Hi, I'm researching ways to interpolate the sampled spectrum of a signal as given by a 512 point FFT. I typically only use the output of the FFT as is, but I occasionally need to resample the continuous spectrum in a non-uniform manner. I can't take a longer FFT to interpolate by zero-padding in the time domain, and usually only a few new samples of the spectrum are needed anyway. I found a solution at the following link: http://ccrma.stanford.edu/~jos/sasp/Ideal_Spectral_Interpolation_I.html I used the given MATLAB function, and it works. At the bottom of the page it says that the computational requirements of the given method can be reduced by using the sampled spectrum of the windowing function that was used as an interpolation kernel in place of the aliased sinc function. At least I think that's what that bullet is telling me. I always use a function other than a rectangular pulse to window the data before the 512 point FFT is taken, but I can't figure out how to take advantage of this to reduce the complexity of the interpolation method. It seems that the given interpolation function always works, as is, regardless of what windowing function I used. It no longer works if I try to replace the aliased sinc function with anything else. Does anyone have any advice? I don�t necessarily need my interpolated values to be extremely accurate, so my interpolation can be non-ideal. Thanks in advance.
non-uniform spectral interpolation in the frequency domain
Started by ●January 14, 2009
Reply by ●January 15, 20092009-01-15
On Jan 14, 6:58�pm, Gilead <Gilead.Tisch...@gmail.com> wrote:> Hi, > > I'm researching ways to interpolate the sampled spectrum of a signal > as given by a 512 point FFT. �I typically only use the output of the > FFT as is, but I occasionally need to resample the continuous spectrum > in a non-uniform manner. �I can't take a longer FFT to interpolate by > zero-padding in the time domain, and usually only a few new samples of > the spectrum are needed anyway. �I found a solution at the following > link: > > http://ccrma.stanford.edu/~jos/sasp/Ideal_Spectral_Interpolation_I.html > > I used the given MATLAB function, and it works. �At the bottom of the > page it says that the computational requirements of the given method > can be reduced by using the sampled spectrum of the windowing function > that was used as an interpolation kernel in place of the aliased sinc > function. �At least I think that's what that bullet is telling me. �I > always use a function other than a rectangular pulse to window the > data before the 512 point FFT is taken, but I can't figure out how to > take advantage of this to reduce the complexity of the interpolation > method. �It seems that the given interpolation function always works, > as is, regardless of what windowing function I used. �It no longer > works if I try to replace the aliased sinc function with anything > else. > > Does anyone have any advice? �I don�t necessarily need my interpolated > values to be extremely accurate, so my interpolation can be non-ideal. > > Thanks in advance.Note in the reference you gave there is an error; the 2nd equation with the delay term (to make it causal) is missing a "j". The sinc function is unique in that the original points are not altered (because when the sinc function is centered directly on a bin, it goes through zero at all other bin frequencies and hence has no contribution from its neighbors). If you use the spectrum of the window function as the interpolation kernel, this will no longer be true; the original points will be altered, so maybe this is why you are thinking it does not work. However, you have to realize that you have a window whether you want one or not; it's either rectanguar (default), or one of the many good windows out there that you can apply. It just so happens that in the rectangular case the optimal interpolation is the sinc function, which does not alter the original points. So I would not be bothered by the fact that the spectral interpolation of the non-rectanguar-windowed sequence changes the original points; this is normal. It may, however, impact your computation burden. In the rectangualr case, if you were using the original points, and also wanted some "in- between" points, you only need to calculate the interpolation function for the "in-between" points. Once you go non-rectangular, you will need to calculate the interpolation function for ALL frequency points. Bob Adams
On 15 Jan, 00:58, Gilead <Gilead.Tisch...@gmail.com> wrote:> Hi, > > I'm researching ways to interpolate the sampled spectrum of a signal > as given by a 512 point FFT. �I typically only use the output of the > FFT as is, but I occasionally need to resample the continuous spectrum > in a non-uniform manner. �I can't take a longer FFT to interpolate by > zero-padding in the time domain, and usually only a few new samples of > the spectrum are needed anyway. �Do you need additional samples to the ones you have, or do you need the spectrum to be resampled at a different uniform sampling interval? If you just need some additional samples (and depending on how many additional spectrum samples are needed) you could compute them directly from the DFT: X(w) = sum x[n] exp(jwn) This is simple to implement and not particularly expensive. It might actually be the cheapest way if you need less than, say, 5-10 additional spectrum samples. Rune
On Wed, 14 Jan 2009 15:58:30 -0800 (PST), Gilead <Gilead.Tischler@gmail.com> wrote:>Hi, > >I'm researching ways to interpolate the sampled spectrum of a signal >as given by a 512 point FFT. I typically only use the output of the >FFT as is, but I occasionally need to resample the continuous spectrum >in a non-uniform manner. I can't take a longer FFT to interpolate by >zero-padding in the time domain, and usually only a few new samples of >the spectrum are needed anyway. I found a solution at the following >link: > >http://ccrma.stanford.edu/~jos/sasp/Ideal_Spectral_Interpolation_I.html > >I used the given MATLAB function, and it works. At the bottom of the >page it says that the computational requirements of the given method >can be reduced by using the sampled spectrum of the windowing function >that was used as an interpolation kernel in place of the aliased sinc >function. At least I think that's what that bullet is telling me. I >always use a function other than a rectangular pulse to window the >data before the 512 point FFT is taken, but I can't figure out how to >take advantage of this to reduce the complexity of the interpolation >method. It seems that the given interpolation function always works, >as is, regardless of what windowing function I used. It no longer >works if I try to replace the aliased sinc function with anything >else. > >Does anyone have any advice? I don�t necessarily need my interpolated >values to be extremely accurate, so my interpolation can be non-ideal. > >Thanks in advance.Hi Gilead, To add to what Robert Adams had to say: because you said you were "researching ways to interpolate" you might have a look at [1] the Goertzel algorithm which can compute spectral samples in between the normal DFT samples, and [2] the Zoom FFT algorithm. Good Luck, [-Rick-]
