to find the appropriate sum.) Then my undergrad TA did a poor job of explaining the continuous transform as the limit of the series as the period goes to infinity. Most likely I am not the only one who learned it that way.> As a mathematical curiosity there was its "paired" analysis of unbounded > discrete time. The rotating machinery variant was called Fourier Series > and the discrete time variant was labelled Fourier Sequences. The > impression was that there was no good name with sequences being > "something other than series" and a borrowed name from Taylor series > and such. The secondary names seemed mostly to allow the several book > chapters and sections to have distinct short titles.(snip)> The commmon names are more for convenience of engineering style > cook books. Discussions over the correct name are about as serious as > those over which is the better beer. As a grad student there was a > local beer store that carried a nice Beck bock beer seasonally and some > dark German beers the rest of the time so I never got into the discussionsI agree, and am not expecting the names to change. But people expecting to use the FFT to transform non-periodic data do need to be reminded of the difference. -- glen
glen herrmannsfeldt wrote:> Gordon Sande <g.sande@worldnet.att.net> wrote: > (snip on naming of transforms) > >> As an undergraduate I learned about the Fourier Transform for unbounded >> continuous time. Then there was an extension for continuous periodic >> time to deal with rotating machinery with their discrete frequencies. > > Well, if you learn it that way... > > I knew about the Fourier series many years before undergrad, at > least that a square wave could be represented as an infinite > sum of sines. (But not yet how to find the appropriate sum.) > > Then my undergrad TA did a poor job of explaining the continuous > transform as the limit of the series as the period goes to infinity. > > Most likely I am not the only one who learned it that way.You aren't; I did too. What's more, the first harmonic analysis I did for real consisted of graphically calculating the lower (say through 7) harmonics generated in Class-B audio amplifiers using the transfer function taken from the tube's plate characteristic and its operating conditions. (Most AM transmitters of the time used no feedback in the final to suppress distortion.)>> As a mathematical curiosity there was its "paired" analysis of unbounded >> discrete time. The rotating machinery variant was called Fourier Series >> and the discrete time variant was labelled Fourier Sequences. The >> impression was that there was no good name with sequences being >> "something other than series" and a borrowed name from Taylor series >> and such. The secondary names seemed mostly to allow the several book >> chapters and sections to have distinct short titles. > > (snip) > >> The commmon names are more for convenience of engineering style >> cook books. Discussions over the correct name are about as serious as >> those over which is the better beer. As a grad student there was a >> local beer store that carried a nice Beck bock beer seasonally and some >> dark German beers the rest of the time so I never got into the discussions > > I agree, and am not expecting the names to change. > > But people expecting to use the FFT to transform non-periodic > data do need to be reminded of the difference.Oh? You mean that the FT assumes ...? :-) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Fri, 16 Jan 2009 15:44:42 -0500, Jerry Avins <jya@ieee.org> wrote:>glen herrmannsfeldt wrote: >> Gordon Sande <g.sande@worldnet.att.net> wrote: >> (snip on naming of transforms) >> >>> As an undergraduate I learned about the Fourier Transform for unbounded >>> continuous time. Then there was an extension for continuous periodic >>> time to deal with rotating machinery with their discrete frequencies. >> >> Well, if you learn it that way... >> >> I knew about the Fourier series many years before undergrad, at >> least that a square wave could be represented as an infinite >> sum of sines. (But not yet how to find the appropriate sum.) >> >> Then my undergrad TA did a poor job of explaining the continuous >> transform as the limit of the series as the period goes to infinity. >> >> Most likely I am not the only one who learned it that way. > >You aren't; I did too. What's more, the first harmonic analysis I did >for real consisted of graphically calculating the lower (say through 7) >harmonics generated in Class-B audio amplifiers using the transfer >function taken from the tube's plate characteristic and its operating >conditions. (Most AM transmitters of the time used no feedback in the >final to suppress distortion.) > >>> As a mathematical curiosity there was its "paired" analysis of unbounded >>> discrete time. The rotating machinery variant was called Fourier Series >>> and the discrete time variant was labelled Fourier Sequences. The >>> impression was that there was no good name with sequences being >>> "something other than series" and a borrowed name from Taylor series >>> and such. The secondary names seemed mostly to allow the several book >>> chapters and sections to have distinct short titles. >> >> (snip) >> >>> The commmon names are more for convenience of engineering style >>> cook books. Discussions over the correct name are about as serious as >>> those over which is the better beer. As a grad student there was a >>> local beer store that carried a nice Beck bock beer seasonally and some >>> dark German beers the rest of the time so I never got into the discussions >> >> I agree, and am not expecting the names to change. >> >> But people expecting to use the FFT to transform non-periodic >> data do need to be reminded of the difference. > >Oh? You mean that the FT assumes ...? :-) > >JerryIt's not an assumption, it's inherent... ;) Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Reply by ●January 18, 20092009-01-18
jhealy wrote:> I seem to have been characteristically unclear. > > F(k) is the function defined by the Fourier transform of f(x), > obtained by an integral over a range from minus infinity to infinity > (This is what I meant by analogue - continuous is the term I meant). > If we change the limits to some finite range, we get a function which > is increasingly unlike F(k). This is the error I'm looking for > information on. > > I think Fred is talking about this when he mentions leakage or > ripple. Can you point me in the direction of something on this Fred? > > As someone said, the equivalent case for the DFT depends on what > algorithm you use, but I'm not interested in that right now. > > Regards, > JohnWell, the FT of a rectangular window or "gate" function is a sinc. The "tails" of the sinc represent the leakage components. When you multiply a time function by a gate function - that is, you limit the extent of the nonzero record, then the frequency domain equivalent is convolution by the sinc. So, if you have a pure sinusoid of infinite extent, it will correspond to a pair of Diracs in frequency. Then, when you time limit the sinusoid, you also convolve the Diracs with a sinc in frequency. And that's what introduces the leakage terms - the tails of the sinc. The longer the time record, the narrower the sinc main lobe and the closer together the "sidelobes" (using the antenna pattern analogy). But the height of the peaks in the tails, the sidelobes, remains the same always as long as the window is rectangular. Is that what you were looking for? Fred
Reply by ●January 26, 20092009-01-26
>jhealy wrote: > >> I'm sure I've been told that there are known bounds on the mean >> square error caused by the truncation of the Fourier transform >> (analogue, preferably). Anyone know what I'm talking about? > >I don't know if this is it, but often a signal's spectrum is >stipulated to decay exponentially fast outside a certain frequency >interval. In that case, if you truncate outside that interval, the >integral of spectral magnitude over the tails exists and is bounded >by the largest (lowest-frequency) tail magnitude times a constant >(related to the decay rate). > > >MartinMartin, that sounds like exactly what I mean. Can you provide a reference for this? Thanks again for your help everyone - I haven't been as clear in what I was looking for as I would like, and your efforts are appreciated.
jhealy wrote:>>I don't know if this is it, but often a signal's spectrum is >>stipulated to decay exponentially fast outside a certain >>frequency interval. In that case, if you truncate outside that >>interval, the integral of spectral magnitude over the tails >>exists and is bounded by the largest (lowest-frequency) tail >>magnitude times a constant (related to the decay rate).> Martin, that sounds like exactly what I mean. Can you provide a > reference for this?No DSP reference, sorry. But integrals of exponentials are Calculus 101 -- int B..inf M(f) df <= 1/r * M(B), where M(f) <= a*exp(-r*f) for f > B. Martin -- Quidquid latine scriptum est, altum videtur.
